Mess Deck: General Section => Model Boating => Topic started by: dreams3577 on October 25, 2014, 08:51:24 pm
Hi All
I am looking for a replacement rudder for my Proboat shockwave 26 (broken mine today), as per the link below, However I cannot find anywhere in the world that has any available as it is a discontinued item
http://www.revmod.co.uk/ProBoat-Shockwave-26-EP-Rudder-Assembly-PRB2104.html (http://www.revmod.co.uk/ProBoat-Shockwave-26-EP-Rudder-Assembly-PRB2104.html)
Does anyone know anywhere that has one, or do I need to alter the rudder setup to something newer? if so what?
many thanks
Steve
Hi Steve.
http://shop.smallsize.no/product_info.php?cPath=230&products_id=3774&osCsid=124c1ab2ce084d9d0e0863564984643b (http://shop.smallsize.no/product_info.php?cPath=230&products_id=3774&osCsid=124c1ab2ce084d9d0e0863564984643b)
if you have just broke the rudder and not the whole assembly you could possibly just replace it with a brass one
frank
Hi Frank
Yes it is just the rudder, A brass one sounds like a good idea, do you know of an alternative brass one? ie a link to one? I cant find any that would fit the current setup.
Steve
Hi Steve.
would need to know what the I/D of the tiller arm is.
frank
Does this one from the Impulse 26 look the same? From the listing it looks like they might be interchangable.
http://www.wheelspinmodels.co.uk/i/115867/ (http://www.wheelspinmodels.co.uk/i/115867/)
Hi Brian
If you take a look at the below link you can see what the rudder looks like, very different..
Steve
Hi All
I took some pictures of the broken rudder, the diameter of the shaft is about 6mm
http://dreamstonephotography.com/photos/forumpics/rcboat_001.jpg (http://dreamstonephotography.com/photos/forumpics/rcboat_001.jpg)
http://dreamstonephotography.com/photos/forumpics/rcboat_002.jpg (http://dreamstonephotography.com/photos/forumpics/rcboat_002.jpg)
http://dreamstonephotography.com/photos/forumpics/rcboat_003.jpg (http://dreamstonephotography.com/photos/forumpics/rcboat_003.jpg)
http://dreamstonephotography.com/photos/forumpics/rcboat_004.jpg (http://dreamstonephotography.com/photos/forumpics/rcboat_004.jpg)
http://dreamstonephotography.com/photos/forumpics/rcboat_005.jpg (http://dreamstonephotography.com/photos/forumpics/rcboat_005.jpg)
Steve
You can 'Copy' and 'Paste' the pictures directly into your letter above.
as per the first picture
Ken
