Mess Deck: General Section => Beginners start here...! => Topic started by: g4yvm on November 10, 2018, 10:58:56 pm
I've just been perusing the plan for my Breeze (got to start somewhere) and most of it makes sense, but all my 40 years of modelling has been on planes, so I'm working hard to keep up.
Its probably easier if I add a photo of my question tomorrow, but has anyone built Breeze? A pilot cutter. My question is about quite how the bulwarks mate to the fibreglass hull...do they sit atop or alongside and extend above?
David
I don't know your model, but I'd suspect the hull is the hull and, once decked, the bulwarks are situated just inboard of the deck edge planking, extending upwards.
Do a Google search on pilot cutters - it'll probably make more sense than my opening sentence!
Belay that comment! Is this the Sarik plan? That appears to show the bulwarks outside the decking's margin planking, and inline with the hull surface. There's a wee gap between hull side and bulwarks for the water to get out, the bulwarks being held in place by those square posts. And on the 'chainplates' drawing there's evidence of wood fillets showing the bulwarks and hull surface inline.
Andy
Check the dimensions of the hull moulding against the plans. You may well find that the moulding incorporates the bulwarks . The deck will be set down from the top of the moulding and located and supported by a timber batten (typically 6mmx6mm ) to be bonded to the inside of the hull moulding.
This is breeze with the bulwark planking removed when at Porlock Somerset.
.[size=78%](http://modelboatmayhemimages.co.uk/images/2018/11/11/06Breeze-6.jpg) (http://modelboatmayhemimages.co.uk/image/J6Qx5)[/size]
Thanks.both.
The profile section seems to show bulwarks and hull inlime, but the plan section shows them overlapped.
Im in a rush now but will study that photo and also show you the plan.
David
OK here's the detail of my Breeze plan.
If you read the photos you'll see that the plan shows bulwarks and deck glued face to face whereas the sectional pic which shows the chain plate fixing seems to show both deck and bulwark one on top of the other. Which is it???
Also, those posts which fix the bulwarks on (sorry, I cant find the name for them)...why are they in two pieces - the thin piece and the square section? Cant I use one and rebate it and anyway, what does the rebate fit over? There's nothing there that thick.
And finally for today, the topping lift is shown in detail but I cant see where it fits on the vessel.
All help appreciated
David
OOps, important pic missed... this shows the bulwarks against the hull moulding.
D
Anyone?
Hi David - I guess you have built your Breeze cutter by now. I am looking at the same plans (prior to buying the hull) and have the same question about the bulwark/ hull joining, the section through for the chainplates is not clear. Did you have to cut the drain slots, which must be level with the deck, through both glassfibre hull & ply bulwark. Any advice would be welcome, I have built some kit boats but this is first scratch build. Does the finished boat sail well.
Thanks in anticipation
