Mess Deck: General Section => Model Boating => Topic started by: Tim. S on March 14, 2018, 08:55:39 pm
Title: Radar
Post by: Tim. S on March 14, 2018, 08:55:39 pm
Hi all
i got this recently
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=112839733584&category=168248&pm=1&ds=0&t=1498939350000&ver=0 (http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=112839733584&category=168248&pm=1&ds=0&t=1498939350000&ver=0)
 but i cant get it to work using the TX (DX8) it works as i have tried a servo tester  but it wont work via TX when i try and set it working with the landing gear switch and ideas ?
Title: Re: Radar
Post by: C-3PO on March 15, 2018, 07:25:48 am
The landing gear receiver channel will output a 2 state signal - likely to be close to 1000ms or 2000ms in the two different switch positions
This may be outside the expected range of the board you have - is the board LED permanently on after startup?
To start with try putting the board on the throttle channel and use the throttle stick to see if that works.
C-3PO
