The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: wombat on July 29, 2007, 10:11:33 pm
Title: Gry Maritha
Post by: wombat on July 29, 2007, 10:11:33 pm
Welcome to the new build....
No piccies yet, but I'm sure there will be fairly soon.
The work so far is to cut out the portholes and freeing ports in the hull and mount the rudder supports and the propshafts and "A" frames. Some problems there which I will document.
The plan is to make this bells and whistles all through - bow thruster, stern thruster, working crane, working fire monitor (though squirting water, not foam), working deck cargo-hatch. I am also toying with making the side hatch open. Hmmm, counting up the servo channels....
Bow Thruster - 1
Stern Thruster - 1
Motors  - 2
Rudder  - 1
Hatches - 2 Relay
Crane  - 2 + 1 Relay
Monitor - 1 + 1 Relay
Lights - 1 Relay
Hmm so that is 9 proportional channels and 5 relay channels. Going to need a bigger RC set - what I am planning doing is doing a PIC based custom control system for the auxiliaries, possibly running on a 433MHz link, which would allow for some telemetry. Quite a big job then.
Wom
Title: Re: Gry Maritha
Post by: slewis on July 29, 2007, 10:16:30 pm
Hmmmmmm   you dont like it quick and easy then ?  :D :D :D
Post by: Tug-Kenny RIP on July 29, 2007, 10:28:07 pm
We'll be on the bank, cheering you on.
Never one to sit still, eh Tim !!.    Sounds interesting.
Cheers...Ken
Post by: wombat on July 29, 2007, 10:31:48 pm
On recent performance, I better fit it with dive planes as well.
Biggest disappointment on the Highlander was it only took 5 months to build
This is a longer term project. I'm not expecting it to be hitting the water within the next 12 months. Got two other boats to play with and a speedboat in build.
Wom
Post by: slewis on July 29, 2007, 10:35:32 pm
I for one am looking forward to this build and make sure you chuck loads of pics up as you go !
Best of luck with it .
Shane
Post by: wombat on August 04, 2007, 09:05:58 pm
OK here are some piccies......
Need to get the web-site updated, but got mugged by the week!!.
OK, so now I have got the bow-thruster, stern thruster and the motor mounts in. There is loads of filler on the inside of the bow-thruster to stabilise the hull - otherwise it flexes when you are trying to sand everything in andcracks away - mutter mutter. The motor mounts took a bit of aligning to get the shafts aligned with the motor so the coupling is straight. Got it spot on with one, the other shifted while the epoxy dried and needs  shim of 0.5mm styrene on one side.
Most of the fairing in is done - just need to finish up and get ready for spray.
Wom
Post by: Channel on August 05, 2007, 02:41:49 pm
This is a very nice model, I built one a few years ago. I know the real ship very well hense my interest in the model.
Colour changed a bit in recent years, she now has cream deckhouses aft with large company logo on the outboard sides. For a number of years she had a light blue hull but its now back to mid blue. Crane cab now green too  :-\
(http://www.clydeshipping.co.uk/images/bristol/2004/06/8448.jpg)
Post by: wombat on September 16, 2007, 09:33:20 pm
A long time since I posted on this thread.....not too much has happened on the old tub - I have chopped out the door in the side ready for the opening mechanism. The bottom is painted and the rear decks are on the way to being installed. What I have focussed on though is the fit out of the running gear.
Here are the platforms for the main electrics - the distribution board is a prototype ACTion P92 (coming soon to all good leather jackets near you), hopefully to be replaced by a pukka one. The cabling is there for the motors, just got to settle onthe motor controllers......HMMMMMM, I'm thinking something that gives a certian amount of action.
The Bow and Stern thrusters will be run off a single custom controller so they operate locked together for either slew or traverse. I will set the controller up so it drops the 12V down to 7.2V to keep the thrusters happy. You can also see the reciever - not mounted, I am waiting for some Velcro so I can pop it out to change the crystal (Or I could just swap it for the Futaba in the Aziz)
Next stage is to get the decks in but not until the control gubbins are in.
Wom
Post by: Voyager on September 16, 2007, 11:40:08 pm
I wish i was that good with electronics ::) Envy aside, your model is lookin rather impressive i must say!
I'm gonna be keeping tabs on this one, with any luck i just might learn something...I'll start with something simple like changing a fuse first ;D
Keep up the good work ship mate!
Post by: Tug-Kenny RIP on September 17, 2007, 11:24:05 am
Nice high freeboard on this model. I can see why it flexes when empty.
Looks like plenty of room for 'stuff' inside. Watching with interest Wom. Keep up the good work. It's so tidy. O0
Cheers...Ken
Post by: BORIS on September 19, 2007, 09:30:38 pm
Good choice of model there O0 i have made it myself but i only have the Bow Thruster ..and yes due to the angle of the Hull , it was a little awkward to  drill out the holes to fit etc..but you have done a decent job..i like your electrics ..you have much more cables etc than i do yet everything looks so neat..good luck with the rest of it and keep sending the pictures...ps "channel your model is diabolical!!! only joking I mean Great!! and yes you are right about the actuall boat being a Darker Blue..[i live in penzance] so if i could make it again [wombat] .i would use a darker colour blue.
Post by: Tug-Kenny RIP on September 23, 2007, 09:04:09 pm
I really like this model, and may well be buying it soon.     O0
Have done a bit of research and find there was a write up in Marine Modelling in April and June of 1995. The June edition is now out of print, so no point in getting just the April copy.  Does anyone have these 'Mags' and could possibly let me have , either the originals or perhaps photocopies. I will gladly pay my way.   :)
Perhaps Wom would be interested as well.
Cheers...Ken
Post by: wombat on October 06, 2007, 08:52:04 pm
Lots of nice comments there  :embarrassed:
The thing about the Gry is that it is totally asymmetric. Though it is a bit slab sided - striking (read ugly) rather than elegant.  Progress continues to be slow, mainly because I have been spending time on the two black boxes on the sides of the equipment platform. SWMBO has been moaning I have spent too much time on them. Basically they are a pair of ACTion style ESCs. OK I admit it, more prototypes for FLJ - this time the P93 Multicontroller - they just need a few more tweaks to get them spot on. Also a quick sneaky-peak at what goes on inside.
The blank black box is placeholder - for the Bow/Stern thruster controller that I need to cook up. Basically two ESCs in a box controlled off a single channel. Toggling the stick to one end or another sets the thrusters to run either in the same direction or opposite directions - which give either traverse or rotate. Need to get this done before the decks go in, though I may take a break from electronics and get some of the building done.
The reciver is mounted up on its side on velcro because of cable length limitations on the servo cables - the velcro means I can lift it off the support to change the crystal, because when the decks are in accesss is limited - as it is, I will have to make a false base for the main hatch area so it can be lifted out to give access to the battery.
Building the model ahas thrown acouple of problems, I don't think the documentation is as good as the Aziz - for instance I have built my own deck reinforcements before finding the parts required on parge two of the plans - if they were mentioned in the manual I missed it.  Never mind eh!
Also got to start thinking about how to do the crane and hatch controls  - for the winching operations, I am thinking of doctored servos - so they become more like ESC/motor sets. Similar to the article in the mags this month, but without removing them from the case. Shouldn't be too hardto butcher the S3003s to do this. Couple of PICs and things to provide the limit switching and control. But that is yet to come.
Voyager - I spend too much of my life on electronics - though now I am more hands-off at work these days. Part of the reason for doing this design is that I want to keep my hand in.
Kenny - I think that the room inside is deceptive - there is a reasonable amount, but it is getting eaten up. Also the front superstructure is not removable (as far as I can tell, so it will be difficult to use that space.
Boris - I will be painting it in the darker blue colour - witohut the large lables on the side as that look more attactive to me - I would like to see the real ship, but Penzance is a bit of a trek for me. I will have ot do with photos - though I would like ot get my hands on a decent copy of the owners logo for the side. I do like tidy electrics - it does make fault finding so much easier. I think also that it helps the reliability - though I get through ty-raps and cable tie bases like they are going out of fashion. I am using Crimp pins and bootlace ferrules on this model because of the large number of screw terminals  - they really do make life easier and avoids thep roblem of leads pulling out. (Note to self - piut the ferrules onot the p92 connections)
Wom
Post by: wombat on December 16, 2007, 08:56:07 pm
It is two an a half moths since my last confession.....
Not a lot of movement since then, or at least not a lot of visible movement. The main main change is that the hull electronics are completed - it has eveything to drive the boat through the water. Lots of ACTion stuff in there - all prototypes I'm afraid. The drive motors are driven using P93 ESCs - incidentally, these have been updated to support limit switching, ideal for winches on those thug-tugs. Nestling between them is a prototype of the Bow/Stern thruster controller - basically it is a dual esc whic will run as a dual ESC, an integrated ESC/Mixer or the mode I am using - which is for the thrusters. One stick is used to control the thruster speed, blipping the rudder when the thruster control is on neutral makes the thrusters drive in opposite directions (Spinning) or in the same direction (traverse).
The crane is built up and most of the detailing is done hough the paintork needs touching up a bit and a few details need to be painted in. I have the mechanism for spinning the crane and raising and lowering the jib. There is a stub on the drive motor which will be used for a potentiometer used to position the boom -  particularly for limit switching, though it will be used for parking the boom. The raise/lower is driven by a servo. The litle bit of wire you can seen hanging is for the hook cable - though whether I will actually use it is a bit moot at the moment - ideally it would have routed down the raise/lower control shaft but I didn't have any handy - it should be OK as long as the boom isn't allowed to swing too far.
Wom
Post by: pops on December 18, 2007, 12:40:48 am
Very nice work wombat. I especially like the neatness inside the hull. It's hidden to most people and many overlook this area. I like that you have put a neatness priority in it. Great thread, look forward to seeing more of it.
Post by: bosun on December 18, 2007, 10:19:41 am
Hy Wombat,
I am really impressed with your build, its looking great...one question,,,, (maybe a bit of a daft one) on the pic number 2628, there is what looks like a screw on the end of the ariel wire, is there a specific reason for this ?, or am I mistaken.
Bosun
Post by: wombat on December 19, 2007, 10:27:27 pm
Hi Guys,
Pops, I put great store by tidy wiring - it is more reliable, easier to fault-find and easier to modify than the rats-nests that you see all too often. Then again, my background is in things like HV systems and Evacuation systems (and a little bit of hazardous area work) so I have been trained in the right way to wire things up. Also the inside should look as good as possible - after all you have to look at it every time you take the top off the boat. I was toying with painting the inside, but then I had a lie down and felt better. Note to self: must sort socks by age, colour and size of hole.
Bosun,
the screw on the end of the aerial lead is for the external aerial - it pushes into a moulding mounted on the deck and the aerial wire screws into it. The mounting will be disguised as a bit of cargo, then when I am sailing I just screw on the aerial. Here are the details....
http://www.jperkinsdistribution.co.uk/detail.php?JPNO=5511775&activepage=1&Navmain=Marine&subcatname=Accessories%20marine (http://www.jperkinsdistribution.co.uk/detail.php?JPNO=5511775&activepage=1&Navmain=Marine&subcatname=Accessories%20marine)
Wom
Post by: Stavros on December 19, 2007, 10:53:19 pm
Wombat I presume that the middle Black box is either a mixer or speed controller,dare I ask knowing your superior knowlage of electrics BUT wont you get interference having the receiver so close to it whatever it be!!!!
Post by: wombat on December 19, 2007, 11:33:37 pm
Hi Stavros,
Right on both counts - it is actually 2 ESCs and a mixer in a box. And a good question...the effects of radiated emissions from the ESCs on the reciever will be relatively limited - the rise time of the FETs is around 150nS (equivalent to around 6.6MHz) so the main frequencies from the switching are well below the 40MHz. The big problem comes from the switcihng current spikes coming up the wiring into the reciever and upsetting the output logic. This is limited by separating the power wiring from the reciever wiring - these are bundled up and kept away from the power wiring - you can't see it clearly, but I will try to get some better pictures. Inside the ESCs I have resistors between the power ground and the reciever grounds to prevent ground loops, which are a real killer. All the power stars up at the P92 deistribution board so current pulses on one ESC cannot couple onto the others or onto the reciever.
All sounds a bit complicated but the principles I have used are basically:
1/.  Keep power and servo leads separate - if you are running for more than about 100mm, keep servo leads separate to prevent crosstalk
2/. Do not loop signals and power through multiple units, bring them to a common point - more wires but less interference
3/. Size the wires generously
4/. Run power and ground together rather than spearately - if you are really worried about noise twist them together though this can be overkill
5/. Suppress the motors well. I prefer 100nF to case, 220nF across motor terminals. Always use good quality disk ceramic capacitors with a 100V rating.
Wom
Post by: kiteman1 on December 20, 2007, 07:45:53 pm
Hi Wombat
It's interesting to read about the effects of interference.  Would it make any difference if the power and radio wires were each wrapped in tinfoil and then run together down the length of the model?  Would this method cure any crosstalk?
Post by: wombat on December 20, 2007, 08:38:19 pm
Hi Kiteman,
Tinfoil would help to prevent crosstalk and interference, though you would have to make sure that the tinfoil is grounded at one end. Effectively this will screen any electric field interference. More effective yet is screen both sets of cables.
If it were me though, I would splash out on screened cable, particularly for the servo leads. The effort to get a good screen with tinfoil wrapping would be difficult. I would consider this to be a last ditch effort - you don't actually need that much space to get a reasonable reduction of interfeence. Down opposite sides of the hull would give a good separation. The interference reduces with the square of the separation - so if you double the space between the cables, you quarter the interferece.
Wom
Post by: Stavros on December 20, 2007, 10:30:00 pm
Thanks for that Wombat I knew there was a simple reason behind your logic
Post by: wombat on December 21, 2007, 03:28:35 pm
Here is a close up of the Radio wiring - I am using the BEC on the P92 which is fed into the P94 mixer/ESC then out to the other ESCs and the rudder servo
Wom
Post by: wombat on April 08, 2008, 10:27:58 pm
Hi All,
Well here are the latest updates. The foredeck is in - put the deck in level with the rear decks as I understood the instructions - this is also at the same height of the superstructure, but is about 3mm below the freeing ports. Probably wrong, but hey - don't think I can face changing it now.
I have ballasted it up so it sits level on the water - side to side and front to back. I will probably have to be back out with the level once the superstructure is in - I guess the crane will imbalance it. The electrics have been totally redone - all the motors are now protected by P95s with appropriatly graded fuses. The P94 is not debugged so all you people dying to get their sticky little maulers on them don't have long to wait - runs the thrusters a treat, but those graupner thrusters are really noisy. There is a little bit of a leak on them - maybe 5-10ml in two or three hours, nothing to worry about.
Next stage is to get the rear part of the deck in - will need to add in some spacers to get the right curve on the hull to match the superstructure. This needs to be painted up but it is complete.
The main hatch is done - a slight gap to fix, but not a big problem. The split in the hatches is not quite right - the inner ones lift off the rails at the extremes and there is a lock up if you open it too far. Will have to limit the travel.
Wom
Post by: wombat on April 09, 2008, 07:19:35 pm
AAAAAAARRRRRRRRGGGGGGGGHHHHHHHHH
Never ever write messages at bed time!!!!!!
It should read
The P94 is NOW debugged
The software is ready and tested and good to go!!!!!!!!!
Wom
Post by: Stavros on April 09, 2008, 08:59:12 pm
Aw Wombat I thought it was only me that dropped clangers
 YOU ARE FORGIVEN O0/size]
SSTAVROS
Post by: wombat on April 09, 2008, 09:22:23 pm
Stav,
I saw this and thought of you.....
http://www.bbc.co.uk/broadband/mediawrapper/consoles/deadringers/bb_rm_console.shtml?pack1-deadringers_s3ep3_16x9 (http://www.bbc.co.uk/broadband/mediawrapper/consoles/deadringers/bb_rm_console.shtml?pack1-deadringers_s3ep3_16x9)
 :P :P :P :P
Post by: Stavros on April 09, 2008, 09:51:13 pm
Oh you war declared   love it
Post by: FullLeatherJacket on April 10, 2008, 09:25:54 am
Wom
Thanks, Wom. Having just shelled out well over a grand on PCBs, PIC chips, relays, heatsinks and cases you can imagine how grateful I was for that simple typo....... :o
Am I safe to put clean underwear on now?
BTW P94 should be available early next month - just waiting for the heat-sink tabs............. and Footski is top of the waiting list.
FLJ
Post by: wombat on June 07, 2008, 04:40:28 pm
OK, another update - things are going slowly at the moment but progress is being made!!!
The hull is painted and sealed withe the waterslide transfers on - however, yet again I broke one so the name on the stern is tiny ones for the ships boat - that will have to do without. I need to put in a boot topping line to hide the gap between the blue and red.
The decks are painted - this was done with Tamiya acrylic green - bit patchy in places especially on the hatch - but should look like it has seen some action. The crane is now in and seems to run OK - there are some shots of the mechanism - works quite well. Might lose the position sensing pot though - got to see how we do....
Here are some shots of the side lift - I was going to have a swinging platform, but found this video:
http://www.bbc.co.uk/mediaselector/check/cornwall/videonation/cornwall_seasick?size=4x3&bgc=C0C0C0&nbram=1&bbram=1 (http://www.bbc.co.uk/mediaselector/check/cornwall/videonation/cornwall_seasick?size=4x3&bgc=C0C0C0&nbram=1&bbram=1)
So now we have a straight lift with an extending deck - all run off two servos.
Wom
Post by: wombat on August 03, 2008, 05:01:45 pm
OK here is a little update  - my first Youtube video - apologies for the poor quality.
These little beasties will be controlling the side hatch and lift and the main doors - they are controlled off a contact - throw the contact one way, and they move in sequence at the preset speed to the preset position. throw it the other way and they move back to their original positions in the opposite sequence. So for example, when the contact is closed, the side hatch will open, the cargo lift rise and then the cargo platform extend. When the contact opens the cargo platform will retract, the platform descend and the side hatch close.
http://www.youtube.com/watch?v=56kyqHK878g (http://www.youtube.com/watch?v=56kyqHK878g)
Wom
Post by: wombat on August 18, 2008, 05:17:23 pm
After a few disasters - here is the the first test run of the side hatch assembly for the Gry - some small problems to be ironed out - don't really like the border around the hatch - but it hides the uneven gap. Also the hatch needs to be curved slightly.
http://www.youtube.com/watch?v=QU2HpEWZ2WE (http://www.youtube.com/watch?v=QU2HpEWZ2WE)
It does however show the P96 servomorph in action (pardon the pun) - the whole thing is controlled off a single switch.
Wom
Post by: barryfoote on August 18, 2008, 05:23:22 pm
Wom,
Very impressive. Looking forward to more..
Barry
Post by: barriew on August 18, 2008, 05:32:05 pm
Very impressive Tim, looking forward to seeing at the lake - if we ever get anymore decent weather :(
Barrie
Post by: catengineman on August 18, 2008, 08:15:07 pm
Great engineering there  O0
R,
Post by: Tug-Kenny RIP on August 18, 2008, 08:27:05 pm
That was pure genius. I love it.
Well done, can we copy you ??    8)
Post by: FullLeatherJacket on August 18, 2008, 10:24:06 pm
Ken
That's the idea, mate! P96 to follow shortly.
FLJ
Post by: wombat on August 19, 2008, 07:18:58 pm
Thanks  for the kind words....
The engineering is not that great - there have been a lot of blunders and don't look too closely - perhaps if I had designed the mechanisms up front rather than winging it.
Some of the paint is a bit rough and the motion is not even - there are a few catch points. But at least it works.
By the way Mr Jaquet - I owe you a servo. Originally it had miniature servos but these burnt out but I had to replace them with standard servos. Time to tidy up the wiring and then get the hatches sorted.
Wom
Post by: FullLeatherJacket on August 19, 2008, 07:42:34 pm
I don't think so, dude. Anyway, I have a box full of them already  ;)
FLJ
Post by: wombat on August 21, 2008, 08:35:28 pm
OK I know this is a bit boring - but here is more fun with the P96. This time it is driving the main hatches - for the side hatch and the lift and extend, the P96 were rigged up using the sequencing system. For the top hatch, they were driven off the same signal - the speeds were tweaked so they close in the right order - had to do this because if the hatches close in the wrong order they snag up on each other and don't shut. Also I cant open the hatches more than that because the guide wheels lift off and the thing snags up when they close. Possibly the inner ones should have been longer and the outer ones longer.
http://www.youtube.com/watch?v=nGth5ImQTys (http://www.youtube.com/watch?v=nGth5ImQTys)
It is flagging up a few problems with the layout - can't open the main hatches unless the crane has been swung out of the way and will have to be careful to avoid colliding with the hatch when swinging the crane. But it all works apart from the raise and lower on the crane hook.
Seems to be turning into a bit of show case for ACTion - so far we have got:
1* P92 (possibly another one going in)
2* P93
1* P94
4* P95
5* P96
Next stage on the electronics is to build controller using 433MHz telemetry. ON the actual build is putting in the main passenger cabin
Wom
Things will go quiet again for a bit
Wom
Post by: barryfoote on August 21, 2008, 08:38:18 pm
Wom,
I don't know what it will be but got to put my name down for the first P100.. O0 It has a certain ring to it... :angel:
Post by: wombat on August 21, 2008, 08:46:23 pm
Well, I suspect I know what the P100 is going to be but I'm not telling  :angel:
