The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Stan on July 08, 2017, 06:29:40 pm
HI Guys with the on going building work and me doing other things not a lot of building of models has taken place. This afternoon I managed to do a little on this next project first job to remove all raised mouldings in the hull. It may be a while before you see any more pictures need to finish the F/Boat first.
Stan.
Now this is going to be interesting :-))
Even at 1/200 scale that is a very large hull you have there sir.
Ah the brilliant Nichimo kit , had one almost 20 years ago and its a lovely model to sail
(http://trawlerphotos.co.uk/gallery/data/640/medium/DSCF000142.JPG)
(http://trawlerphotos.co.uk/gallery/data/640/medium/ijn-yamato-2001a.jpg)
I await further progress with interest Stan.
Thanks guys it will be while before you see any major progress. I have invested in some nice brass etch for this model and also some very nice brass gun barrels. Should be ok with the 1/200 mighty Mo.
Stan.
Good luck with the build Stan I'll be following this one :-))
I've got one of these - it's a big model!
Love to see another build of this rare kit.
Makes for a great model..... I was very. very lucky to pick a part built one up off E-Bay for a buy it now price of £10 a year ago..... yes £10 !!!!!!!!!!
All parts were in the box except the gold parts of the stand
Terry H
HI Guys sorry for no further pictures all modelling stopped at the moment due home improvements. Hope to be back with you in September.
Stan.
Just a small update. Prop shafts fitted also four drive motors into the hull. I am using a building adhesive to glue down the metal motor mounts. I have used this before on PT BOAT 596 with very good results may be more pictures tomorrow.
Stan.
Looking very very tidy Stan. I salute you for installing those without getting glue everywhere.
Any details, photos of construction of the props and shafts????
All the motors are fixed in place and tested. The prop shafts are made from the following Outer shafts are 1/8 dia brass and the inner shafts are 3/32 brass. The outer shafts enter the hull into a box section at the end of this is a round tube this is glued to the box section and a cap is fitted to the box section see pictures.
Stan.
Thank you O0 O0
1/32nd shaft clearance, yes, you then don't need bushes.
Looks really great :-)) :-)) :-))
After a nice break in sunny Florida I hope to start work on this model again later this week more to follow.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
fitting out of motors sped control almost done just a few picture. This model will not be a simple build the difference in moulding is very different from the trumpeter kit.
Stan.
Just a few pictures showing how many clamps are needed to hold the deck in position until permanent fixings are fitted. Timber braces will be fitted to keep the hull straight and decks will be held in place with magnets. Other picture shows connections to main rudder and auxiliary rudder both operate hopefully will improve turning circle. 40 FM radio fitted to this model 2 channels only rudder two ESC via mixer.
Stan
Only just started following this build Stan,as usual you are doing a grand job!
Hope shes not too heavy for you to handle matey,but looking forward to further progress as and when
Take care
Mick F
Bloomin impressive the pair of them! They are a tempting size for fitting out aren't they.
Looking good. I had one quite a few years ago, really wished I had kept it. Especially as now you can get upgrade parts. Looking forward to the build.
Just a update on this build. Old motors removed and new ones fitted poor RPM on first motors. Hope to test sail on Sunday.If all goes well model will be at Blackpool.
Stan
New motors fitted along with 2 channel 40 am radio two ESC and W tail marine mixer. All tested works fine 5amp fuses fitted in Action fuse holder drive battery 6volt 4 amp hr gel cell battery. Just a few picture showing new motors and all electronics's.
Stan,
Thanks for the pics.
Nice tidy layout no "rats" there.
Looking at the rudder linkage and wondering why the 'kink' in the line, strength?.
The reason for the offset in the rudder linkage is due to me not getting the servo in the right postion. Even with this offset it causes no problem with moving the two rudders.
Stan
Model taken to our home water for first sea trials no tests done due to the lead acid battery being flat silly me should have checked that last night more to follow.
Stan. :(( :(( :(( :(( :(( :((
:} :} :}well done stan looks the bees knees.
cheer alan
Hi guys you may be wondering why I have not posted any updates on this build and the Missouri plus the Whitehall. I have been laid up with a bad infection which has knocked me for six. Normal service will resume hopefully next week.
Stan :(( :((
Sorry Stan. A good day for the pond tomorrow! Hope to see you out
Get well soon Stan. All the best to you.
All the best Stan. There's a lot of it about at the minute.
Good job we have the ol mayhem Forum. :} It's very entertaining these days. There's no need to speak out loud without coughing.
Hi all back in the saddle. The model is wired up ready to show at Blackpool.
Glad to hear you are on the mend Stan.Please be sure to come over to say hello!
Mick F.
Update on this build. It is a very typical moulding from who knows when. It fits were it fits and misses were it misses I have had to fit timber braces into the hull to bring it back in line and I have joined the main deck sections together making a one piece main deck. Timber braces have been fitted to take out the bounce of the deck sections. The decks will be held in place using magnets.
Stan.
Will the magnets give a good seal and will you be using a rubber gasket at hull to deck seam? Nice work sir. Cheers... Dennis
Stan,
I almost got to meet you today,but I am definitely coming across to see you tomorrow.I know where you are matey!lol
Mick F
HI Dennis yes the magnets will pull down the deck into the hull. I terms of sealing the deck I will not be fitting any seal. Built this model many years ago when the decks were screwed down and it took very little water. After all these are static models and were never made for R C operation. Hope this helps.
Hi all update on the build. Gell cell battery confined to the redundant shelf not enough power to the motors. Mixer also removed going back to tank steering power to be supplied from a 7.4 volt lipo. Magnets removed from second deck section due to poor fit. This section will now be glued in place more to follow.
Stan.
Sunday morning a cold wind blowing down the lake not ideal for a plastic model. After removing the mixer and the gel cell battery and fitting a 7.4 volt lipo performance was much better. I have fitted the old radio that was used on the first build way back in 1992 and I intend to use the old Electronize controllers that came in kit form many years ago. Just one picture from this morning sorry about the glare on the picture.
just a few pictures from today. I have decided to fit the original 40 FM radio that was fitted in my first build of this model. The radio system was supplied in kit form when the T/X and R/X had been constructed it was sent back to Micron for calibration. Even now it works a treat. I know you will all be thinking what ugly looking thing but after all these years it is still doing its job. You may also see a battery change gone over to a lipo cell much better than the gel cell.
Stan.
Wow, awesome work! Dennis :-))
Hi Stan
What size props are you using ? great build thanks
I think they are 25mm pm sent also.
I can confirm the props are 25mm hope this helps more pictures to follow when the build starts again.
Hi Stan
Good thread and real nice build, appreciated the advice from you on my tug build which I'm still awaiting the power board to be looked at as just sent it back to Action., soon be on the water Also have a Revell corvette 1:72 I;m on with as well just got all bracing in place and electric layout. sorted, built a static one years ago which I'm just transferring all the superstructure over to a new hull I built and refurbishing.
Anyways been looking at a big ship and the trumpeter models and converting to RC, seeing your already on with one will hopefully be able to pick your brains on the running gear and how to set up 4 props. Seen a few as in bismark and Hood but come across the USS hornet aircraft carrier and all around 4foot long must be impressive on the water. Good to see a thread on these conversions and hopefully will have a model sorted next month.
Cheers Steve
Hope to be back on this build end of March.
Stan.
Hi Stan great thread. I have a slightly newer Micron set, mine came with the RF cct already calibrated, I enjoyed building the set as well, not used it for a while but I also run a Futaba Tx on 27 Mhtz FM and I favour the Micron rx's every time. I changed my rx's over to modern connectors a while ago. I have a few 27Mhtz FM crystals, do you have a source?
best regards,
Roy
Hi Roy my micron set is running on 40 fm not 27 fm
Stan
My fishing boat build is almost finished looking forward to starting this build again.
Stan.
With the fishing boat 99.99% complete I have started work again on this model but already I have hit problems. The build book states the plastic is ABS. I have tried solvent glues with no effect so I am now using superglue and UHU Acrylit for construction. The mouldings must be all types of plastic the funnel glued with solvent weld no problem. Pictures to follow or it may end up in the bin.
Stan. {:-{ {:-{ {:-{ {:-{ {:-{ {:-{
Hi Stan
Is this a trumpeter kit, have been looking to purchase one to convert as seen deans marine do a hood model, would you not recommend if that is the case, looks like you have all the hard work done installing the RC kit as well.
HI smyster simple answer the model is a very old kit made by Nichimo many years ago. The quality of the injection mouldings leaves a little to be desired compered with today's injection mouldings. The Trumpeter Hood makes up ok. I have enclosed some pictures of a club members Trumpeter Hood enjoy.
Stan.
Thanks for that Stan
Lot of money to spend out if the kits are not that good of quality, good to know there ok, excellent pics and just like the amount of detail that's included on a big model, thought they might be easier to build than the deans marine kits, its between the hood and the aircraft carrier model USS Hornet
Thanks Steve
The standard of Trumpeter kits is very high should have no problem .
Stan.
Must agree, Trumpeter is very good quality and worth the expense. Add the PE and you really have something. Cheers, Dennis
HI All I have finally found a glue to stick ABS. Plastic magic from Deluxe seems to ok. Hope to post some pictures later this week still working on getting the deck sections to fit better.
HI I have stared to work on this model full time now and what a challenge. The original model had the deck held in place with large screws and they did look the best. The challenge is to find a better way of holding the decks down. I have opted for magnets once again when they are all fitted I will post pictures. Two pictures one showing a small magnet holding down a hatch cover and one showing parts of the hull clamped to bring it back to something like.
Stan
Some more pictures showing the magnets that will secure the read deck sections. Further picture showing wood blocks and bracing the wood blocks will have brass m2 bolts fixed in them to hold the middle deck sections. The bracing will stop downward movement when fitting main superstructure.
Stan.
Stan,
Nice to see the wiring lay out done well, I'm a bit OCD at having the wiring loom looking neat and tidy.
Hope you have sorted out the issue you spoke about?
I forgot to post these last night two shots showing the main gun barrels. I have disposed of the plastic ones supplied in the kit and fitted new barrels from RB Models Poland.
Stan.
An old type of kit but a good subject , looking forward to seeing more of this build.
Bowwave :-))
Just a few pictures showing the metal gun barrels fitted in the plastic mounts. Final picture showing base glued into turret top.
Stan.
Well what seems like forever getting the decks to fit something like is very nearly complete. I have used magnets timber braces and finally brass road to pull in part of the hull to get a better fit. Now starts the fun of fitting a large amount of brass portholes . Just a few pictures showing final braces fitted into the hull.
Stan
Nice neat wiring!! :-)) :-))
Manage a little today this model is going to take some time all the plastic parts need a lot of time spendinon them. Just one picture today.
Stan.
Are you just going to stop with the metal guns? or splash out on after market etching kits?
HI Brass eth kit already and waiting.
That will be fun, have looked a couple of builds using PE.
Looking forward to your future posts.
Hi Collin the set for the Missouri is a mind blowing 18 frets so the 2 for the Yamato hopefully will be a breeze.
Stan.
Sorry guys will be no updates for a while busy with other things at the moment. I hope to have the model at the C A D M A show in June.
Stan. :(( :(( :(( :(( :(( :(( :(( :((
HI all this kit is driving me up the wall. It needs a lot of T L C some of the brass etch is not a perfect fit either. Just a few pictures showing progress may be finished by the end of the year.
Stan. <:( <:( <:( <:( <:( <:( <:( <:( <:( <:(
HI all just to let you all know construction is on hold at the moment. Just back from holiday and other things to do before building starts again.
Stan. :(( :(( :(( :(( :(( :(( :(( :(( later :-)) :-)) :-)) :-)) :-)) :-))
No I have not left all still on hold may be until early Autumn.
Stan.
Update on the build It is driving me crazy wish I had never started it. But we must persevere and hopefully all will come good.
Stan. :(( :(( :(( :(( :(( :(( :(( :(( :((may be in the future. :-)) :-)) :-)) :-))
Update on this build all stop at the moment suffering from summer man flu. I hope to have it on display at Haydock.
Stan.
At the moment not feeling the best. :(( :(( :(( :(( :(( :((
Get well soon Stan! :-)
HI All just to let you know the build is moving on but very slowly. I hope to have the model at Blackpool along with two others under construction pictures to follow.
Stan.
I have been watching this thread from afar Stan.Your build is coming along great.I have this kit part built and lost enthusiasm when various photoetch items didn't fit.I have since learned the problems arise with the gold medal photoetch in that Loren Perry designed the etch from the anatomy of the ship book as opposed to the kit.One problem area is the main turret handrails.The kit turrets are quite a way from where they should be and the rails need modifying to sit properly.
After a brief flirt with the idea to scrap the superstructure and build mine as Shinano,I will revisit the model and build her as Yamato in her final guise.My enthusiasm has been rekindled by Fujimi's kit of her main armament in this scale and also their December release of her fighting tower,which is accurate and more detailed.I have these on order as they are limited availability from Japan along with secondary turrets and 127mm aa armament from L'arsenal.Also I have ordered the additional etch from GMM for the vents and seaplane tracks etc.
It will be a long while before she is back on the bench,and I don't envisage her as being a quick build.
Nigel
You are right many parts of the brass etch do not fit.Have sent you a pm hope to hear from you more pictures to follow.
Stan.
Hi all I have not posted much over the last few months. Been busy with other things hope to get back in the frame next week.
Stan. :(( :(( :(( :(( >:-o >:-o
I Know how you feel Stan, looking forward to see your progress
Stan.
We miss you input Stan! O0
Missed you to Martin.
Stan.
Sorry not posting any updates on this build. But I now free time so hope make some progress on the build.
Stan.
Working on the four aircraft at the moment adding more detail to them will post pictures later this week.
Stan
Just a few pictures showing the Pete Bi plane and the low wing monoplane painted in white primer. More detail added the bi plane not to easy at 1/200 scale mode pictures when the are painted.
Stan.
Good lord! I like the struts and bracing.
Beautiful casting and assembly work sir. Dennis
Hopefully should be all painted next week will post some pictures.
Stan
sweet Stan :-))
Well three models revamped ready for the spring. I should be able to get back on with this build next week all been well pictures to follow.
Stan
HI Guys no I have not dropped off the planet just been busy with other things I hope to get back on this model shortly.
First pictures of the float planes and brass etch catapults. The crane still needs lots of work.
Stan
Very nice work. Is this a resin or plastic model? Photo etch is amazing for detail like this. She is a beauty. Dennis
The model is a 1/200 plastic kit.
Stan.
Would that be a Tumpeter kit? Very nice casting. !/200 makes for a nice large model. D.
HI No this kit was made many years ago by Nichimo needs a lot of work. The kit is now fetching silly prices.
HI Guys no this model is not in the bin just on hold.
Stan.
I ordered four new props for this model picked them up today from prop shop at the C A D M A model boat show pictures to follow.
Hi all now that I have finished a repair on a very old model I hope to start on this build once again. I will update this thread when building starts.
Stan.
Nice up grading of the Aircraft Stan.
Now back on this build.
Stan
Back to following your updates on this one now Stan
After doing a silly thing that resulted in me destroying two viper speed controllers I decided to use some electronize speed controllers. These pictures show the final power layout a voltage reducer is fitted to power the radio set at 5,5 volts. Other pictures show the motors and Huco motor couplings and finally the rudder connections.
Stan
Neat electrical installation work as always - I hope to be able to do likewise in future models.
Are those load resistors mounted on the aft end of motors? (I do not know what I am talking about, just curious)... tks, Dennis
Those are capacitors Dennis , they remove any rf interference they kick out and prevent a lot of problems with the RC gear ( or at least used to on 27Mhz and 40Mhz not used the current rc gear so can't say if this helps or isn't needed now )
Thank you sir, that makes good sense. Lots to learn and know when going RC. Dennis
I like those neat fuse blocks Stan, where did you get them?
Hi they come from Action model electronics.
Stan
Just done little today so hot in the garage even with the door and windows open. Just a few pictures showing the brass etch rails used to move aircraft. Fitting these certainly raises the blood pressure and a few choice words also.
Stan. 8) 8) 8) 8) 8)I wish 80 plus degrees
Nice work Stan, is each rail support "pinned" and glued to deck? Dennis
Simple answer Yes.
Stan
I hope to get back on this build full time next week. Since my last post time on this build has been nil.
Stan.
Still a long way to go but I have started to paint the hull and parts of the deck area.
Lots of masking there Stan but it looks a bit easier than my Elco ;) . I nearly used a whole reel of masking tape before I got it looking anywhere near right - still not perfect but its going to have to do.
Looking forward to following the rest of this build. :-))
HI a very neat model an I will be following your build an how long is the hull an beam width ?
chris
Hi - I've just dragged my Yamato out of the garage - lots of parts have come loose after many years - mostly styrene things glued to the ABS parts. What glue are you using and is it holding firm?
The hull bottom has now had two coats of varnish. When this is dry I will mask of the bottom area and spray the top half and any deck fittings. Once this all completed I should be able to fit the wood decks.
Plastic all the internal works have been glued using Stabalit Express.The brass etch and plastic parts I have used Loctite super glue.
Stan.
Cheers Stan - I'm ok with the internal stuff, it's the exterior details that coming loose. It's difficult to identify the individual plastics as they all look similar but some bits are ABS and others are styrene - so it's trial and error seeing if they fall apart after gluing.
Yes the plastics used in model leave a lot to be desired. Just a few pictures from today showing the lower now varnished and the aft deck note the brass etch platforms for the AA guns. Finally the centre deck section all the raised parts are now painted before the wood deck is fitted.
Stan.
LOOKS a crackin build Stan im enjoyin following this an did you see on the tv a program called draining the oceans as they found the real yamato wreck an it was very instresting in fact I think I will rewatch it
chris
Hi Chris yes I did see the program. The build will go on hold now need to get ready for Haydock hope to fit the wood deck next week more pictures to follow.
Hi Stan - you asked for a pic of mine - it's a much older version of the kit - it's a damaged model from ebay (£21) where all the details are broken off - the rear crane, radio mast etc. - it's almost all there (in little pieces), it just needs a bit of tlc to resurrect it. Notice mine only has 2 small turrets on either side of the citadel.
Just managed a few hours today centre deck section now fitted with wood finish. Some general shots showing other details. I hope to have all the wood on the decks next week.
Nice :-))
HI STAN wonderfull workmanship ive just sort of skimmed through your build so far but im so impressed with what you have done im gonna read all your build properly an this is a kit isn't it ? an do you get everything or do you have to buy extra's ?
chris
Chris
It is an old Nichimo? kit from long ago, the basic kit was what you would expect, crappy motor rubber tube as couplings, so knowing that you can see what Stan has done to it, truly amazing
Chris
Yea I totally agree with you Bob it is amazeing build an the kit when you say from long ago do they still make it to sell as I just whondered ?
cris
Stan - I have a couple of questions - mine is a fixer-upper and it needs new propellers - the original shafts are 2.3mm hard steel slid inside 4mm O/D brass tubes - and the moulded props look like they are just glued on - is yours the same? My props are all broken so what's your thoughts? Buy new M2 props & drill them out to 2.3 smooth? Rip out all the shafts and replace with new M2 shafts - but they would be 5.7mm diameter and I'm not sure there's enough meat to drill the shaft bearers out to that diameter? Any thoughts?
Hi Plastic sorry for the late reply. The shafts in my model are from prop shop the kit shafts were never fitted. I suspect the kit props were screwed on to the shafts.
Stan
Hi I have managed to do a little more today. Masked off the lower part of the hull and the internal electronics and motor bay then applied 3 coats of grey to the upper part of the hull. Also painted some smaller parts more pictures to follow when masking is removed.
Stan.
Top half now sprayed ready for varnish coat next week then fit the wood deck. Just a few pictures again from today.
Stan.
Awesome!
Hi Plastic sadly the props and shafts have long since been disposed of.
Ok - thanks anyway Stan. Cheers
Hi Stan it's John V You are doing a lovely Job..you are getting to clever in your old age .keep up the good work.cheers John V
HI John V they do say things mature with age. Thank for your comments I am still learning I have along way to go.
Hi Stan, Decking looks great
I hope to fit the last parts of the wood deck later this week more pictures to follow.
Stan
This morning I had to cut the forward section of the timber deck this will allow the centre section to be removed to gain access to the RC gear. Just a few picture showing how I did this and how the two parts marry up.
The wood deck is now fixed. I can now concentrate on the deck fixtures more pictures to follow .
Hi Stan it's John V decking is looking very good .keep up the good work .you are a master cheers John V
Have a message from Stan
His telephone line has gone down inevitably meaning no internet connection. He's still beavering away on the model and has more photo's but can't post them up of course. Needless to say he's not best pleased with BT but is hoping things will be sorted by Monday.
>:-o >:-o >:-o >:-o >:-o >:-o >:-o >:-o >:-o >:-o
The angry faces are not his idea but he does like lots of smiley's :-))
Oh dear.
Well, thanks for the update CJK, we'll just have to wait a bit longer for the updates :-)
Hi all just had a visit from a Open Reach technician and the problems is now resolved. Top marks for the engineer coming so late in the day.
Cheers Stan, that's great news :-)
Jus few pictures from Wednesday before the phone line went down. Picture show all the wood deck fitted and some close up shots of various deck fittings.
Love it :-)
Not a spot of glue or paint out of place :o . Are you using Photoshop Stan? ok2
Hi CJK no pictures straight from the camera on to the p/c. Then right click on picture then edit then resize then save has. All these steps are done using the paint program.
I knew you wouldnt be Stan :} , Photoshop is used by cheats to hide mistakes - you just don't make any by the looks of it. One day I might be as good. %)
Hi Guys just a few pictures showing the secondary turrets these are still under construction and not painted. I have made them removable by using magnets.
Stan.
I like that idea Stan - magnets and locating pins / holes - belt and braces, so to speak. :-))
Hi Capt Podge the magnets along with the locating holes works a treat.
HI all hopefully back on the build tomorrow.
Stan.
Now back working on this build painting most of the day pictures to follow.
Just a little work done over the last few days.
Very nice and clean sir.
I have just got back from my hols hope to restart work later this week.
Stan.
Hope you had a good holiday Stan. Looking forward to your new tricks with Yamato. :-))
Fantastic build so far Stan. :-))
Looking forward to seeing more on this one Stan and by the way, the chequer plate looks fantastic O0
Hi All back on this build once again pictures to follow.
Hi just a little done today. Magnets fitted to hold down main superstructure also fittings glued in place to keep anchor chains under tension.
Hi Stan,
A question if I may - are the anchor chain tension holders located somewhere under the focsle deck?
Just curious...
Hi Ray no the chains are quite long allowing the tension fittings to be fitted in the centre section. Plus easy to get too
Stan.
Ahh, yes, that makes perfect sense.
Cheers Stan :-))
Hi Stan, do like the magnet and pin idea.
Question, how are you going to seal/ water proof the wood decks
Hi T888 I have already tried thinned Humbrol varnish on a wood deck test piece with no problems. The edges will be sealed with thin superglue hope this answers your questions.
Stan
HI Guys once again only a little done today. Rear gun turret will be held place using magnets this will allow access to the radio on /of switch. Pictures show magnets installed and gun turret glued to its mount Other pictures are just general shots sorry about the mast picture. Hopefully it will be at Blackpool.
Hi all not much done this week getting ready for Blackpool.
Stan. :((
Now Blackpool show is finished I hope to concentrate more on the Whitehall having a break from1/200 scale.
Stan. :-)) :-)) :-)) :-)) :-)) not for long
Hope to be back on this next week.
Stan.
Just ordered from the U S brass etch cable reels and two rail hand rails.Not cheap but what the heck.
Stan. <:( <:(
Don't know about you Stan but I didn't start modelling to save money {-) {-) Its a lovely build and worth every penny!
This one will get some TLC next week.
Stan.
The first fix of the Amati kit is now finished so it is back to this model.
Stan.
Progress is slow on this model just a few pictures showing hand rails in gun tubs and rails to stop gun deflections.
Stan. 1/200 scale driving me %% %% %% %% %% %%
Beautiful detail work. Dennis
Hopefully back on this build next week or else.
Stan. <*< <*< <*< <*< <*< <*<
Just received today some 1/200 scale brass etch ladders I hope to get some time on this model on Monday pictures to follow.
Stan.
Things are hold with this build having a break from 1/200 scale but I hope to have finished for the model show at Doncaster.
Stan.
Hope you achieve your aim Stan and I hope to get to the show this year - I haven't been for years <:(
Hi Yamato here no my builder has not forgotten me needs a break from such a small scale.We will back later this year.
Yamato. <:( <:( <:( <:( <:( <:( <:( but will back :-)) :-)) :-)) :-)) :-)) :-)) .
Hi you may be wondering where I have gone. Should be back next month watch this space.
Stan
HI Guys i have not dropped off the planet just been doing non stop decorating. Hopefully I should be able to make a start on this build and have it finished by Christmas.
Hello Stan
Sold my Nichimo Yamato a couple of weeks ago... sad to see it go but the buyer was well chuffed.
Terry H
Again a model that has ben side lined but along with U S S Whitehall hope to have it finished in 2021.
My latest model hopefully will be finished in July then along with the U S S Whitehall we will be back on this build.
Waiting on the sidelines - patiently of course %)
Hopefully the Yamato will be back in build mode before Christmas.
Stan :-)) :-)) :-)) :-))
wot this Christmas. {-) bill
HI I never stated which Christmas. {-) {-) {-) {-) {-) {-)
