The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: Stavros on June 06, 2007, 11:47:51 pm
Thought you were the ideal person to buy one Bradders to go with the Sea queen to rescue Barbie when the Queen sinks Stavros ;)
The old sea queen will never sink....well..I hope not, it depends how thin the hull gets after I have sanded off that lovely pea green paintwork... ;)
I will take a picture and post it....just so the other chaps can see..I am sure it will inspire them
Good god man didnt I tell you there was a condition called gollygreen giant itis on that hull and whoever got rid of the wonderfull green paint would have to eat 20tins of sweetcorn (cold) at the next Mayhem gahtering.Martin knew and I was told not to tell you sugar I ahve now let the cat out of the bag or should I have said sweetcorn.Stavros
Watch out for owls and pussy cats hoping to go to sea.
Well, I was going to upload some pics but Stavros had already posted some, as below.
Now on a more serious note, what should I power the old girl with?. I have dug out an old Johnson 888 motor but Martin recons this Will be gutless, I have thought about a car heater Fan motor but not sure. I would like to use 12v lead acids to get a bit of duration any suggestions ?
(http://www.modelboatmayhem.co.uk/forum/index.php?action=dlattach;topic=3761.0;attach=9751;image)
(http://www.modelboatmayhem.co.uk/forum/index.php?action=dlattach;topic=3761.0;attach=9754;image)
Bradders, I used to run a Sea Commander many moons ago and I am certain I had a 550 motor in it
if you use the 800 it will be lethargic Braddes - - go for a 850 and water cool it.
I SHOULD KNOW I HAVE ONE !
SLightly moderated! Admin.
I use a car blower motor with 2 x 12v 7amp sla's in my old girl not the fastest on the pond but goes at a good walking pace
BobB
Bradders
I use an 850 (not water cooled). Still playing with props - 2 bladed about 55mm. Goes OK for me.
Doug
If you use a 850 power the water pump from the motor so it is controlled by the speed controller.Using a std 55mm prop it you fit 2x12 7amp batts as far back as poss she will come up on the plane with 3/4 of its length out of the water as far as duration I get 3to 4 hrs running wiht it in the plane on 3/4 throttle.Any prop bigger then 55mm affects the performance it slows down!!! Havign tried various props from 40mm up this is the best thta you can fit.stavros
Thanks for all of the info chaps.
It looks like this may all boil down to speed.
I envisaged finishing the boat as a sort of 'Broads Cruiser' type, so fast walking pace seems about right to me, I am not too bright on prop sizes but I imagined something larger turning slower (Martin has suggested with a rope cutter !!!)
I just have visions of my old Billings Admiral a few years ago thundering across the lake on its 6v lead acid only to run out of steam after about 5 Min's (a bit like me...now...) so I am looking for endurance really.
Hell I may even hang some curtains in the windows, and probably mount Barbie on the rear deck (I think I know what mean), this should please Stavros ;D
Bradders
As long as they have flowers on them ;) Stavros
.....and probably mount Barbie on the rear deck
Bradders
Now, what can he possibly mean ? ? ?
Well if it's Ken everything is ok Bradders well thats a different story ;)stavros
Piccie of my Sea Queen in full flight at Wat Tylers lake at Pitsea,850motor,55mmprop,2x12gell cells and it goes well.stavros
Well, the motor problem is solved as I have been kindly passed Buhler Motor by HS93, many thanks again Peter (Martin has the other half to the coupling as well which I have stolen from him ;D)
This is a loverly piece of engineering and will run 12-24 Volts. I have tried it on 12v and it pulls about 2 amps under finger load (bradders testing method.....remember to let go at the first smell of molten flesh...ouch ;)) so this should cruise the boat around for a few hours.
I now need to sort out a propshaft and rudder, I can then look at grinding of the 'Pea Skin' from the hull and painting with something a little less 'startling', maybe a cream hull with planked deck and burgundy suprestructure.
Pics of motor below, and I will post a few more when I get the shaft and rudder....
That green one is an ... er ... interesting colour! Does it glow in the dark?
What you need for a boat that size is ... a strimmer motor!
See martno1fan for details where you can buy one!
Ouch ! That is some seriously wrong paintwork !
Where on earth did you get the green from ? (looking for the vomit smiley) I like your idea for the colours of the repaint ;)
Have fun
Shane
Stavros had some paint left over when he painted the kitchen and being a true modeller he wasts nothing ::) ;D
BobB
Well Bradders any updates cant wait to see it Stavros
