Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: richald on August 29, 2014, 09:50:17 am
Title: Moving Planet T5 stick fittings
Post by: richald on August 29, 2014, 09:50:17 am
I've had a look at the thread about fitting a spring and centreing arm -
planet t5 centre arm and spring fitting (http://www.modelboatmayhem.co.uk/forum/index.php/topic,43913.msg443865.html#msg443865)
my question is along similar lines - rather than buying a conversion kit,
is it possible to move the fittings from the right hand stick (vertical movement parts)
onto the left hand stick so that the throttle becomes spring loaded and centred
(Does that make sense ?!)
Richard
Title: Re: Moving Planet T5 stick fittings
Post by: Tug-Kenny RIP on August 29, 2014, 11:21:19 am
I don't see why not.  I did it on a Spectrum as the parts were standard each side.
Whilst you have it apart you will see the shapes of the different parts and might be able to fabricate some news ones yourself.  Let us know how you get on.
Post by: richald on August 29, 2014, 11:22:40 am
Ta Ken - I think I'll get me screwdriver out !
Richard
Post by: Tug-Kenny RIP on August 29, 2014, 11:24:20 am
Watch the spring doesn't go  ' boing'  and keep yourself grounded before touching the  'chips'
Post by: richald on August 29, 2014, 06:17:08 pm
Done it!
Took back off. Kept fingers away from Electronics and got a good hold of the spring....
1) extracted the components as shown in Plug's photo 1 from right-hand stick.
2) ratchet bar and screw moved from left-hand stick to right-hand stick.
3) small block with hook and screw fitted back into mounting on left-hand stick.
4) spring hooked onto centreing bar and then small hole drilled into bar and
small piece of brass wire super-glued onto centreing bar to retain spring. (see hook.jpg)
5) 2"-3" loop of stiff waxed thread looped through other end of spring
5 ) Thread fed through under gimbal from end with hinge mount.
6) String pulled up, two pins on centreing bar pushed into mount on gimbal.
7) Thread used to pull top loop over hook refitted in step 3.
8   Check stick movement and all bits sitting in the correct places.
9) Refit back of transmitter
Simples!
Richard
Post by: Netleyned on August 29, 2014, 06:23:58 pm
Well Done  :-))
But  ;)
Does it Work???
Post by: richald on August 29, 2014, 07:42:15 pm
Of course it does Ned - %)
providing you carry out step 8 properly! -
Been caught out before like that  -
Do the mods -
Don't check them thoroughly -
Refit the back or cover -
then find there is a fault !
Richard
