Mess Deck: General Section => Model Boating => Topic started by: rickles23 on June 09, 2014, 09:25:07 am
I need to make some working scupper covers (?) around a half inch in length and a quarter high.
Have you got a picture of one please, as some folks might not have seen them.
Ken
As requested, 1 photo.
just a thought;
http://www.dollshouse.com/product/186344/letter-box-8-x-25mm (http://www.dollshouse.com/product/186344/letter-box-8-x-25mm)
may provide inspiration?
Hi cdsc123,
Actually a very good idea.
I will send them an email.
Another method that was widely used on "real" ships was to fasten a steel bar about one-third of the flap depth from the top. This makes the bottom two-thirds heavier and so makes the flap self shutting with no hinges to rust up. the bare extends slightly beyond the ends of the flap plate and fastens to the bulwark through 2 simple eye bolts. BY.
Hi Bryan,
More food for thought.
The problem at model sizes is to prevent the scuppers sticking and trapping water on deck. When miniaturised, the weight is insufficient to keep them free swinging and it doesn't take much to clog up any hinging arrangements.
An alternative can be to fix the scuppers in place and then provide a drain from the lowest part of the deck just inside the bulwarks which exits at or below the waterline. This can block up too but a bit of wire will easily clear it.
