Mess Deck: General Section => Model Boating => Topic started by: Gopher on October 10, 2016, 07:45:55 pm
Title: Help to identify a few bits
Post by: Gopher on October 10, 2016, 07:45:55 pm
Good evening all, sorting a few drawers came across these and I have no idea what they are used for, can anyone help?
Title: Re: Help to identify a few bits
Post by: Plastic - RIP on October 10, 2016, 08:06:09 pm
2sC2500 = transistor for firing flash strobes
TDA7052 = 1W mono amplifier
last thing - can't see it properly
Post by: Gopher on October 10, 2016, 08:21:04 pm
many thanks, I will try and get a better photo of the last item, the 1st 2 will go back in the drawer I don't think I will ever use them
Post by: nivapilot on October 10, 2016, 08:22:24 pm
Third one looks like it/they might be the sort of small cable crimps that the GPO used to use on their systems.
Post by: Gopher on October 10, 2016, 08:30:37 pm
is this a better picture
Post by: Gopher on October 10, 2016, 08:41:22 pm
just cracked one open they are a connector for thin wires, I may be able to use these
Post by: malcolmfrary on October 10, 2016, 09:05:35 pm
Almost as Nivapilot said, IDC crimps for wires of small diameter, although by the time that they came into use, the GPO had long lost any interest in phone lines.  They were stuffed with silicone grease to help keep damp away from the join.  Sort of, a mini Scotchlock.  They needed parallel action pliers to work as intended, but ordinary ones could work.
Post by: Gopher on October 10, 2016, 09:26:11 pm
Many thanks for that, I did notice some grease inside, I am having thoughts about trying to wire one of the strobe transistors up just for fun so I will need some help with what I will need to do it
Post by: malcolmfrary on October 11, 2016, 08:29:31 am
The datasheet - http://html.alldatasheet.com/html-pdf/30107/TOSHIBA/2SC2500/246/1/2SC2500.html - indicates a nice medium power NPN transistor, should be good for a wide range of applications on low-ish voltage and moderate current.  The strobing will be a function of whatever is controlling it, not the transistor itself.
Post by: Plastic - RIP on October 11, 2016, 08:41:13 am
The datasheet - http://html.alldatasheet.com/html-pdf/30107/TOSHIBA/2SC2500/246/1/2SC2500.html (http://html.alldatasheet.com/html-pdf/30107/TOSHIBA/2SC2500/246/1/2SC2500.html) - indicates a nice medium power NPN transistor, should be good for a wide range of applications on low-ish voltage and moderate current.  The strobing will be a function of whatever is controlling it, not the transistor itself.
Dunno why anybody uses discrete transistors these days - you're always going to need more components around them so whatever you're building, there's probably a chip that does the job all in one box.
Post by: nivapilot on October 11, 2016, 10:40:20 am
Here is a small amplifier circuit using the TDA7052.......now all you need is a suitable sound input.....hey presto.....sound module. :-))
http://www.eleccircuit.com/super-small-amp-12w-by-ic-tda7052/ (http://www.eleccircuit.com/super-small-amp-12w-by-ic-tda7052/)
Post by: canabus on October 11, 2016, 11:34:04 am
Hi All
Mal is right they are scotch locks used in the telephone industry including Australia.
Post by: malcolmfrary on October 12, 2016, 08:04:46 am
Chips tend to be picky about the voltages that they will interface with - there are still lots of applications where a chip is cheaply available to do the clever bits but a transistor or something similar is needed to interface with external power.
Post by: Plastic - RIP on October 12, 2016, 08:16:11 am
Totally agree - the need for special transistors - but an average, boring, middle-of-the-road single transistor is pretty much pointless these days.
Post by: Arthur_C on October 18, 2016, 01:43:17 pm
H
Last one is connector used by th post office to connect telehone wires. put wires in hoelos in pess close with a plier.
