The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: coolbumble on August 12, 2015, 12:00:06 am
After trying to find or make a suitable sailor crew for my boat and failed !!
I therefore decided to do something a little different for a change and used these figures obtained from eBay. They are 6 inches tall with movable head and arms . It might be a bit to different for some but I think its fun. So posted some pictures.
The steam unit also has an electric water pump so I have positioned a bright flashing blue led on the top of the Life buoy post to show when it is running
Op's I see I have forgotten to put the knife in the sheaf of the last guy shown will do !I am renaming the boat Anarchy Patrol !!!
Cheers to all
Ian :-))
Well done Ian......that is a very tidy looking build :-)).......not sure about the grog bottle ;D ...just sitting there...it might spill over >>:-(
I see you have a Microcosm boiler feed pump installed [140 RPM?]....what are you thoughts on pumping performance relative to you engine & steam usage?
Its glued in place cant spill a good brew !
On tests the pump copes very well with the setup.
Ian
Thanks Ian...is this an isolation valve for an on-board boilerfeed tank?... Derek
Bonjour Ian,
Great and original idea for the crew of your beautiful launch. I also have great difficulties to find crews for my boats.
Besides this, as I also look for autonomy when possible, and even if I have electric pumps, I prefer mechanical pumps and I am fortunate to have one for my Cheddar Puffin : https://www.youtube.com/watch?v=mnkUssS4HMg (https://www.youtube.com/watch?v=mnkUssS4HMg) (tug not finished, water coming from the pond through a little filter)
Hi Derek
Yes it is and useful as a "bleed" valve. The water comes from a tube near the rear of the launch and via a filter. The small tap is originally a aquarium fitting .
Ian
The forward member of the crew now completed !!!
Ian :-)) {-)
