Mess Deck: General Section => Chit-Chat => Topic started by: Baldrick on June 21, 2018, 02:13:44 pm
It may be a jumble but it is my jumble
(http://modelboatmayhemimages.co.uk/images/2018/06/21/20180621_133957.jpg) (http://modelboatmayhemimages.co.uk/image/Bl1BX)
Paaa! This what it Should look like!
(http://modelboatmayhemimages.co.uk/images/2018/06/21/35774449_2072424752825064_4687580113477304320_n.jpg) (http://modelboatmayhemimages.co.uk/image/BlPgT)
(http://modelboatmayhemimages.co.uk/images/2018/06/21/35765369_2072424726158400_8753335506084823040_n.jpg) (http://modelboatmayhemimages.co.uk/image/BlNXV)
(http://modelboatmayhemimages.co.uk/images/2018/06/21/35799338_2072424669491739_4861038595428843520_n.jpg) (http://modelboatmayhemimages.co.uk/image/Bl6LD)
(http://modelboatmayhemimages.co.uk/images/2018/06/21/35761530_2072424539491752_1556086876341796864_n.jpg) (http://modelboatmayhemimages.co.uk/image/BlyoM)
https://www.facebook.com/photo.php?fbid=2072424536158419&set=pcb.660457090959280&type=3&theater&ifg=1
What indexing system for cataloguing do you use Martin? {-) {-) {-) {-) {-) {-) {-) {-) {-)
Probably the same as mine, ie
If it's not in the workshop its in the shed, or the green shed, or the garage.
I know it's not in the spare bedroom cos I was in there this morning. etc.etc.
Not my shed but I'm guessing.... 'it's around here somewhere...!'
Hey, Baldrick,Where did you manage to get your EMCO drill stand?Tony :-))
Now that's a SERIOUS jumble Martin.
Respect! :-))
Martin's photos remind me of Richard Howard's Model Boat Museum at Beale Park which was stuffed to the rafters with a mixture of purchased and loan boats.
Does anyone know what has happened to the collection following his death, it was very much his personal hobbyhorse.
Hi Tony . It's actually a Unimat 3 set up as a vertical mill but with a change of milling chuck to drill chuck it makes a versatile drill press . I bought the machines some years ago and have just given all 3 a good overhaul and clean . Biggest problem is keeping corrosion at bay over the winter as even a waterproof shed can get a damp atmosphere during a bad winter . I have just bought some Ambersil corrosion inhibitor spray to see if this helps keep rust at bay
Oh my goodness Martin it looks like an Island after a hurricane has hit the coast {-) Thats the only other time I've seen boats stacked up like that {-)
Thanks Baldrick. Does the switch still work effectively because I've had to cobble together a replacement on my U3 lathe.
Tony
as was his garage, as well as radio control planes, boats there was a couple of interesting full-size car s (it was a garage after all ) . A rare 4 door Maserati if I remember in mafia black and a replica D type Jaguar, cant remeber the other one, too busy looking at the ship models, most with their own R/C transmitters.
Tony
Hi Tony.
Switch is fine , you can of course rotate the motor against the backplate so that the switch comes in a comfortable position.
Am I correct in reading that the switch on your U3 is broken ? If so I have a motor which is duff (Bearings worn out and commutator damaged) but the switch as far as I know is fine . If you would like it to use to repair yours with you are welcome, just squawk . Balders.
