Mess Deck: General Section => Model Boating => Topic started by: merseyferry on February 28, 2017, 05:32:33 pm
what colour is below the water line on a hull, plans state red/brown.. is this a certain colour i could look up regards pad
Halfords Red Oxide Primer is as close as you can get.
Ron.
Might depend on what you are building. For steel ships Halford's Red Oxide primer is a pretty good match for commercial hull antifouling.
thank you ron,colin redoxide ill use :-))
Red/Brown is actually a Humbrol Enamel Matt colour - number 100.
Barrie
thank you barrie ill take a look
thanks again barrie humbrol :-) it is
hi there - the last couple of hulls I painted, I painted the bottom with Brick Red - Humbrol number 70 and when it was dry I gave it a coat of Satin Clear Varnish number 135. I know that John Haynes likes to use the same technique, but, he adds a touch of number 19 Bright Red into the brick red,. This brings the colour somewhere close of the hull red Humrol colour 177. Have a look on the paddle build I am doing and it will give you a rough idea of the colour.
http://www.modelboatmayhem.co.uk/forum/index.php/topic,57145.msg594482.html#msg594482
john
