Mess Deck: General Section => Model Boating => Topic started by: essex2visuvesi on April 24, 2015, 11:35:42 am
Hi guys
The Lindberg Chris Craft Constellation kit comes with "White metal" (tho I believe this to be Zamac judging by the hardness) rudders which they suggest are suitable for R/C operation.
My question is this:-
Should I use them or make/buy some brass ones?
e2v.....not sure where you found a comparison between white metal & Zamac ....but the following should keep you reading for 5 slices of toast & a few cups of tea {-)
Look a rather impressive metal .......not just sure? why they produced so many ranges of metals with such miniscule variance's % >>:-( of composition..... Derek
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FZamak&ei=Hh86VeG8E6HmmAX9tYGQAg&usg=AFQjCNG-7eZed9Xd7sVHeL-smvBocf8MqQ&bvm=bv.91427555,d.dGY
Thanks for that Derek
It was an uneducated guess on the Zamac.... More over that it is quite a bit harder than the usual white metal fittings I'm used to
e2v........I think the inverse of the melting point as ~~380++ degrees C says it all.....most low cost/poor quality die cast white metal alloys seem to be totally stable to ~~200 C, then fall over very quickly and without warning in a heap of unrecognisable and unusable sh*t. <*<............ and usually with a large % of dross formation from the atmosphere...........................Derek
Zamac........ 'Solidification range (melting range) 379—390 °C 714—734 °F'
These day I make my own by laminating styrene sheet over the stock and bonding with epoxy and then sanding to profile, but I have used white metal rudders on a couple of my earlier ships and I've had no problems with them. :-))
Why would a whitemetal (or zamac) rudder not be suitable for r/c?
Having not used white metal rudders before I just wanted to check if anyone had issues previously. I know some kits do come with some questionable running gear
Nothing better than brass. My Bugsier is now in its 30+ years old and still has the original brass rudder.
I run my boats in salt water and have had no problems.
Usual after sailing care should always be a priority.
e2v
Nothing wrong with white metal, but sometimes the post is not very well anchored to the white metal blade and in time the blade turns without the post. {:-{
Barrie
Generally I find them too heavy and use them as a pattern for a brass blade tanged into the rudder tube with any detailing added in very thin plywood.
I can understand why kit manufacturers use them and they are serviceable but I prefer to make the improvement.
