Technical, Techniques, Hints, and Tips => Wood Care: => Topic started by: spike on November 04, 2013, 08:11:14 pm
hi what wood undercoat primer to use on my wooden deck and wheelhouse so i can paint it please
I use several coats of sanding sealer, starting with thinned sealer so it soaks in well.
hi i see you are near to me is there a boat club over there were you are
Yes The Peterborough Area Model Boat Club www.pambc.org.uk
Sailing Wednesday and Sunday afternoons
The only real issue is compatibility of the primer with any surface coats, and surface coat to any varnish. If you already have the varnish, then that may dictate the layers underneath.
I have used a primer and topcoat, of different types and got crazing.
