Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: 2772e on September 06, 2007, 07:05:41 pm
Title: TUG LED's
Post by: 2772e on September 06, 2007, 07:05:41 pm
Just had the LED lighting kit turn up for my tug from MMM.
I am right in thinking that the positive one is the longer spur, and the one the resister gets connected too?
Simon ???
Title: Re: TUG LED's
Post by: gribeauval on September 06, 2007, 07:15:56 pm
Yes!
Post by: 2772e on September 06, 2007, 07:21:26 pm
Thanks Mike, thats that the easy bit over with!
Post by: gribeauval on September 06, 2007, 08:06:07 pm
Just don't keep the soldering iron in contact for long,the led's object to too much heat!  8)
The results are worth it though, here is the mast for a small German lifeboat I am building, all led's ablaze! ;D
Post by: 2772e on September 06, 2007, 08:08:22 pm
How bright are they!!!!!
Is it one resiter per LED, where have you hidden the wires?
Post by: 2772e on September 06, 2007, 08:13:12 pm
And do you wire them one by one or in a daisy chain?
Post by: gribeauval on September 06, 2007, 08:19:40 pm
They aren't as bright in real life, it's the digital camera slightly over exposing as the picture was taken without any other light source.
I always use one resistor per led, I know it can be done in other ways but I am a great believer in KISS ( keep it simple stupid!!).
All the wires are inside the mast and exit from the bottom, the original fitting in the Graupner kit was solid plastic so I built a copy but hollow, all the negative leads are then joined into  a single wire and then each positive wire is taken to a switch bank and then to the battery to allow individual light control.
Post by: andywright on September 07, 2007, 10:49:08 pm
I use brass for masts, then solder negative to mast and make it negative return, it saves on wires in the mast, some mast won't take a +ve and -ve for each light any way, +ve go to individual switches. Negative to bottom of mast.
Andy
