The Shipyard ( Dry Dock ): Builds & Questions => Submarines => Topic started by: webbo on December 23, 2016, 04:35:15 pm
Title: paint colours
Post by: webbo on December 23, 2016, 04:35:15 pm
Hi I am struggling to find correct colours for US Los Angeles class  , can anybody help :embarrassed:
Title: Re: paint colours
Post by: unbuiltnautilus on December 23, 2016, 07:14:57 pm
I don't think black works for the upper colour, it needs to be a very dark grey colour. Revell Anthracite is a good 'off black' colour. This can be weathered with slightly lighter colours for vertical streaking. Plus a hard black can be used for random panels, which will then stand out.
I think the Los Angeles class has a red lower hull, below the mid point of the hull. Dry dock photos, from memory, often show a washed out salmon pink sort of colour, indicating extreme wear and tear. So my thoughts would be anything from a flat primer red brown to a very washed out red/pink sort of colour..How is that for vague??
Post by: derekwarner on December 24, 2016, 01:19:20 am
UBN  says...... 'a washed out salmon pink sort of colour' ....
This sounds like a 'tributal tin oxide' which are different coloured coatings of a self polishing co-polymer paint
The TBTO is castenergic base that inhibits marine growth.......[moss or marine growth is killed and falls off]  >>:-( the different colour layered system is simply to allow maintainers to know the actual depth of paint remaining
I have seen colours ranging from the salmon pink that UBN notes to turquoise blue and lime green O0.....
These TBTO hull preservation systems saved $millions in unnecessary dockings & steam cleaning of the underwater hull structures both for above and below water vessels
Post by: webbo on December 24, 2016, 08:53:10 am
Many thanks for the quick replies . The plan up to now is Dark Grey Silky Matt or Granite Grey for the top of the hull and Fiery Red Silk Matt or Purple Red Silk Matt for the bottom ,Anthracite for the Bow area. Looking down at the sub from above no antifouling to be seen .Did also think about leaving the bottom a red primer colour.
