The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Krishna on June 21, 2015, 07:05:39 am
Title: its my RESCUE DINGHIE...
Post by: Krishna on June 21, 2015, 07:05:39 am
a simple build.. based on my lake cat hull.. cut about 1 cms to down to attain a shallow hull.. then glued rubber foam tube that we used to seal split A/C duct pipes.. as it may shrik with NC and PU paints, i just coated the tubing with white glue.. then easy.. powered by a low profile brush less motor, she is so powerful, and weighs only 350 grams.. without battery.. and very responsive..
Title: Re: its my RESCUE DINGHIE...
Post by: Krishna on June 21, 2015, 07:08:09 am
on..
Post by: Krishna on June 21, 2015, 07:10:15 am
and on..
Post by: Krishna on June 21, 2015, 07:11:34 am
and..
Post by: Krishna on June 21, 2015, 07:12:31 am
here she is in action..
https://www.youtube.com/watch?v=7CyFtTDeUbg&feature=youtu.be
Post by: NobbySideways on June 23, 2015, 12:52:47 pm
I love how well hidden all the components are, nice one
Post by: TugCowboy on June 23, 2015, 04:18:41 pm
Looks fantastic and goes well. Nice job Krishna.
Post by: Krishna on June 24, 2015, 10:07:37 am
yes she is beautiful.. and lovely.. thank you Friends..
Post by: Mad Scientist on June 24, 2015, 09:17:58 pm
Using the 'dummy' outboard as a rudder is such a great idea! - Tom
Post by: Krishna on June 25, 2015, 07:01:45 am
keeping drive train simple and reliable as possible.. thank you..
Post by: imsinking on June 25, 2015, 09:52:14 am
You have mastered the art of using brushless motors , do you prefer Out runners ?
What Batteries are you using ? LIPO or NiHm ?
Bill
Post by: Krishna on June 27, 2015, 07:49:19 am
yes.. sure.. brush less motors are so great.. and sure out runners as it can generate more torque, because of the leverage of the cup.. and so easy to make water cooling jackets.. great power to weight ratio.. strain free working at all throttle levels.. easy to install.. can even fix directly under water.. and in all batteries.. but mostly on LiPoly.. great power from little battery packs.. thank you..
