The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Rob47 on December 16, 2018, 07:22:48 pm
Title: CVA-01 HMS Queen Elizabeth
Post by: Rob47 on December 16, 2018, 07:22:48 pm
Picked this up yesterday from John V, going to be finished as the above, lots already done so tweaks here n there.
https://www.modelboatmayhemimages.co.uk/image/JivBw
https://www.modelboatmayhemimages.co.uk/image/JiGxo
https://www.modelboatmayhemimages.co.uk/image/JiiOK
Title: Re: CVA-01 HMS Queen Elizabeth
Post by: johnv on December 17, 2018, 02:27:51 pm
Hi Bob it's John V looks good set up in your garage .Hope you make something of it .I now you have got a bit to go .But it needs some one like you to get it up and running take care have a good Christmas John V
Post by: Buccaneer on December 19, 2018, 07:44:53 pm
Hello Bob
I am very interested to see the pictures of CVA 01. Had things turned out differently that could have well been my home during the late 1970's to 1980 something. I can recall, (just about!) the day in 1971 or72 I believe when all the Buccaneer Aircrew at Lossiemouth were summoned together to be told that all the Carriers would be scrapped by the end of '72 or '73. We all made our plans on using our redundancy money and I was all set to go to a technical college in Oxford to study Cartography. A while later it was announced that Ark Royal was to be extended until the end of 1978 so I was required to stay on. My apologies if the dates above are slightly incorrect but it gives the picture.
Keep the pictures of the build coming as I am very interested to see what CVA01 would have been.
Post by: Rob47 on December 19, 2018, 10:18:05 pm
Thanks for that, my plans for her are, ballast trials (hopefully) Saturday, then it is to work on the parts I wish to modify, will be diving into the island late Jane once the NMM drawings are scanned and in my position,  as things go I will start a build log. Were you WAFU or another branch? I ask as trying to get accurate info on what lights on the flight deck, the model has leds in the deck but unfortunately they run right into the catapult area so will need modifying..
Thanks for your interest and here is a shot of her in refit at the Gloucester dockyard (my garage)
(https://www.modelboatmayhemimages.co.uk/images/2018/12/19/IMG_4098.jpg)
Post by: johnv on December 20, 2018, 09:39:32 am
Hi Bob looks good .I am so glad you can make something of it .I hope it gives you a good start .At least you can do it as you want .Looks good in garage .Have a good Christmas .Keep in touch Cheers John V
Post by: KitS on December 20, 2018, 09:39:59 am
Must have been fun getting her through Sharpness Docks and up the Canal.  :-) ok2
Post by: johnv on December 20, 2018, 01:38:37 pm
Hi kits it's John V hope you are doing ok have a good Christmas .I see we are all looking forward to see this aircraft carrier going back together .He will do a grand job cheers John V
Post by: Rob47 on December 20, 2018, 03:43:50 pm
Bit of a squeeze {-) {-)
Post by: johnv on December 20, 2018, 05:19:24 pm
Hi Bob it's John V if you go on website it shows the two catapult's are just off center of runway lights Cheers John V
Post by: Buccaneer on December 20, 2018, 07:16:27 pm
Hello Bob
Yes I was a WAFU, whichever meaning you wish to choose! I was a Buccaneer Observer and served on HMS Eagle and HMS Ark Royal from 1969-1978.
I wouldn't like to trust my memory too much for details of the flight deck lighting but you must remember that when launching or recovering aircraft virtually the whole of the flight deck would be in use for one function or another and lit appropriately. So when night flying different lights would be in use for either function and with space short areas in use would effectively overlap. Any questions please ask and I will do my best but I suspect that Google will come up with as much as I can.
Don't forget the 'Donkeys Plonk'. this was a vertical pole with red lights on that ran vertically down at the stern of the ship below the landing centre line. If you were lined up correctly it formed a straight line with the centre line lights but if you were offset to one side and approaching at an angle it formed an angle with the centre line lights.
Good luck with the build.
Post by: Rob47 on December 20, 2018, 09:45:55 pm
Cheers John
Buccs you lucky man, just finished the Buccaner boys, great read.
Yes will pick you brains once all the plans are in place, it will not be 100% all deck light but the major ones, that will be visible for the public to see.
Really hoping she gets wet this Saturday, will post if she does.
bob
Post by: littoralcombat on December 21, 2018, 10:24:05 pm
What scale is she Rob?
Nige
Post by: Rob47 on December 22, 2018, 04:38:18 pm
1/96 mate
Post by: Rob47 on December 22, 2018, 04:46:58 pm
Well I will keep this going as the rebuild log of QE.
Today she was launched for ballast trials and passed with flying colours, only needing two 5kg batteries and about 4kg of lead in the bow, only issue was after a while she began to take on water, rather quickly, source was one of the A frames which have been bolted in with a washer then body filler, had deteriorated, very much like a lot of the glue, has become brittle, nothing to worry about as she now will go through the fitting out process, three shots of her afloat and one showing the removal of prop shafts and rudder, to relocate them in correct position and correct angle.
(https://www.modelboatmayhemimages.co.uk/images/2018/12/22/IMG_4108.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2018/12/22/IMG_4107.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2018/12/22/IMG_4105.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2018/12/22/IMG_4106.jpg)
Post by: johnv on December 22, 2018, 05:39:51 pm
Hi Bob it's John V looking good on water glad everything went well cheers John V
Post by: Rob47 on December 24, 2018, 04:43:18 pm
Just a single update, all the rudders and prop shafts removed, next phase will be a fresh coat of fibre glass to seal the gaps, then new shafts and rudders fitted at correct distance and angles.  it looks like a butcher job, but not as bad as it seems.
(https://www.modelboatmayhemimages.co.uk/images/2018/12/24/IMG_4113.jpg)
Post by: derekwarner on December 24, 2018, 08:41:13 pm
Rob...if you choose a small sheet of chopped strand glass mesh, you will never see the final repair   :-X ........Derek
Post by: dlancast on December 31, 2018, 04:19:26 am
Its great to see a CVA out on the pond.  Your project is coming along nicely and I will be watching for further posts.  I served aboard  the USS Ranger CVA-61 in 1969.  Sad that the old lady is now scrap.  They tried to save her, but funding just was not there.  Many of the old Forrestal Class carriers are gone now.  I'm working on the USS Intrepid CV-11.  An Essex class carrier in the beginning, but modified with the first angle deck and steam catapults for the US Navy.  I'm really enjoying this build, great design and will be most interesting when completed.  All my ship models are entombed in glass cases.. perhaps one day I will try RC and sail one.  Cheers, Dennis
Post by: Rob47 on December 31, 2018, 04:00:07 pm
Thank you very much Dennis, much appreciated
Post by: Rob47 on December 31, 2018, 04:04:03 pm
Today, fibre glassed the area that had all the running gear removed, then added filler, ready to rub down, next will be marking the holes for the new locations of rudders and A frames.
(https://www.modelboatmayhemimages.co.uk/images/2018/12/31/IMG_4128.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2018/12/31/IMG_4129.jpg)
Post by: Capt Podge on December 31, 2018, 05:02:47 pm
I wonder whether Her Majesty would be amused by the way her name has been spelt - see thread title - surprised no one has picked up on this before now... <*< {-) {-)
Post by: DavieTait on December 31, 2018, 05:08:35 pm
Isn't it how Philip pronounces her name after he gets his new false teeth lol
Post by: Rob47 on December 31, 2018, 09:28:56 pm
Well spotted Wilson , wonder how long it would take you. If you can explain how to amend please explain
Post by: DavieTait on December 31, 2018, 09:51:26 pm
Needs one of the moderators or Martin to change it Rob
Post by: dougal99 on December 31, 2018, 10:11:18 pm
Done  :-)) :-)) :-)) :-))
Post by: Rob47 on January 01, 2019, 01:18:05 am
Ah thanks for that
Post by: Martin (Admin) on January 01, 2019, 10:33:28 pm
Sorted!  :-))
Post by: Rob47 on January 02, 2019, 10:35:21 am
Post by: Rob47 on January 05, 2019, 01:10:16 pm
Well now the major issue of the name is sorted, latest bit of update
First coats of anti foul added, prop shafts, tubes and A frames on order along with brass bolts to secure the three rudders.  So should be able to look a bit more like a carrier hull soon.
(https://www.modelboatmayhemimages.co.uk/images/2019/01/05/IMG_4169.jpg)
Post by: Netleyned on January 05, 2019, 01:34:37 pm
Post by: raflaunches on January 05, 2019, 08:24:50 pm
Starting to look very ship-shape and Type 82 fashion!!! :-))
If you get my drift... ok2
Beautiful work Rob.
Post by: johnv on January 06, 2019, 10:19:24 am
Hi bob it's John V it's looking good .What motors are you going to use .Looks very big on your bench .Keep it up you are doing well . Looking forward to seeing more pics cheers John V
Post by: Rob47 on January 06, 2019, 03:00:52 pm
Using three smith fan motors, same as the two that came with her
Post by: Rob47 on January 06, 2019, 03:01:29 pm
Beautiful work Rob.
Thanks and yes nice drift :}
Post by: Netleyned on January 06, 2019, 03:32:33 pm
Not bad for a Tonka Tinkerer :D
Beautiful work Rob.
Post by: Rob47 on January 09, 2019, 05:37:01 pm
Started to modify the rudders, so they show correct profile, one done, two to go, hopefully running gear here soon so can crack on with that.
(https://www.modelboatmayhemimages.co.uk/images/2019/01/09/IMG_4173.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/01/09/IMG_4172.jpg)
Post by: ballastanksian on January 09, 2019, 09:38:56 pm
Was the island so far over to allow fitting of anti air missiles etc along the outside?
Post by: johnv on January 10, 2019, 12:24:42 am
Hi it was set inboard so that could park more aircraft up on deck .A good idea .It keeps runways clear cheers John V
Post by: Rob47 on January 10, 2019, 10:00:06 am
It also allowed continuous flight deck ops, as a/c could taxi around  side of island, to either be struck down using side lift or ranged on stbd cat.
Post by: ballastanksian on January 10, 2019, 07:47:00 pm
That is very clever. It has echos of the flying bridges that allowed aircraft to be moved from the landing platform to the take off one on HMS Furious before she was refitted.
Post by: Rob47 on January 21, 2019, 03:20:44 pm
Well prop shafts aee here, so that means braving the cold to fit them  {-)
Today I removed the portion of hull covered by white tape, this is to allow the lift to be able to descend to its correct level.  As built there was no room to allow the underneath lift platform supports, the edges will be plated in and contain the lift mechanism.  It brilliant having the drawing to work from, especially as she is a "what if" type build.
I think another might be on the stocks as someone else is buying the drawings, so maybe we will one day have CVA-01 HMS Queen Elizabeth and CVA-02 HMS Duke of Edinburgh which was the listed name.
(https://www.modelboatmayhemimages.co.uk/images/2019/01/21/IMG_4177.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/01/21/IMG_4176.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/01/21/IMG_4175.jpg)
Post by: Rob47 on January 30, 2019, 11:06:57 am
Todays update, managed to fit port prop shaft, propeller and A frame, also had a visitor Gannet COD came to take a peek :}
(https://www.modelboatmayhemimages.co.uk/images/2019/01/30/IMG_4197.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/01/30/IMG_4195.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/01/30/IMG_4196.jpg)
Post by: Rob47 on January 31, 2019, 11:03:56 am
Port rudder added, and yes I know its at an angle but that's how they were to be, apparently it was easier to follow the contours of the hull, and it worked on the test tank :}
(https://www.modelboatmayhemimages.co.uk/images/2019/01/31/IMG_4198.jpg)
Post by: Capt Podge on January 31, 2019, 12:31:02 pm
May be that the angled rudders help with vessel stability? Just a thought...
Ray
I
Post by: johnv on January 31, 2019, 11:30:20 pm
Hi it's John V it's looking very good and well laid out just how it should be cheers John V
Post by: derekwarner on February 01, 2019, 12:31:12 am
Certainly allows for propeller removal, then the full withdrawal of the propeller shafts with sufficient clearance of the P&S rudders..........
Rudders can be removed in drydock, however if clearances are an element of the design saves huge amounts of Funds $$ during docking tasks
Our Australian Navy DDG's with twin shafts and offset rudders provided sufficient design clearance for propeller shaft withdrawal
Our Australian Navy FFG's with a single shaft and centralized rudder required rudder removal to facilitate propeller shaft withdrawal
Post by: Rob47 on February 06, 2019, 10:55:14 am
Recently decided to start work on the various weather decks, but felt something not quite right, checked the plans, and shock horror!! they had been cut out in the wrong locations.  Now some would say, does it matter, she was never built, who will know, well I would and I have the plans so no excuse, also I think there is a flurry of interest in the class so, got be as right as could be.  Images show as is now, then the paper templates marking correct locations and size.  Blanking plates have been formed and will be fixed in, then filler applied and once all that is set and rubbed down out with the Dremel and diamond cutting disc, its all great fun really.  :} :} :}
(https://www.modelboatmayhemimages.co.uk/images/2019/02/06/IMG_4217.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/02/06/IMG_4216.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/02/06/IMG_4215.jpg)
Post by: Rob47 on February 07, 2019, 11:17:44 am
A few shoots showing the amount that had to be altered, the real cheek gripping gap to cut was the very large one for the RAS station, looks dramatic but a lot of fairing in to do, that it for today as temp dropped a bit.
(https://www.modelboatmayhemimages.co.uk/images/2019/02/07/IMG_4220.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/02/07/IMG_4219.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/02/07/IMG_4218.jpg)
Post by: Rob47 on February 27, 2019, 10:44:52 am
Most of the starboard, weather decks complete, so time to start on the new island.  This is all built from plasticard, for lightness, and ease of working.
Parts are only lightly tacked for the pictures, as more internals and wiring to be done yet.  The Broomstick radar dome is only at the roughing out stage, but it is a huge item, scheduled to weigh 9 tonnes,
(https://www.modelboatmayhemimages.co.uk/images/2019/02/27/IMG_4244.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/02/27/IMG_4242.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/02/27/IMG_4243.jpg)
Post by: Capt Podge on February 27, 2019, 11:58:40 am
Well impressed with those window cut-outs. I know from experience just how difficult they can be to get right - great job so far :-))
Ray
Post by: raflaunches on February 27, 2019, 07:54:56 pm
Rob
Wow, your plasticard workmanship is stunning. When I first glimpsed the pictures I thought it was a 3D printed item but how wrong was I! Beautiful sharp edges and very clean work. Keep up the excellent work. :-))
Post by: ballastanksian on February 27, 2019, 11:09:39 pm
Any major alterations are cheek clampy but also exciting to do and finally, it gives you that warm fuzzy feeling when done. I always agonise over whether the previous owner would be grumpy over converting their model, but I work on the principle that it has been passed into your hands and you are responsible for renovating and updating. We all aspire to work as good as some others and sometimes it takes another person to realise that aspiration.
She's looking good Bob  :-))
Post by: Rob47 on March 10, 2019, 10:57:29 pm
Weekends work, stripped the flight deck, filled all the LED holes, marked and drilled new holes for LED. Masked the deck for painting, quite pleased with the result.  Next task is to wire in the lights.  This all based on a new plan that was the final drawing before acceptance.  Only nine landing lights required and all in a straight line.
(https://www.modelboatmayhemimages.co.uk/images/2019/03/10/IMG_4248.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/10/IMG_4247.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/10/IMG_4246.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/10/IMG_4245.jpg)
Post by: johnv on March 11, 2019, 04:38:06 pm
Hi bob it's John V i can see it's all coming together nicely cheers John
Post by: Rob47 on March 13, 2019, 02:14:54 pm
Thanks John, much appreciated, having new drawings is helping heaps.
Post by: Rob47 on March 13, 2019, 05:59:17 pm
Flight deck markings added, now ready to wire the lights up
(https://www.modelboatmayhemimages.co.uk/images/2019/03/13/IMG_4249.jpg)
Post by: Rob47 on March 15, 2019, 09:06:53 pm
More work on the flight deck, showing the method of wiring up, and the lights lit, also the start of the lift and hangar area
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4260-Edited.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4258.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4257-Edited.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4256.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4255.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4250.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/03/15/IMG_4251.jpg)
Post by: Capt Podge on March 15, 2019, 09:15:14 pm
That's a great job you've done there Bob and those night shots look fantastic - looking forward to seeing this model coming together  O0
Ray
Post by: dlancast on March 15, 2019, 09:58:49 pm
Wow! :-))
Post by: Rob47 on April 05, 2019, 08:13:48 pm
More work on the island, still cant get over the size of the Broomstick radar dome
Glazed some of the bridge and flyco, tinted green for top of bridge and all flyco, these window were actually made for her as well,
(https://www.modelboatmayhemimages.co.uk/images/2019/04/05/IMG_4289.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/05/IMG_4290.jpg)
Post by: dlancast on April 05, 2019, 08:45:01 pm
Very nice. What method did you use for tinting?  I noticed pic on table of two in uniform.  Is that you?  Best regards,  Dennis
Post by: Rob47 on April 06, 2019, 08:07:43 pm
Thank you
The tinting is green transparent plastic
The ones made for were green panels so seems accurate. As she was never built built wonder
happened to them
Ref picture yes it’s me as CPO my partner just ha military look coat, although she has served
Post by: dlancast on April 06, 2019, 09:11:20 pm
Thank you for your service sir as well as your partner.  I served with the US Navy as a Second Class Petty Officer Radioman, Midway Island, Vietnam, finished with the USS Ranger CVA-61 (now scrapped, rest her soul).  Build on... you are doing fine work.  Dennis
Post by: Rob47 on April 11, 2019, 05:07:43 pm
Thanks Dennis, much appreciated
Post by: Rob47 on April 11, 2019, 05:13:25 pm
The power house installed and runs as sweet as you could wish for, and also the rather nice name plate.  If anyone would like this style of nameplate google "Foreverjack"and they are in there.
(https://www.modelboatmayhemimages.co.uk/images/2019/04/11/IMG_4294.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/11/IMG_4293.jpg)
Post by: johnv on April 11, 2019, 08:15:25 pm
Hi bob its all looking very good .new you wear the man for it .I now it's been a challenge .and I hope you are enjoying doing it .it's so nice to see it coming to gether .at least you know you. have the only one that's up and running .keep up the good work cheers John V
Post by: johnv on April 23, 2019, 10:01:32 pm
Hi bob keep looking for you to put up some more photos cheers John V
Post by: Rob47 on April 26, 2019, 09:07:45 am
Next week John with bit of luck, waiting for some parts
Post by: johnv on April 26, 2019, 09:22:50 am
Hi bob thanks for all you have done to save the ship .at least it will now be built after all these years like it shoud have been only in  a smaller size cheers John
Post by: ballastanksian on April 27, 2019, 07:46:41 pm
The bridge is nice. I like the multi view windows as well as the radar dome. It looks so big, I wonder if the designers borrowed St. Pauls!
Re the green screens, I reckon as it was glass they either binned them or perhaps sold the glass as scrap for reuse in the glass industry. Probably the former given the era we are talking about.
Post by: Rob47 on April 28, 2019, 10:14:10 pm
Just fitted the rd over white over red
unable to manoeuvre ship at flying stations lights. Later this week is buttock clenching time when I have to
cut to grooves into the flight deck to take the catapults. Hangar lights are in and working
Post by: Akira on April 29, 2019, 12:40:28 pm
Wonderful job of fitting the Queen to her new gown. It will be most exciting to see her underway in her element.Jonathan
Post by: Rob47 on April 29, 2019, 03:04:08 pm
A few images to show her current state, before an enforced break of two months (allegedly) to keep my publisher happy, sure  I will sneak bits in
Started to fit the bridge wipers, fiddly job, will hope to get catapult tracks fitted thought this week.
On deck we have the COD Gannet from HMS Hermes on the Starboard cat and a Phantom on the port cat. other aircraft are parked awaiting their turn, first of the crew members can be seen in front of the island, only about 35 to paint.  steering servo and linkages are in and work, despite the angled outer rudders, now awaiting a replacement prop from Cornwall models. showing unable to manoeuvre lights due to flying stations, island floodlights on as are deck landing lights and hangar.
(https://www.modelboatmayhemimages.co.uk/images/2019/04/29/IMG_4320.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/29/IMG_4319.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/29/IMG_4318.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/29/IMG_4317.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/29/IMG_4314.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/04/29/IMG_4316.jpg)
Post by: johnv on April 29, 2019, 04:11:16 pm
Hi bob its John V it's looking great .I now you have a lot to do yet .but I can see you are getting there .when your done I will have to buy it back .cheers Bob keep up the good work cheers John V
Post by: Rob47 on April 29, 2019, 11:14:15 pm
 :} :} :} :} :} Start saving John
Post by: ballastanksian on May 07, 2019, 10:58:26 pm
I have just noticed the funnels Rob. What an interesting arrangement! Was she CODAG or Steam and Diesel?
The coterie of aircraft is a good detail to see attended to  :-))
Post by: Rob47 on May 11, 2019, 07:25:00 pm
She would have been three shafts Steam turbine, very good layout as each propulsion area would have been enclosed in its own splinter proof setting, thus giving max chance of at least one unit surviving an attack, the rudders were arranged similarly, each one had its own independent steering machinery so it could be used in event of otherers being lost.
Post by: Rob47 on May 11, 2019, 07:28:02 pm
Port catapult track fitted and forward lift cut out
(https://www.modelboatmayhemimages.co.uk/images/2019/05/11/IMG_4332.jpg)
Post by: Rob47 on June 07, 2019, 05:50:57 pm
No to much done due to finishing a book for publisher.
Trying to bring the hangar to life, very slowly, the wires are for the lighting to be sorted soon.  (JohnV) can you recall how much smaller this area was originally  :-))
Major decision taken in that the deck will stay as a whole section and secured by hidden screws , looks ok so far.
(https://www.modelboatmayhemimages.co.uk/images/2019/06/07/IMG_44568cd55fb1feca268d.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/06/07/IMG_44582f5c5aa9ca4bc5c7.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/06/07/IMG_4457e2d68d377d5290e2.jpg)
Post by: frogman3 on June 07, 2019, 08:24:41 pm
HI Bob very nice build an its great to see another person fittin in leds lights on the ship I will be following your build great stuff this
chris
Post by: johnv on June 09, 2019, 03:37:31 pm
Hi bob its John V my old aircraft carrier looking grand .I am so pleased you took it on can you put some picks up of the rudders in side hull and motors when you get a minute.and have you got top side of the deck done .I can see you are getting on with it cheers John V
Post by: Rob47 on June 09, 2019, 06:03:32 pm
 as requested, shot of motors and the tiller arrangements
Bob(https://www.modelboatmayhemimages.co.uk/images/2019/06/09/IMG_4461.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/06/09/IMG_4460.jpg)
Post by: johnv on June 09, 2019, 07:16:33 pm
Hi bob its John V I can see it's going to move a 9 foot aircraft carrier and buy the look it's going to turn well .have you though about a bow thruster for tight turns .don't forget I want to be there for the big launch .you should be proud of yourself you are doing a lovely job cheers John V
Post by: Rob47 on July 18, 2019, 05:22:58 pm
Well not posted for a while, so here is latest offering, fitted (temp) the starboard chaff launcher, makes a difference, next big job will be making her travelling box, which starts next w/e, this will mean I can get her wet and ballasted properly, unlike last time having to contend with several leaks.
(https://www.modelboatmayhemimages.co.uk/images/2019/07/18/IMG_4689.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/07/18/IMG_4690.jpg)
Post by: johnv on July 18, 2019, 09:57:35 pm
Hi bob its John V lovely details coming on great looking forward to finishing paint work and water test cheers John
Post by: Rob47 on August 03, 2019, 12:23:07 pm
Now for something different but still CVA-01,, as she is just over 8 foot long, it does not fit in car, so obviously wish to transport to sail so options
1/ new car, not really going to happen
2/ trailer, possible but adding up the cost of trailer, bracket, wiring and fitting, again not happening
3/ a coffin on the roof rack, way to go.
It is built as a complete flat pack box, load base onto the rack, then load Lizzie, then the panel are screwed on and finally a waterproof cover covers the lot.  It works well in trials and as she is only a foot high, its going to work.  The grey paint in the image is pussers weather works grey supplied from paint store HMS Illustrious  :-)) Just thought it might help others with bigger models
(https://www.modelboatmayhemimages.co.uk/images/2019/08/03/IMG_4878.jpg)
Post by: frogman3 on August 04, 2019, 01:12:21 pm
Comin on well you got some great ideas Bob  :-)) lookin forward to seein more of your work an her bein worked on are you havin workin aircraft elevator's
Bob ?  an that wheatherworks grey is it in a spray can or brush on an how much is the paint ? because as you know Bob im building a big tiger an if paint is cheaper ?
chris
Post by: Rob47 on August 05, 2019, 11:36:30 am
Chris the answer to your paint question is the post accompanying the  :-)) :-))
Post by: Bob K on August 05, 2019, 02:23:46 pm
I had a similar problem with my HMS Agincourt, although a foot shorter than yours there was no way I could get it into my small car.  Trailers are not allowed at Black Park, where there is also a 1.8M height bar on the entrance which rules out top boxes.
In the end I cut the hull in half, using sliding telescopic stainless tubes between the hulls and an HD toggle latch as a central clamp.
Bob K
Erroneous link removed - Admin
Post by: Rob47 on August 05, 2019, 02:37:41 pm
Hi Bob
yes followed that build, works for you but not a great fan of split hulls, so this seemed the way, all trials seem positive so fingers crossed.
Post by: BrianB6 on August 05, 2019, 11:45:47 pm
One Task Force 72 member that i know bought a second hand ambulance for his Ark and Lusty.
Both are on racks on one side and he has a bed and drop down bench on the other side.  :-))
Post by: Capt Podge on August 05, 2019, 11:58:06 pm
I'd love to see any available photos of that setup.
(thinking ahead to upcoming retirement)  ;)
Post by: BrianB6 on August 06, 2019, 05:49:12 am
I will if possible.   It will depend on when we next meet
Post by: johnv on August 27, 2019, 09:07:57 pm
Hi bob its John V stop keeping us all in the dark .we are all waiting to see more picks .on how things are going with project cheers John V
Post by: Rob47 on August 28, 2019, 03:28:43 pm
At the moment, commencing fitting the fuse box and wiring, once that is done it is time to make the antenna that fold away, once that's done a video of it all working will be posted.
Post by: johnv on August 28, 2019, 05:52:47 pm
Hi bob its John V there's a lot of people on hear all waiting in anticipation .it sounds you are nearly there. Hope you have enyored the challenge because if anybody now's it's me cheers John V
Post by: warspite on August 28, 2019, 06:07:46 pm
and using an old ambulance means there is a special place for the defib when the weight of the model overcomes the modeler, though using the gurney for an ambulance may be a way of transporting it to the waters edge.  :P  and the modeler back after succumbing to the weight
Post by: Rob47 on August 29, 2019, 09:19:52 am
 :D :D :D
Its not that heavy, more unwieldly, all weight is added once in the wet stuff, transport from the car to water is, by means of a garden trolley with nice pneumatic tyres, easily lifted onto roof of car, in actual fact my HMS Bristol and Tiger are more awkward to move around.  This is a fun hobby is it not  ok2 ok2
Post by: Bob K on August 29, 2019, 09:38:20 am
I solved my seven foot HMS Agincourt by cutting in half.  Each half is self contained and thus able to carry its batteries etc so no need to mess around knelling to fit and wire up batteries.  The two halves are joined by sliding telescopic stainless tubes, with a single toggle latch to secure.
It may sound extreme but is surprisingly easy to maneuver and get into my small car with the halves side by side.
Post by: Rob47 on August 29, 2019, 11:02:41 am
Hi Bob
Used that method for my Victorious and to be honest hated it, it all fits in the car but just don't like split hulls, with Elizabeth, once at waters edge drop batteries in connect to fuse box, fit flight deck and job done.  At end of day its what suits each one of us and also fits out capabilities.
Post by: Rob47 on September 04, 2019, 09:40:51 am
Couple of short videos to show some progress with CVA-01
https://www.youtube.com/watch?v=slNNjLqG7Hc (https://www.youtube.com/watch?v=slNNjLqG7Hc)
https://www.youtube.com/watch?v=_5Q_E3Tp3VQ
Post by: frogman3 on September 04, 2019, 11:55:17 am
HI Bob love your utube vids that rudder layout looks the bees knees  :-)) an works very well indeed an I see you have fitted led 's lights in the hangars  :-)) that's what I did on my Nimitz an it makes the ship look more realistic. An I just cant understand why you don't like split hulls Bob as mine is very simple 4 bolts fitted in hull joint an 4 butterfly nuts to join her up an electric plugs that when you join the hulls togeather the E /PLUGS just slip into one another  an it makes the model lighter to lift but that's just me
all best chris
Post by: Rob47 on September 04, 2019, 05:18:20 pm
Just me Chris, as I said used it for HMS Victorious which is a lot bigger than CVA, but it just is not my preferred solution.  Yes lots of lovely lights fitted, used lots on Tiger as well for white light and red action lights or simply change by flick of a switch.
Post by: johnv on September 04, 2019, 06:07:39 pm
Hi bob its John V it's all looking very good .you are doing a lovely Job .I knew you could do it right man for the job cheers John V
Post by: Rob47 on September 08, 2019, 05:19:16 pm
Another small video showing a working anchor winch, ok its not protypical in speed but near enough, for showing off at shows.  The other important thing (to me) is it cost £5 compared to the £100+ being asked for the ready made one.
https://youtu.be/UcD5-LkpTh4
Post by: dlancast on September 08, 2019, 08:45:33 pm
Awesome!!
Post by: johnv on September 09, 2019, 12:50:19 pm
Hay bob its John V you are just showing off now .but doing a grand job cheers John V
Post by: Rob47 on September 27, 2019, 10:29:09 am
One of my pet hates now fitted, just needs bit cleaning up then painting, Bilge Keels arggghhh
Of note she now has the correct grey paint on her, BSC 381 light weather works grey.
If the weather holds out this weekend she may move from slipway to the ballast basin for final ballasting, hopefully this time with no major leaks as happen last time %%
(https://www.modelboatmayhemimages.co.uk/images/2019/09/27/IMG_5048.jpg)
Post by: ballastanksian on September 30, 2019, 08:44:33 pm
There. Now you have those out of the way, hopefully you can enjoy the rest of the build that little bit more  :-))
Post by: Rob47 on October 01, 2019, 09:13:28 am
To right, hate doing them. :} :}
Post by: raflaunches on October 02, 2019, 09:04:59 pm
I’ve got some of those to do soon on Albatross. Colin-d showed me a better way whilst I was displaying at Deans Marine Open weekend. I’ll try to photograph it as I go along showing the methodology for future reference. My last bilge keel was on Invincible and it was a right pig to get right. Hopefully the next one will be easier. :-))
Post by: Rob47 on October 02, 2019, 10:27:14 pm
At last CVA-01 got her bottom wet, floats great and very stable, couple of annoying small leaks from port shaft and center rudder post, easy fix though
(https://www.modelboatmayhemimages.co.uk/images/2019/10/02/IMG_5052.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/10/02/IMG_5049.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/10/02/IMG_5051.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/10/02/IMG_5050.jpg)
Post by: Rob47 on October 02, 2019, 10:28:11 pm
Look forward to those Nick, any way to make it easier it going to be good
Post by: raflaunches on October 02, 2019, 10:44:45 pm
Magnificent Bob,
I’ll write up a post with my Albatross build as I go along showing Colin’s method- it looked simple enough and very effective- hopefully I’ll do it justice!
Keep up the good job  :-))
Post by: Rob47 on October 03, 2019, 10:59:54 am
Thanks, only fitted one side so look forward to seeing a different way
Post by: frogman3 on October 03, 2019, 11:08:54 am
She looks great on the wet stuff Bob are you fittin any aircraft an if you are what will they be ?
chris
Post by: Rob47 on October 03, 2019, 11:46:31 am
Gannets Phantoms and Wessex. If I can find at sensible
price Tamiya 1/100 Buccaneers as well
Post by: Rob47 on October 06, 2019, 10:23:25 pm
Todays work, deck landing light system, it can move forward and back, up and down and traverse, all to obtain correct setting. Quite pleased with it..
(https://www.modelboatmayhemimages.co.uk/images/2019/10/06/IMG_5053.jpg)
Post by: ballastanksian on October 06, 2019, 11:05:27 pm
If that lights up Rob, it'll be the model tech star of the year!
Post by: johnv on October 07, 2019, 08:46:03 am
Hi bob its John V i can see you are really going to town on this one nothing but the best .will end up best one in the country .I will have to buy it back .very proud of you cheers John V
Post by: Rob47 on October 07, 2019, 02:58:30 pm
Damm you sussed me out :} , yes it will be able to be lit, although this is the trial and fit version, designed to get me making and prove it will work.  Will have red, green and amber lights and bit more detailing, now working on the sponson and how to fit it, interestingly it is the only sponson she would have had.
Post by: Rob47 on October 07, 2019, 02:59:35 pm
Thanks for king words John, buy it back? better start saving  {-) {-) {-) {-)
Post by: Rob47 on October 10, 2019, 10:31:33 am
Latest work on Lizzie, No its not a gun turret {-) it is the sponson that will be the base for the light landing system posted earlier.  It is the only sponson she was designed with as the aim was to keep her smooth and clean to aid in the event of NBC attack.  The two rods fit into the tubes in the hull and are then pushed  home, giving a firm and secure mounting that is easy to remove for transport..
(https://www.modelboatmayhemimages.co.uk/images/2019/10/10/IMG_5059.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/10/10/IMG_5058.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/10/10/IMG_5057.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/10/10/IMG_5056.jpg)
Post by: johnv on October 10, 2019, 12:36:43 pm
Hi Bob it's John V it's looking good .it's going to look great when it's all lit up and got aircraft on .still saving up to buy it back cheers John V
Post by: unbuiltnautilus on October 10, 2019, 06:31:30 pm
I was looking forward to all the super detailed doo dads hanging off the side of the ship, looks like that's not going to be a thing then?! Curse that NBC stuff >>:-(
Post by: KitS on October 10, 2019, 07:24:49 pm
Looks like a gun turret in that last pic!  O0
Post by: Rob47 on October 11, 2019, 11:06:43 am
 :} :} yes it does, the only other bit that protrudes and only when needed are the booms for lowering the ships boats, they sit in the openings and when required two booms to each boat extend till the boat is clear of the hull side, then lower away handsomely.. Very stealth in its time.
Post by: frogman3 on October 29, 2019, 11:05:33 am
HI Bob whats happening on her as it would be nice to see some more pics  ?
chris
Post by: Rob47 on October 30, 2019, 10:12:35 am
Chris
Still working on her but as temp drops now doing small indoor bits. Wiring the deck landing light system and painting air group. Once done more images will be posted
Post by: frogman3 on October 30, 2019, 12:44:42 pm
Chris
OK Bob lookin forward to the pics an them tiger pics you posted for me were of imence help as the prop sharts are goin in now thank goodness cheers
all best to you chris
Post by: Rob47 on November 08, 2019, 08:40:57 pm
The Mk3 version of the light landing system, MK 1 was the version posted earlier using just coloured lenses, Mk 2 used led but found them to bulky so now using 12v grain of wheat bulbs, very happy with result.
The scenario for all lights on is, flying stations have just been piped, carrier turning into wind and the light landing system, turned on, it is now self checking the system, hence all the lights are on.
(https://www.modelboatmayhemimages.co.uk/images/2019/11/08/IMG_5117.jpg)
Post by: frogman3 on November 08, 2019, 09:05:32 pm
Lovley bit of work Bob in my opinion just got to hope it don't get knocked off by a passin model  as I had the same type of freshnel landin lights on my Nimitz an it got hit on our pond so I fitted  it back on the carrier with pidgin rubber qauter " square an then when it got hit it just bent back an forth to its proper postion but your carrier lookin great be nice to seein her sail with aircraft
chris
Post by: johnv on November 20, 2019, 09:19:04 am
Hi Bob its John V hurry up and get some more picks up .We haven't seen any for a while cheers John V
Post by: frogman3 on November 20, 2019, 09:41:44 am
YES I second that lookin forward to more pics Bob
chris :-))
Post by: johnv on November 20, 2019, 09:56:03 am
Hi Chris he's getting slow in his old age .But he's doing a lovely Job cheers
Post by: frogman3 on November 20, 2019, 11:22:27 am
AN hi John yes Bob is slowin down in his ole age bit like me I suppose  but hopefully he'll speed up a bit an post some pics when he sees our posts %) ok2   :} :-))
chris
Post by: Rob47 on November 21, 2019, 10:50:42 am
Not so much slowing down, as not enough time, work, then lessons to prepare, for teaching, also finishing one book and just had commission to produce one on HMS Bristol, to be ready by February, so just a tad busy.
Working on the air wing at moment as can do that indoors, also working on the side lift area in very short bursts.
So its not dormant {-) {-) {-) {-) {-) {-)
Post by: frogman3 on November 21, 2019, 11:33:52 am
HOORAY Bob  John v an me  lookin forward to more pics when you can fit us in your busy schedgle cheers
chris
Post by: littoralcombat on November 23, 2019, 10:35:33 am
Put me down for a copy of your HMS Bristol book Rob :-)) .
Nige
Post by: Rob47 on November 24, 2019, 05:41:54 pm
Post by: Rob47 on November 24, 2019, 05:55:02 pm
Some Dusk shots showing the air group, Buccaneers, Phantom, Wessex and Gannett all painted in the colours used for her first deployment
(https://www.modelboatmayhemimages.co.uk/images/2019/11/24/IMG_5174.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/11/24/IMG_5172.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/11/24/IMG_5173.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/11/24/IMG_5175.jpg)
Post by: johnv on November 24, 2019, 06:27:48 pm
Hi bob its John V Just to say it looks one hell of a bit of kit .. Looks real a very nice job cheers John
Post by: KitS on November 24, 2019, 09:19:16 pm
That looks pretty darned impressive.  :-))
Which kits did you use for the Air Group please?
Post by: Rob47 on November 24, 2019, 10:22:59 pm
Thank for commenting
Wessex are 1/100 die cast
Same for some of the Phantoms
Buccaneer are a mix of Tamiya/Revell 1/100 kits
Post by: frogman3 on November 24, 2019, 10:42:06 pm
Cor she looks great Bob an cheers for putting on some pics the lighting looks good
an the planes all lined up really set the flightdeck off brilliant job  :-)) 8)
chris
Post by: KitS on November 25, 2019, 08:33:34 am
Thanks for that info Bob, I noted that a some of the Phantoms were the longer nosed F-4E variant, but I'd forgotten that Tamiya had done that one in 1/100 scale.  :-))
At the price 1/100 scale stuff goes for these days that group must have cost a bit!
Post by: Rob47 on November 25, 2019, 09:41:08 am
Dearest cost £9. So well pleased so far. Just need more Buccaneers
Not being an aircraft buff I wanted to quickly populate hangar and flight deck
Post by: Rob47 on December 07, 2019, 12:22:40 pm
Lift now in place, and first lifting chain located., still need to blend sides in but quite happy with it.
(https://www.modelboatmayhemimages.co.uk/images/2019/12/07/IMG_5200.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/12/07/IMG_5201.jpg)
Post by: johnv on December 07, 2019, 04:12:11 pm
Hi Bob its John V I think you are building a real aircraft carrier . Working light's working ramp working anchors  it all looks great .ment to ask did that bilge pump work ok and was any of that stuff any good to you .take care John V
Post by: Rob47 on December 07, 2019, 09:55:45 pm
Yes pump works a treat and yes the other stuff very useful
Post by: frogman3 on December 29, 2019, 06:09:10 pm
HI Bob she's lookin good now with the planes an lights on an regards the aircraft lifts do they work up an down ok ?
chris
Post by: Rob47 on December 30, 2019, 03:18:30 pm
Chris
thanks
Forward lift is an access hatch, the side lift will work eventually.
Latest add on, first of the 50foot HF antennae mast, can be fixed in vertical or lowered, and no they will not be r/c controlled :} :}
(https://www.modelboatmayhemimages.co.uk/images/2019/12/30/IMG_5296-Edited.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2019/12/30/IMG_5295-Edited.jpg)
Post by: frogman3 on December 30, 2019, 05:45:02 pm
[/list]
Post by: Rob47 on December 31, 2019, 11:46:51 am
Replaced the scale warships Corvus launcher with Shapeways item, really good and very cheap to.
(https://www.modelboatmayhemimages.co.uk/images/2019/12/31/IMG_5298.jpg)
Post by: frogman3 on December 31, 2019, 01:59:03 pm
HI Bob the saftey rails look very good where did you buy them as im gonna need a whole lot of them an how much please ? an this shapeways is 3d printing isn't it ?
chris :-))
Post by: frogman3 on December 31, 2019, 02:00:56 pm
HI Bob the saftey rails  posts look very good where did you buy them as im gonna need a whole lot of them an how much please ? an this shapeways is 3d printing isn't it ?
chris :-))
Post by: Rob47 on December 31, 2019, 02:44:10 pm
chris :-))
Chris Maritime Models on line company, these are 10mm and £6 for 10
Shapeways is 3d, the corvus were less for a pair than the scale warships set, so very pleased.
Post by: frogman3 on December 31, 2019, 09:13:37 pm
HI Bob cheers for the info an I cant try an load pics yet as my printer is playin up so I cant down load your instruckions but will have another go tomorrow an hope it behaves itself AN HAPPY NEW YEAR
Chris
Post by: Rob47 on January 31, 2020, 10:49:03 am
Bit more on CVA-01, got most of the air group on board, missing two at moment, due to not being built, as can be seen, Wessex helicopters, Phantoms ,Buccaneers and a visiting COD Gannett from HMS Hermes who was soon to be replaced by CVA-02 HMS Duke of Edinburgh.  The one shot shows the idea of being able to taxi around the Island while landing takes place, helping to speed things up.  The aircraft will be tarted up and decals applied later, just wanted to get them done.
JohnV hope you like how she is shaping up.
(https://www.modelboatmayhemimages.co.uk/images/2020/01/31/IMG_5363.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/01/31/IMG_5362.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/01/31/IMG_5360.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/01/31/IMG_5359.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/01/31/IMG_5361.jpg)
Post by: frogman3 on January 31, 2020, 11:35:02 am
HI Bob
Cor she's really lookin good all those phantom's an buckeneers an the gannet ready for take off   wesssek choppers nr a full air wing I reckon just been havin a look at them for a ship that never was  this is lookin great she will look great on the wet stuff  :-))
chris
Post by: johnv on February 01, 2020, 10:40:18 am
Hi Bob it's John v like I said before you are doing a grand job. I  Think I shall be  buying it back. Keep up the good work you should be very proud of yourself cheers John v. If there's anything I can help you with give us a shout John v
Post by: Buccaneer on February 01, 2020, 07:24:56 pm
Hello Bob,
I haven't been in touch for some time but rest assured I am still following your build. It is excellent, and interesting at the same time. I was always sceptical about having room behind the island to manoeuvre aircraft but having seen a model on it I now believe it fits!
Post by: Rob47 on February 02, 2020, 03:44:42 pm
Thanks very much for that, I have tried to follow the original plans as much as possible, and I am pleasantly pleased with her, do hope to get her wet very soon
Hello Bob,
Post by: johnv on February 02, 2020, 06:49:10 pm
Hi Bob it's John v don't forget to give  me a shout when it's going in the wet stuff cheers John v
Post by: frogman3 on February 13, 2020, 08:44:14 am
HI Bob anything more on her ?
chris
Post by: Rob47 on February 13, 2020, 11:05:07 am
not a lot, apart from building the last Buccaneer, thank goodness, also have built a carry case for the island. To cold and I have till first week in March to complete a ships history for the RN, very important contract for me, but hopefully back to her soon, still want her wet so can finally sort ballast, which means certain areas can finally be sealed, then after that final bits and then her big day which I hope Johnv will come to.
Post by: Rob47 on February 29, 2020, 05:29:20 pm
Picture shows the automatic bilge pump system (many thanks to JohnV), which works a treat.
Special servos for the lift arrived today and tested the theory and it works, just need sparky to finish in the garage and some building can take place.
(https://www.modelboatmayhemimages.co.uk/images/2020/02/29/IMG_5481.jpg)
Post by: frogman3 on March 02, 2020, 09:50:10 pm
HI Rob what is that red thing  the
[size=0.85em]automatic bilge pump system sencor ? an when water hits it it starts the pump I suppose [/size][/color]
[/size][/color]
[size=0.85em]chris[/size][/color]
Post by: derekwarner on March 02, 2020, 10:11:23 pm
If she is sailing in sea water & springs a leak........the [saline] salty water will hit the 2 contacts in the switch & conduct electricity or make the circuit thus turning the bilge pump on and saving HMS CVA-01 from a murky future
[but only if the pump is positive displacement or and self priming and can suck about 5 1/2" of air column?  %) ]
Sorry, but my best guess......Derek  :embarrassed:
Post by: Rob47 on March 03, 2020, 10:50:49 am
I installed it then deliberately added water to hull interior and pleased to say it goes like a good un. If anything the flow would credit to a fire engine 😂
Post by: johnv on March 03, 2020, 01:44:07 pm
Hi Bob it's John v You tell them Bob. It does work better than you would think. Lovely bit of work cheers John v
Post by: ballastanksian on April 04, 2020, 12:24:52 pm
You have made an Opus of a model Rob. I salute your efforts on the aircraft complement as well as the electrical lighting magic.
Post by: frogman3 on May 12, 2020, 06:15:02 am
HI Bob whats happening on her ?
chris
Post by: Rob47 on May 12, 2020, 10:08:00 pm
Nothing, really, working on the lift and came up with an ide to make the antenna work by r/c
Post by: Rob47 on May 23, 2020, 05:11:11 pm
Well at long last the side lift works, using chains just as she would have and same as the current QE
Next are the antennae which are coming on nicely, basing them on the ones used on HMS Victorious, which use rack and pinion to raise and lower.
Video of the lift in operation, still WIP but very happy so far.
]https://youtu.be/_AthW-mgt_g  (https://youtu.be/_AthW-mgt_g)
Post by: johnv on May 23, 2020, 05:21:09 pm
Hi Bob it's John v all looks very good. We'll done. I  knew you would do it. Great job cheers John
Post by: raflaunches on May 23, 2020, 06:17:08 pm
Hi Bob
These are the article pages I mentioned- if you like I can send you some scans and email you with them. PM me with your email address and I’ll send them to you. Hope they help.
Post by: derekwarner on May 23, 2020, 11:55:29 pm
The side lift motion by chain is great Bob  :-))
Are you using just one servo drum [endless?] for the lift raise & lower?...[we just see a glimpse of the drum to the left for a second]
If so, an ACTion P96 Servomorph would give you great control over adjustable [desired] speed and chosen set points [totally repeatable]
Could certainly be wurth reading the spec sheet
https://www.componentshop.co.uk/pdf/pdf.jpg (https://www.componentshop.co.uk/pdf/pdf.jpg)
Any tendency for the drive to hop or jerk, could be countered by adding some sheet lead into the base of the lift floor plate fo add to stability
Post by: Rob47 on May 24, 2020, 11:16:02 am
No servos were harmed in the making of this lift.  I tried all sort of methods, including servo slower, but it is not effective when trying to control two servos.. Solution is two small high torque right angle gearboxes, running at 3 RPM, no other electronics need, simply on/off/on switch and a twin relay. Works a treat ,if possibly tad slow but that can be changed later, this at least proves the system.
Post by: derekwarner on May 24, 2020, 11:38:49 am
Thanks Bob...well explained  O0 ...the proof is in the pudding & the end result is   :-)) ..I do not think the raise/lower speed is too slow... Derek
Post by: Rob47 on June 12, 2020, 07:20:44 pm
Well latest up date on the QE, built two of the three working HF antennas, they are raised and lowered copying designs used in Ark Royal, Eagle and Victorious, rack and pinion and on the model controlled by individual servos, all linked to a three legged Y lead,  Waiting for the servo morph to come back into stock then I can adjust the speed and throw, eventually control will be a on/of switch.
https://youtu.be/vej2UBeyDh8
Post by: ballastanksian on June 12, 2020, 08:09:46 pm
These, the anchor and the lift all look great in motion. The speed of the lift if a bit slow, but like you say, you can adjust it, and you do not want it too fast, or everything that travels on it will become VTOL!
Post by: raflaunches on June 12, 2020, 11:41:13 pm
Love it Bob
Love to see your working features - it’s little things like this that make the model special.
Post by: Rob47 on June 13, 2020, 02:34:08 pm
 :} :} true but would save having her in for refit for a ski jump
Post by: ballastanksian on June 13, 2020, 03:35:11 pm
True Bob, true!
Post by: Rob47 on June 25, 2020, 11:45:51 am
Now got all the HF Antennae working under r/c control from a rotary switch on the tx, just needs linkage tweaking and job done, quite pleased, speed is set from watching ARK Royals in action
https://youtu.be/xY7yPg-wkGw
Post by: frogman3 on June 29, 2020, 07:22:32 am
https://youtu.be/xY7yPg-wkGw (https://youtu.be/xY7yPg-wkGw)
HI Bob its great to see your anttenas workin  on your carrier an the aircraft lifts i got my aircrafts elevator or lifts whatever they called workin on my USS NIMITZ an the hangar doors  to open an close by push pull wires
chris
Post by: ballastanksian on June 29, 2020, 08:59:35 am
I like how the pivots are slightly loose as that will protect them from inevitable knocks breaking the pivots or their mounts. Just wiggle them into alignment and they look just right  :-))
Post by: Rob47 on July 04, 2020, 02:33:47 pm
Well with her name going on I feel as if I am nearly there, (if only)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/04/IMG_0196.jpg)
Post by: frogman3 on July 04, 2020, 05:58:49 pm
LOOKIN  GOOD Bob  :-))
chris
Post by: frogman3 on July 15, 2020, 12:26:07 pm
chris
Post by: Akira on July 15, 2020, 01:00:05 pm
When I need to adjust motor speeds or simply voltages in general, as long as the current draw is low, I have used this Buck Converter, which works beautifully and is very inexpensive.    https://www.mpja.com/Adjustable-15-37V-DC_DC-Buck-Converter-with-LED-Volt-Meter/productinfo/30149+PS/   You may find it to be just the ticket for your blast deflector motor.
Post by: Rob47 on July 15, 2020, 02:40:33 pm
Hi thanks for the post, not to sure what you mean as i have not mentioned blast deflector motors, they are a static item.
When I need to adjust motor speeds or simply voltages in general, as long as the current draw is low, I have used this Buck Converter, which works beautifully and is very inexpensive.    https://www.mpja.com/Adjustable-15-37V-DC_DC-Buck-Converter-with-LED-Volt-Meter/productinfo/30149+PS/ (https://www.mpja.com/Adjustable-15-37V-DC_DC-Buck-Converter-with-LED-Volt-Meter/productinfo/30149+PS/)   You may find it to be just the ticket for your blast deflector motor.
Post by: Rob47 on July 15, 2020, 02:41:35 pm
Bit of a pause while working on Vic, but pulley wheels for crane and arrestor gear, arrived to day so that next job
bob
chris
Post by: Akira on July 15, 2020, 03:28:01 pm
My mistake! So sorry, I confused the lift and anchor with the deflector.... although that would be quite a feat.I actually use one of the converters to power and adjust the speed of my anchor winch on my rescue salvage ship. They work beautifully as power supplies for LED s as well.
Post by: Rob47 on July 15, 2020, 08:33:18 pm
hey no problem, the lifts work brilliant now using 3rp hi torque motors, one each side.  I use a similar device to adjust current, cost about £2 and are absolutely brilliant.
Post by: Rob47 on July 22, 2020, 12:31:52 pm
Latest images of CVA-01 Queen Elizabeth
Show first two arrestor wires fitted, Sea dart launcher roughly located, Jet blast deflectors, and one ships boat and crane.
(https://www.modelboatmayhemimages.co.uk/images/2020/07/22/IMG_0221.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/22/IMG_0222.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/22/IMG_0219.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/22/IMG_0218.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/22/IMG_0220.jpg)
Post by: frogman3 on July 22, 2020, 05:04:22 pm
NICE WORK Bob comin on great a pleasure to follow this build  :-))
chris
Post by: johnv on July 23, 2020, 10:38:12 am
Hi Bob it's John v. You are doing a grand job keep up the work. Cheers John v
Post by: Rob47 on July 23, 2020, 10:22:03 pm
It may look brutal, but this is the start of the main embarkation port, a similar one will also be added to the port stern side.  the whole in the sponson is for the 45 foot launch. 35 foot work boat, these are held in side the sponson, very similar to the current QE, once in the water the accommodation ladders can be lowered for access to the launch  Not decide if I will have this as a working feature yet  O0 O0
(https://www.modelboatmayhemimages.co.uk/images/2020/07/23/IMG_0229.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/23/IMG_0224.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/23/IMG_0225.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/23/IMG_0228.jpg)
Post by: frogman3 on July 24, 2020, 06:18:42 am
HI Bob comin on nicely  but can you take a pic of the aperture from a bit further away so we can see where this is on the ship ? :-))
chris
Post by: Rob47 on July 24, 2020, 03:37:14 pm
ChrisPort for'd and aft although aft is not started.  As they are today, normally the work boat would not rest on lolly sticks {-) {-)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/24/IMG_0233.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/24/IMG_0232.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/24/IMG_0231.jpg)
Post by: frogman3 on July 24, 2020, 06:04:31 pm
OK Bob but could you take a pic of the hull so i can see where in the hull they are located  :-)) as i just cant imgine where ?
chris
Post by: Rob47 on July 25, 2020, 03:08:28 pm
Chris
 both located fore and aft.  The ones in the images are the port forward the aft is not started yet.. once the deck is done and piping complete i will post some more.  The winch steel cable arrives Monday.
Post by: frogman3 on July 25, 2020, 03:39:27 pm
OK Bob look forward to seein them an more pics as you are doin a grand job  :-))
chris
Post by: Rob47 on July 30, 2020, 09:11:40 pm
Images and short video today.  The images show the port forward embarkation port, which does have detail but as its not illuminated its to dark to see. while the video is a 35 foot work boat, being lowered, it normally is stored in the flight deck sponson, and a parallel today is the current QE class stow boats the same.  The motor is not the final one but the actual one is same design, just more rpm, ignore the bits hanging from underneath, :}
(https://www.modelboatmayhemimages.co.uk/images/2020/07/30/IMG_0245.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2020/07/30/IMG_0244.jpg)
https://youtu.be/lFv3WtE3fIk
Post by: Capt Podge on July 30, 2020, 10:02:20 pm
It looks like you've made an excellent job of lowering and raising the boat with the speed of descent and on an even keel - super job with that mechanism - well impressed with it Bob  :-))
Post by: frogman3 on August 12, 2020, 06:05:35 am
HI Bob yes ive now seen the vid of the work boat bein lowered an raised an very good to it goin up an down on even level very well done be nice to see the workins of how you done it ;D  as really good to see workin features on a big ship model  an back to the vid link when i did look as i remember now at the pics an what you said but i just did not see the vid link thats how i missed it will look more closely from now on  :embarrassed: as i think if i built a big model an it dint have workin features id be ashamed to show it in public but really as i try an make things work my models are really semi scale models as they are not 100% correct  like yours but im happy with the way my tiger build is goin an bein happy buildin is the thing about this hobby to enjoy the build but i must admit sometime my heart is in me mouth worryin if something will work rightly how i want it to but back to your model here brilliant work an more pics please
chris
Post by: Rob47 on August 12, 2020, 10:03:48 am
thanks Chris, the working features are very basic, a 2rpm motor with a shaft running the full width of the gap, and thats it , controlled by a on/off/on switch, keep it simple if you can, will take a pic later for you
Title: Re: CVA-01 HMS Queen Elizabeth
Post by: Rob47 on August 12, 2020, 02:49:05 pm
Chris
Boat mechanism as i said nice n simple
(https://www.modelboatmayhemimages.co.uk/images/2020/08/12/IMG_0273.jpg)
Post by: frogman3 on August 12, 2020, 08:12:39 pm
YEA I see what you mean Bob as you say nice simple an thats the best way really less to go wrong spot on
chris :-))
Post by: Akira on September 28, 2020, 05:06:32 pm
I don't know if this will help you, but there is a nice long article, with plan diagrams, in the 2014 edition of warship, published by Conway.
Post by: Rob47 on September 28, 2020, 05:13:30 pm
That is one of the best articles on the ship and used that along with the original drawings
Post by: Rob47 on October 05, 2020, 10:24:24 am
Anchor winch in operation version 2
https://youtu.be/KU10YTvqKZA
Post by: frogman3 on October 05, 2020, 05:46:06 pm
HI Bob this is really great nice to see things work on your models as it brings the model to life  what other working options are you thinking of as ive got quite a few planned for my tiger brilliant work  :-)) as today jen has helped me on the hand rails holders as i had to drill out the tiny holes to get the brass rod through an jen has managed to thread the knobs onto the rail as they are so tiny but jen bein nr ten yrs younger than me has a lot better eyesight but lookin forward to seeing more pics of your carrier
chris
Post by: derekwarner on October 05, 2020, 10:14:17 pm
Don't laugh ......
It you have ever been in the foredeck anchor machinery space in a 100,000 tonner when the anchor is hoisted & housed ...the mechanical growns & echoing thumps are memorable
Your model of CVA-01 sounds remarkably like this  :-))
Post by: johnv on October 05, 2020, 11:47:15 pm
Hi Bob it's John V I think you are doing a lovely job. But when are you going to stop. All these working parts. I think you are building a real one ha ha ha. Keep up the good work. Cheers John V
Post by: raflaunches on November 28, 2020, 08:51:58 pm
Hi Bob
I’ve just been reading about some what-if aircraft and it’s a real shame that 1/96 scale isn’t a more prevalent scale for aircraft kit companies!
Imagine a replacement COD Gannet with a COD Dominie! It actually was considered and sales brochures were made by Hawker Siddeley. They were going to fit an arrestor hook, strengthened undercarriage and catapult hooks. In a little twist the aftermarket kit company who is making a conversion set for the Airfix 1/72 Dominie T1 has included an inflight refuelling probe too.
It would look very different and a certain talking point about the air wing on board!
Post by: Akira on November 28, 2020, 11:18:57 pm
Do you mean something like this?https://www.youtube.com/watch?v=ar-poc38C84
Post by: raflaunches on November 28, 2020, 11:27:39 pm
Sort of- just much smaller aircraft! Carrier Onboard Delivery (COD) was taken up by Gannets in the Royal Navy. The proposed Dominie COD could carry engines and other spares in its cargo bay. I think the reason it was never taken up was that it didn’t have folding wings.
Post by: KitS on November 29, 2020, 12:15:40 pm
That'd be Freightdog, an excellent company with a genius modeller to make their masters.
I have that conversion kit for the Airfix kit and it's superb. It might even work with the longer Matchbox HS125-600 too, which would have made an even better COD aircraft.
Post by: raflaunches on November 29, 2020, 12:58:19 pm
I agree, they are fantastic-I’ve bought two different sets by Freightdog for the Airfix Dominie- the COD variant and the RN Weapons Trainer.
I have to admire Colin of Freightdog for his quality and he even sent out two Fire Streak missiles as an addendum for the kits that were supposed to be purchased at the cancelled Telford show.
Post by: ballastanksian on January 17, 2021, 11:50:02 pm
He's a lovely chap Colin. I used to meet up and talk to a mutual friend about stuff at a Model show in Farnborough High school each year.
The mutual friend 'might' be the designer as I remember him using wood shavings to recreate the plywood effect on the fuselages of WW1 aircraft! It looked so real. I got in touch with Colin about getting in touch with our mutual friend and mentioned the situation regarding lack of 1:96th scale aircraft but obviously kits take time and money to develop, so I am sure that if sufficient orders were guaranteed, he might consider it, though I am in no way pushing agendas.
Post by: Rob47 on January 18, 2021, 10:27:04 pm
Interesting to produce a list of most sought after 1/96 aircraft
Post by: frogman3 on January 19, 2021, 07:32:38 am
HI Bob what happening on your carrier now  ?  an i think you have got all your aircraft now hav'nt you ?
chris
Post by: Rob47 on January 19, 2021, 10:04:54 pm
Chris
Yes I have a full air wing, as for Lizzie she is still ok, but just to cold to go in the garage, now have started on a nice indoor project, with a bit of modelling licence.  Google HMS  Leviathan R97  I am going to build her as if she HAD been completed  Tweaking Glynn Guests model of Goliath and lots of Shapeways bits which at 1/144 are pretty cheap.  Pictures once some progress is mad.
Post by: raflaunches on June 06, 2021, 01:49:15 pm
Well it’s time for the announcement- HMS Queen Elizabeth CVA-01 transferred to Kettering last week and had her maiden sail at Wicksteed Park model boat lake. Remarkably manoeuvrable with the triple props and rudders she sails rather majestically and occasionally I had to remember to slow down in advance as is the case with heavy displacement models.
My thanks to Bob Griffin (Rob47) for allowing me to take ownership of such a fantastic model.
I hope to continue his excellent work and she will be a common sight hopefully around the country.
Post by: raflaunches on June 06, 2021, 01:51:13 pm
Pictures of the maiden voyage
Post by: KitS on June 06, 2021, 02:11:29 pm
A flush decked UK carrier!  :o
That's going back to our carrier roots for sure, a bit like the 'Furious'.
Post by: raflaunches on June 06, 2021, 02:34:18 pm
Yes she does look like a modernised Furious or Argus! Superstructure is being repaired at the moment as the trip back from Bob’s was a little more bumpy than expected and broke some of the structure but nothing that couldn’t be fixed with a bit of glue and tape to hold it in place whilst it dried.
Post by: KitS on June 06, 2021, 04:42:06 pm
I know every pothole on every possible route from Glos to Northants so I feel for your problems in trying to avoid them!  :((
Well done on getting her afloat.  :-))
Post by: raflaunches on June 06, 2021, 04:58:07 pm
The credit goes to Bob for the fantastic rebuild which if I remember correctly included the prop shaft re-alignment. The rudders are particularly interesting and I did wonder how effective they are- at fully speed she can slew around surprisingly tight for a model of her size.
Post by: Rob47 on June 06, 2021, 09:59:34 pm
Nick
Thans for posting those, good to see her in the water and to hear how well she sails, I did wondr about the rudders, hope it was not the island that was dmaged.
Post by: Rob47 on June 06, 2021, 10:00:38 pm
Would have been amazing as she coloud land, launch and strike down aircraft all at the same time with no interpution to flying
Post by: raflaunches on June 06, 2021, 10:10:53 pm
Hi Bob
Glad you like the pictures and get to see her sailing in them. Unfortunately it was the superstructure that as damaged slightly as it fell over in the back in the van when we went over a series of road potholes but nothing too serious- a bit of thin glue and and tape was all that is needed to hold it back together again.
Post by: frogman3 on June 07, 2021, 12:20:56 pm
HI  Nick some lovely moddeling on that carrier but whats gonna happen on that smaller tiger ?
chris
Post by: raflaunches on June 07, 2021, 12:27:28 pm
Don’t worry about tiny tiger, the build is on-going this week as I have at long last got a week off work! Loads of modelling potential this week ;)
Post by: frogman3 on June 07, 2021, 12:36:30 pm
OH BRILLINT Nick  :-))
Chris
Post by: ballastanksian on June 07, 2021, 01:06:01 pm
An interesting turn of events that I am pleased to see resulting in you taking on one of Mr Griffins masterpieces :) It's a shame we cannot claim for damage to goods etc from these blasted potholes* Maybe more would be removed if there was a way.
*If the pothole has not been identified by Highways (usually by spraying it with a coloured boundary ) and it causes damage to your vehicle then you can I believe make a claim for repair costs.
Post by: raflaunches on January 03, 2022, 04:39:38 pm
Hi everyone
Time for some updates to the CVA01 project. As Bob was aware and would have sorted when he was making the model the aft section of hangar/quarterdeck/boat deck needed some attention to make it removable and watertight at the same time. I’ve carefully removed Bob’s elevator and put in storage temporarily with the lights so this could be rectified. It’s been fun I can say as I managed to get copies of the original ship drawings and used them to construct a rough example of the area which has been interesting to say in the least! I thought I could get away with not removing the rudder tillers and steering equipment but after discovering that the hangar deck sat lower I’ve had to carefully disconnect them too to trial fit the deck and see where the access will be in case of emergency rudder failure. All the electrics have been carefully photographed and disconnected to lay in the bows of the carrier so no damage can come to them during the construction of the aft/stern section.
Fingers crossed that when everything is reconnected my photos and memory will ensure a good working elevator and other features as before.
Post by: Rob47 on January 03, 2022, 04:57:06 pm
Intresting Nick, see you noticed the discrepancy between plans and actual hull, are you using the NMM plans set? I found from those that I would have had to increaes the hull sides to give correct height, I see you have cut down to give it the height.  Its a good model to work on, btw dont break the forward part of the bridge, as price now is enough to buy a real carrier.
Happy New year to you and your dad.
Post by: raflaunches on January 03, 2022, 05:22:08 pm
Hi Bob
Yes they are the NMM plans and I can see what you mean when I collected her from you- they are infuriating I’m not matching up so I’ve made it practicable instead of accurate as there is no way some parts as drawn will fit or work. The drawing shows the sea dart launcher but no way of detail how it was reloaded or controlled and the area around the launcher itself and the quarterdeck is like deciphering hieroglyphs. I’m doing as you did- make it look like it would work instead of following the plans 100%.
The superstructure is safe at work in its box and fully secure this time. I saw the price on Shapeways and almost gasped at the price- I was speaking to Mark Hawkins and he has bought three 3D printers himself after he was happy with the price they were going to charge for his new K class superstructure. So watch for his own stuff very soon- I’ve actually got a 3D printer myself but still trying to understand the CAD software that goes with it.
Many thanks and I’ll keep you posted on the rebuild/finishing.
Happy New Year to you and and your family too from both Dad and myself. :-))
Post by: Rob47 on January 03, 2022, 06:47:12 pm
The sea dart launcher is the MoD 0 as fitted to the T82 HMS Bristol and although it had the flash doors either side in practice it was to be reload horizontally, as there was no space for a deep magazine, suspect that the launcehrv would have been redesigned in that case.
If I was to tackle it again I would have to be drastic and do a lot of cutting and adding bits, but as it was 3/4 built I tired as you sayo to make it look correct.  Talking of the plans, when i collected them from the brass foundry, we had them all laid out and one of the volunteers looked at them and said "thats the first time in 50 years I have seen these" he only was one of the draughtsman on it.  Have attached a section of plan just to ocnfirm sameo nes.
(https://www.modelboatmayhemimages.co.uk/images/2022/01/03/IMG_1428.jpg)
Post by: Rob47 on March 18, 2026, 03:30:49 pm
Update on Lizzy, not looking to bad I think
(https://www.modelboatmayhemimages.co.uk/images/2026/03/18/IMG_43891.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2026/03/18/IMG_43881.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2026/03/18/IMG_43851.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2026/03/18/IMG_43871.jpg)
(https://www.modelboatmayhemimages.co.uk/images/2026/03/18/IMG_43861.jpg)
Post by: Martin (Admin) on March 18, 2026, 05:01:04 pm
Not looking too bad at all !   :-))
Post by: NavyShooter on March 18, 2026, 08:05:43 pm
That's looking quite fine!  Well done on the air det!  That's a project all on its own!  Keep it up!
Post by: T888 on March 18, 2026, 08:49:47 pm
Rob,
Not bad at all  :-)) :-)) :-))
