Mess Deck: General Section => Model Boating => Topic started by: pcresser on October 19, 2015, 11:49:42 am
Title: Kort nozzles
Post by: pcresser on October 19, 2015, 11:49:42 am
Hello Mayhemers,
Just got a beam trawler hull, it`s 960mm by 280mm, what size kort nozzle, prop and motor will I need? Can anyone give some advice, please?
Paul.
Title: Re: Kort nozzles
Post by: Martin (Admin) on October 19, 2015, 12:28:11 pm
Freelance or scale build?
Post by: Fastfaz on October 19, 2015, 01:17:07 pm
      Why a Kort nozzle on a Trawler are you going to build a Tug from the hull? For that size of hull (depending what you will be doing with the boat) I would suggest around the 70mm size Kort and 4 blade prop if you want the Kort to work.
      Cheers,
            Faz. :-)) :-)) :-)) :-)) :-)) :-)) :-))
Post by: pcresser on October 19, 2015, 01:19:55 pm
Hi, its 1:25 scale.
Paul.
Post by: pcresser on October 19, 2015, 01:24:11 pm
Hi faz all the beam trawlers have korts down this part of the world.
Paul.
Post by: Netleyned on October 19, 2015, 06:41:04 pm
The Brixham Beamers have a single fixed Kort.
Probably Dutch influence.
Post by: Martin (Admin) on October 19, 2015, 07:16:07 pm
Hi, its 1:25 scale.
Paul.
What trawler is she a model of?
Any indication of the prop or rudder size on the plan?
.... is the a plan?
Post by: pcresser on October 20, 2015, 11:40:26 am
Hi, Martin
Its a Eurokotter I got from Belgium there is a small plan but not to scale no sizes.
