Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: Ian K on August 07, 2016, 05:47:36 pm
I have a question about the DSC connection on the Futaba 8 channel 40 MHz receiver.
Is it possible to use this as a power in socket, rather than use a Y lead on the 8th channel socket?
Nothing is mentioned in the manual regarding this socket. I do know it is for the cable connected direct servo control function, to check systems without transmitting a signal.
Ian
Yes, no problem.
Hi Subculture,
Thanks for your reply. I thought it would be OK, but needed reassurance before plugging in.
Ian
