Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: boxer on October 05, 2018, 09:23:00 pm
Planet t5 with correct receiver
20 amp viper marine mtroniks ESC
540 motor
Have used the planet t5 set up in club 500 now going into warship same set up
I know how to bind but need advice on how to fault find
Using multimeter
Battery is fully charged in transmitter and battery
Pressed button on receiver then turned on ESC no flashing as I usually get on ESC then transmitter on
Where to check next ?
Put the multimeter probes on a positive and negative pinout on the Rx, with the battery plugged in on a separate channel. Have you connected a servo in to see if you get movement there?
first off disconnect everything from the receiver. I NEVER mind when speed controllers are connected. second attach 1 x servo to rudder slot. 3rd put in bind plug in correct slot. 4th attach a 4.8v or 6v battery to any other slot tgen go through the bind sequence. this is the direct route. ensure all leads attached the rx are the correct way round before attaching battery! if you go through a speed controller and that has a fault you can be head scratching! if when you attach the battery it flashes all is well. bind it. if when you attach the esc tgen tgen esc is blown.
No movement on servo, just red light on ESC
Turn on esc then bind button then transmitter.
Red light on esc signifies no signal.
