Mess Deck: General Section => Model Boating => Topic started by: boat captain on July 02, 2016, 03:37:57 pm
Does anybody know any suppliers of 4mm or 3ba brass castle nuts and split pins.
When you say "castle nuts" do you mean the ones that have several slots across the top? Or acorn nuts? Anyway, digging through my bookmarks reveals a few sites that may be helpful.
http://www.scalehardware.com/slotted-bolts-c-46
http://www.modellingtimbers.co.uk/36.html
Castellated Nuts is the correct description I think.
I have always known them as castellated nuts but on a lot of sites they list them now as castle nuts.
Possibly the American terminology?
Chris
This is a Russian site ( I think!). Is this what you are looking for? No picture though.
http://soga-miniatures.ru.com/index.php?productID=4066 (http://soga-miniatures.ru.com/index.php?productID=4066)
They may be cosmetic, rather than functional though. - but as I don't speak Russian, so...........
Chris
Can you not use Nyloc nuts ?
The nut's would be no problem to anyone mit zer lathe / miller . . .
Split pins that small is another story . . .
Bill
They are for a Severn Lifeboat propellors which are secured with castellated nuts and split pins.
Like these?
http://www.nutsboltsandthings.co.uk/castle-nuts
or these
http://www.ebay.co.uk/itm/Turnbuckle-Stainless-Castle-Slotted-Nuts-Multi-Listing-M4-to-M18-/221231462658
Drilling the hoe in the shaft for the pin or wire could be a job and a bit - for function I would go for a nyloc and maybe, if I was that bothered about appearance, modify that to look like a wired/pinned nut.
Like these?
or these
It is purely a cosmetic appearence the nuts will be soldered on the propellers with a sub shaft and pin soldered in the nut.
I am using K-lock nuts on my boat as they look pretty close and can be used to lock the props in place as well.
Craig.
