Mess Deck: General Section => Other Hobbies and Interests => Topic started by: eddiesolo on June 24, 2019, 01:51:42 pm
Some recent pictures of some new props for our K.M.B.C home and away events.
A basic centre town river section for the bridges to go over, just board, scrap wood, paint etc. There is other sections to make.
I also remade the knocked out Tiger, this is a metal lower hull, new top hull, only the turret is the original as this takes the sound unit for background battle sounds.
The lower hull can now take a incense cone and will smoke away through the grilles and hatches to give the impression of it still smouldering away. This was the easiest option, I was going to use a smoke unit and just power it via a battery pack however, if it is forgot about it will run dry and burn out-keep it simple. There is also a suspended aluminium plate attached to the underside of the top hull to stop the plastic from getting too warm.
(https://i.ibb.co/wKMV9G5/62009174-431435137413384-7949670013160390656-n.jpg)
(https://i.ibb.co/v1dGdtx/61891425-345634216100140-4869821704764915712-n.jpg)
(https://i.ibb.co/bJMgw3C/62030325-436533777161719-3608820535019962368-n.jpg)
(https://i.ibb.co/VpLqkJF/IMG-8566.jpg)
(https://i.ibb.co/ckn7rdG/IMG-8567.jpg)
(https://i.ibb.co/jRyGNG2/IMG-8569.jpg)
(https://i.ibb.co/dgCpH83/IMG-8573.jpg)
(https://i.ibb.co/KbrNFdt/IMG-8587.jpg)
(https://i.ibb.co/tqCQP6C/IMG-8632.jpg)
(https://i.ibb.co/vm51dk3/IMG-8638.jpg)
Si
Great work Si
super detail on the tank as allways :-)
Jason
Great work Si
Jason
Cheers Jason. :D
There are HVAC smoke bombs that produce a sizeable amount of smoke - say for the start of the event, swap say for a normal incense cone for later / longevity
( Photos fixed )
