The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: Krishna on August 09, 2014, 11:58:55 am
Title: its my STAR.. the pleasure cruiser...
Post by: Krishna on August 09, 2014, 11:58:55 am
after lots of requests from my friends just on this simple boat, that can make in to anything.. so simple that is needed only 8 parts.. simple to cut and glue.. well balanced.. starting with a pleasure cruiser.. so simple.. 100% foam board, as the deck sheet and bulk heads are  4 mm and all other are 3 mm...
Title: Re: its my STAR.. the pleasure cruiser...
Post by: Krishna on August 09, 2014, 12:01:14 pm
so simple to make that can finish her in an hour...
Post by: Krishna on August 09, 2014, 12:04:17 pm
in action.. i calls her as Lake Cat...
https://www.youtube.com/watch?v=g1ubEd5Nyxs
Post by: Nordsee on August 09, 2014, 02:06:35 pm
Very nice! Just the thing for a School Group to build. You say Foam board, what is that exactly? Also could you scan the sheet with the bits on and post it? I think lots of others would like to make one!Quite a Commercial opportunity there I think!
Post by: Krishna on August 09, 2014, 04:58:19 pm
sure Nordsee.. its so easy.. and its so inexpensive.. i will scan the drawing and share you.. while i am making lots of variations with super structures, from torpedo boat to open hull boat.. i9ts so balanced.. and just can go with a toy motor..
the foam board i uses here is based on P V C, the technical name is styroflex, came as sheets of 8X4 feet, in various thickness.. here i used 4 mm for deck sheets and bulk heads while 3 mm for sides and bottom.. this makes the craft so rigid.. and so lite in weight.. usually this sheets are used to make sign boards, name plates, and thicker sheets for making false ceiling and room partitions.. can also buy in various density and colours.. the two sides will be so smooth, so we can use the craft even without painting..
Post by: setsunakaede on September 12, 2014, 03:20:32 pm
Hi Krishna,
Can you please also share the scans with me? It looks like a perfect model to build with my daughters as one of their first ships...
Also, what is the vessel in the back? Looks good too.
Post by: Krishna on September 12, 2014, 06:02:41 pm
uyyo.. please do not angry on me.. the scanned A3 papers are still in computer center.. i just kept it there because of heavy rain here.. its not good to fold to take with me on my scooter.. i will collect it next day and shares you.. its a perfect size, and well balanced, easy to make within an hour, by this time i made 12 of them in various segments including a torpedo boat.. still 3 more hulls are in free..
the primed super structure is belongs to Emma Maersk, and the 4 feet craft is for the Naval institution, is an OPV.. have a lots to do, now working on engine sound unit, and helicopter..
Post by: setsunakaede on September 12, 2014, 07:57:34 pm
Wow, those variations look good Krishna. I look forward to the scans, no rush - my girls are not at an age yet that they can sit down patiently enough to build their own boat, I am just collecting plans for when that day comes  ok2
I hope you'll share that OPV vessel as well, it looks really good as it stands on the photo!
Post by: Krishna on September 17, 2014, 07:25:29 pm
tied up in some static models.. will share plan in short time.. thank you..
Post by: hobbymartin on February 07, 2015, 10:08:15 am
Very cool.
 :-)) How long did you need to speed?
Post by: Krishna on February 08, 2015, 04:55:58 am
uyyoo.. sorry.. just moment..
Post by: Krishna on March 15, 2015, 05:12:31 am
Friends.. sorry for the delay.. no A3 scanners near me.. so just scanned as A4, and joined.. so the length of the boat hull is 15.5 inches, while measuring through the center line of the deck sheet..
the printout are in A3 papers..
the bulkheads are numbered from nose to back, as 1,2 and transom.. use 4 mm foam, or balsa sheet for deck, transom and bulkheads, while 3 mm for sides and bottom..
Post by: Krishna on March 15, 2015, 05:14:31 am
please trim out 3 mm each side of the transom, to fix the side sheets nicely with the transom..
Post by: mariopozzi on April 07, 2015, 11:46:56 am
do you have a scan of the "cabin-cruiser" version's top part?
 ok2
Post by: Krishna on April 07, 2015, 12:48:03 pm
sure..
Post by: mariopozzi on April 07, 2015, 01:29:24 pm
... and will you share this with us so we can copy your boat  O0 ?
ciao!
mario
Post by: Krishna on April 14, 2015, 07:12:29 am
bit of time.. sorry for the delay..
Post by: setsunakaede on April 29, 2015, 01:17:41 pm
Hi Krishna,
Thanks for sharing the plans for STAR, I think I will build one some day with the little girl. And I concur with Mario's question; the canopy plans for the cabin cruiser would be very nice indeed!
Post by: Krishna on May 01, 2015, 05:51:15 am
Friends.. once again so sorry for the delay.. no scanners around me.. will share you within a day.. have to go nearest town.. while, we can make any boat with this hull.. lobster boat.. little trawler.. waiting to add.. sorry for the delay once again..
Post by: Krishna on June 13, 2015, 07:27:28 am
another simple version on same hull..
Post by: setsunakaede on June 13, 2015, 10:12:20 am
That is a good looking boat once again, Krishna! Well done!
Post by: Krishna on June 13, 2015, 10:20:44 am
yes.. beautiful.. thank you Setsunakaede..
Post by: Krishna on June 21, 2015, 07:15:05 am
another one.. is Rescue Dinghie.. same hull but with a little extra work with foam tube.. so easy.. so responsive..
Post by: Krishna on June 21, 2015, 07:15:50 am
here in action..
https://www.youtube.com/watch?v=7CyFtTDeUbg&feature=youtu.be
Post by: Unsinkable 2 on June 21, 2015, 07:36:18 am
What a nice little boat :}
You are very busy, how many boats do you have? I think that I will make one of these if I can find the styrofoam in my local DIY shop. Looks fun.    U2
Post by: Krishna on June 21, 2015, 03:04:20 pm
uyyo.. not busy.. but enjoying.. modeling brings me ample of joy.. what else in my life..!!
i have given many of my crafts to some serious modelers.. but still 32 as RTR around me.. still ON.. my little house is almost house full.. thank you..
Post by: Bob K on June 21, 2015, 03:10:51 pm
Krishna, you are a real star.  I love your builds, especially that little jet engine.  Despite not having lots of model shops and model boat shows nearby you always come up with wonderful new ideas in using materials to hand to produce your gems.  Sad we can't fly you over to the UK    {:-{
Post by: Krishna on June 21, 2015, 03:18:29 pm
i am having ample of material around me Bob..  and a lots to do.. still working.. loves rain.. so is raining.. so great time for new crafts.. and yes, have a great dream to meet great modelers.. hope one day it will realize.. so i can learn lots from you all.. lots in model making.. thank you..
Post by: Krishna on July 10, 2015, 05:32:45 am
same hull another version.. easy to build.. is Police launch..
Post by: Krishna on July 29, 2015, 06:56:48 am
same hull.. another version..
Post by: Krishna on July 29, 2015, 06:57:04 am
https://www.youtube.com/watch?v=HhhP4wf4oho
