Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: BreezyB on September 10, 2007, 12:41:08 pm
Being new to this electrickery stuff, can I use a Hitec sail winch (HS.785HB) with my Futaba T2ER set up??
Cheers. :-\
Yesno probs at all,I use one on one of my Yachts
Stavros, Many thanks for the help, that's good news. Barrie. O0
One thing I forgot to add was that if you are using a sail winch I would fit a ratchet clip[ to the stick that is being used for the sail winch available from most good model shops or do as I do just remove the spring on the relevant stick and away you go
