Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: Norman Castle on August 13, 2016, 03:20:02 pm
Title: Help please with Flysky FS-GT2E tx problem!
Post by: Norman Castle on August 13, 2016, 03:20:02 pm
Needing a cheapo tx for the lady wife to use with her airboat, I ended up getting a Flysky FS-GT2E and the thing is driving me up the wall  :((
I've followed the quaint instructions to the best of my ability, and the supplied RX (an FS-A3) is correctly connected to both throttle (ESC driving brushless motor) and servo.  TX throttle trim is zeroed, and bind plug is removed.  On switching on the TX, both red and green LEDs are on steady.
When I connect the battery to the RX, the RX LED cxomes on steady, and the motor keeps beeping 2-3 times a second after the usual 3-note startup beep.  Rudders respond correctly to input from the steering wheel, but nothing will persuade the motor to respond to the throttle.
The motor works just fine with the same ESC when I revert to my usual Spektrum/Orange setup, so can anybody please suggest what I'm doing wrong before I hurl the thing out the window and write off £17?
Title: Re: Help please with Flysky FS-GT2E tx problem!
Post by: Netleyned on August 13, 2016, 03:44:20 pm
Have you tried changing the throttle reverse setting?
Just a thought.
Post by: Norman Castle on August 13, 2016, 03:52:23 pm
Just a thought.
I hadn't, Ned, but I have now - and after maybe 5 seconds, the motor ran right way round at or close to flat out with no pressure on the trigger!  What's really bizarre though is that I can't make it do that again, irrespective of the throttle reverse setting.
This is not sensible at all ...  {:-{
Post by: barriew on August 13, 2016, 03:52:57 pm
As this is an air boat, I take it you are using a Forward Only ESC. I think you will find that the ESC requires the throttle to be set to minimum when you switch on. With a steerwheel type transmitter this may be difficult. These ESCs are normally used by the aero guys who use the non- centering stick on a conventional TX. This is a safety system to protect you from whirring props.
Barrie
Post by: barriew on August 13, 2016, 03:55:03 pm
As this is an air boat, I take it you are using a Forward Only ESC. I think you will find that the ESC requires the throttle to be set to minimum when you switch on - that is full reverse with a centered channel. With a steerwheel type transmitter this may be difficult. These ESCs are normally used by the aero guys who use the non- centering stick on a conventional TX.
Barrie
Not sure why this ended up as quote!
Post by: Norman Castle on August 13, 2016, 04:00:49 pm
Yep, forward-only ESC, but doesn't no pressure on the TX trigger mean "off" in the same sense as stick fully back on a conventional aircraft TX?
Post by: barriew on August 13, 2016, 04:19:28 pm
Sorry Norman - no. No pressure means mid- point.  Its a question of the signal the TX sends. This does not go negative for reverse - its just by convention that neutral in boats and cars is effectively 50% throttle for aircraft.
I think you are going to have a problem using your Tx with your airboat.
Barrie
Post by: Netleyned on August 13, 2016, 05:18:08 pm
It may be possible to programme the esc to recognise the centre position of the trigger.
I use a trigger and wheel Tx with a forwards only esc in a small
fast electric with no problems.
You could try starting up with the trigger held in reverse while switching on the Rx.
When you first asked about a cheap Tx , you were a bit secretive about the intended
use. A bit more info would have allowed a more informative response.
Post by: Norman Castle on August 13, 2016, 05:47:19 pm
use.
Not intentionally, Ned.  It would never have occurred to me that no pressure on the trigger equates to 50% throttle, which is why I simply said that I didn't need reverse.
Anyhow, I've tried the start up with trigger held in reverse and although the bleeps coming from the motor are different, it's still no go.  The question now is, how have you got something similar working for you?  I'd give up on the idea now despite that leaving me £17 down which I can't really afford, but unfortunately the lady wife had a try of rudder control via steering wheel and liked it lots ...  :((
Post by: barriew on August 13, 2016, 05:50:58 pm
Norman,
Its really down to the ESC - do you have the instructions for it? These will tell you what the ESC is telling you with the beeps, which may help to see how the Tx can be used.
Barrie
Post by: Norman Castle on August 13, 2016, 05:56:05 pm
Norman,
Barrie
Ah!  I don't think I have destructions for this one, but I might have another ESC I can try it with for which they might be online.  Back very shortly!
Post by: Netleyned on August 13, 2016, 05:59:04 pm
If you do not have the instructions they are usually
available on line.
Just google the make and model instructions and
you should find the answer.
Post by: Norman Castle on August 13, 2016, 06:06:30 pm
OK ... I've found the other ESC which I know works as it should.  It's a Perkins 20A and the book of words for it is here .pdf]http://www.phoenixmp.com/acatalog/4404850a[1].pdf (http://www.phoenixmp.com/acatalog/4404850a[1) but I can't see anything there that's relevant to the current problem.
Looks like I'm snookered.
Post by: Netleyned on August 13, 2016, 06:14:01 pm
Are you saying the perky works with your new Tx?
If so you need to look at the esc programming.
Post by: barriew on August 13, 2016, 06:14:35 pm
I tend to agree The only thing I can suggest is if you are able (willing) to open up the TX and remove the centring spring on the throttle.
Barrie
Post by: Netleyned on August 13, 2016, 06:21:37 pm
The spring fell off mine Barrie,
Made no difference to the operation.
Just a bit awkward finding stop!
Opened it up and found the plastic
holder had snapped off so drilled and fixed
a 2 mm bolt head to hook the spring on.
Post by: Norman Castle on August 13, 2016, 06:42:56 pm
Sorry, Ned - brain is just about fried with this.  The Perkins one works just fine in the airboat with the Spektrum TX but I need to see what happens with this toy TX.  Will swop it over and report back in the morning: must away now and do some cooking or I shall be in the doghouse ...
Thanks for your help so far, chaps.  Enjoy your evening  :-)
Post by: barriew on August 14, 2016, 06:30:51 am
Norman - Do you use a "centered" channel on your Spektrum? The Perkins ESC manual states that the throttle must be set to minimum before switching on.
Ned - I suggested removing the spring so the Tx could be switched on with the throttle at minimum - Full reverse for a boat.
I don't have one of the steerwheel transmitters, but have run into problems using forward only ESCs on a centered channel in an airboat.
Barrie
Post by: Norman Castle on August 14, 2016, 06:47:00 am
Barrie, I think you've just about summed it up here.  The Spektrum we use with the airboat is one of the later ones which is readily convertible from centred to aircraft mode and back again (at least it is if you drill a hole in the case exactly over the appropriate screw) and we use it in pull-stick-back-to-stop mode.
The reason I tried to go down this route is that having seen videos of people controlling airboats with pistol-grip TXs, my wife took a fancy to using one.  But it now looks to me like there must be something special about the ESCs they use with them.
Post by: barriew on August 14, 2016, 07:07:26 am
Norman
The Flysky should still work, IF you can do the same and disable the spring and start with the lever in "full reverse".
Barrie
Post by: Netleyned on August 14, 2016, 07:08:57 am
No need to move the spring.
Try holding the trigger full astern whilst
switching on Tx and then Rx.
Worth a try O0
Post by: barriew on August 14, 2016, 07:11:40 am
Agreed Ned, but I thought he had tried that. Maybe try both ways - full forward and full reverse in case the channel is reversed %)
Barrie
Post by: Netleyned on August 14, 2016, 07:18:02 am
Just had a thought,
We have a club member who uses one of these with a fast elec fwd only
and I've noticed he has an elastic band holding the trigger in full reverse
until he pulls the trigger. The elastic band returns the trigger to full reverse.
I wonder if that is to get around this problem.
If he is at the lake today I ill find out.
Post by: barriew on August 14, 2016, 07:20:00 am
That should solve the problem provided the channel isn't reversed.
Barrie
Post by: Norman Castle on August 14, 2016, 08:30:28 am
Gosh, thanks gents.  I'll try that now.  Just had a thought though - if it doesn't work, could I use a car speed controller?
HURRAH!!!!  IT WORKS!!!!!
The rubber band trick has done it.  No idea how that works, but it does, so the lady wife will be well chuffed.  Hopefully there will even be cake for tea.
Thank you very much indeed gents.  I really appreciate your help.
Post by: Netleyned on August 14, 2016, 08:44:06 am
Great news Norman.
I suppose if you open it up it would be possible
to modify the spring to do the same job.
Lots of brownie points eh mate :-)) :-))
Post by: nivapilot on August 14, 2016, 09:03:33 am
I love it when a plan comes together...
I really don't think you can beat the combined knowledge and friendliness of this forum........well done lads.....another pat on the back and a problem solved..
Post by: barriew on August 14, 2016, 12:26:47 pm
Hi Norman
Just back from the lake. I'm pleased that you have got it working.  If you're brave enough to open up the Tx I think removing the spring would have the same effect.
A car or boat ESC could be used, but of course the reverse would not work and so you would have coarser control of the forward speed.
Barrie
Post by: Norman Castle on August 14, 2016, 12:48:31 pm
Well, that was interesting.  Her Ladyship's well chuffed with her new TX, and was very soon driving her airboat all over the pond like a 12 year-old showing off to his mates!  In due course I was allowed a go on it too, and to my surprise I found it very good for use with a hooligan boat.  Completely intuitive, but I wouldn't fancy using it for a "proper" boat.
Thanks again folks, from both of us.
