The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: djrobbo on April 12, 2015, 06:39:46 pm
Hi guys and gals....thought i would start the 49 inch perkasa i have had on the shelf for years...is it me or is the glass fibre hull kit awful >:-o the hull is all out of shape and most of the wood is warped.so i have replaced the wood deck with 1.5 mm plastic sheet.now thrown what is provided for the rear shelf in the bin and scratch building that and the trim tab from plastic..the bofors gun has also found its way to the bin.i am hoping the rest of the kit isnt as bad or im in for a lot of scratch building >>:-(
HI Mate
Sounds like you have had the kit for a while, the hull straightens out when the deck beams go in, allow for the deck, the deck in styreen works better than ply, takes paint better.
With the big Percasa are you going the twin motor and prop route, shoud have 3 but thats going to be a nightmare.
More photos as you progress.
Mark
Hi...single motor..i have one of m m b;s large motors which i am reliably informed makes it go like stink on 24 volts..if it doesnt i will probably go the brushless route..never could get piccies on here but will have another go and see if i can post some this time.
What scale is the kit Rob? I ask because Italeri and Dragon do good kits of the Bofors in 1:35th. They are land pattern, but the workings are the same, they would just need fitting into naval mounts.
Hi its 1/24 and i have the 49mm bofors and the twin oerlikon already nice models in their own right .
wondering now how much more of the precedent kit will find its way to the bin O0 O0 .
Fittings;
http://www.battlecrafts.co.uk/index.php/complete-fittings-kits/172-kd-perkasa-in-1-24-scale
I do the hull
Link very slow or dead!
Fittings;
I do the hull
Just trying to be helpful, sorry.
Battlecraft is nothing to do with me.
Hi is this the one
http://www.battlecrafts.co.uk/index.php/deck-fittings?limitstart=0
aye
john
Ah! That's OK then! :-)
