Technical, Techniques, Hints, and Tips => BRUSHLESS Motors and Speed Controllers => Topic started by: Gardener on June 09, 2018, 09:16:16 am
which crimp on connectors do you need to go into mtronics viper marine Speed Controller yellow and blue wires please?
I am looking for some crimp on connectors to fit that I can make up wires my self...
Where can you buy them ?
chocolate blocks of correct ampage. or deans plugs.....
do you realise you have this in the Brushless section? if the motor etc is brushless dont use chocolate blocks!
Bullet types as sold in most car spare shops, sized to match whatever you are fitting to the motor. Preferably male ones on the motor leads, receptacle on the ESC output leads to avoid accidental shorts. Easy to reverse the motor connections when you connect the wrong way round first try.
Come to think of it, all the Vipers that I have used come with receptacles ready fitted, just need the right size bullets on the motor leads. Bullets usually need soldering, but crimp types are available if reliability is not vital.
Sorted now Thanks
