Title: Re: Martin builds a Mini Logging Tug
Post by: Martin (Admin) on November 02, 2019, 10:10:14 pm
Post by: Taranis on November 02, 2019, 10:16:16 pm
Wow that is truly a professional presentation O0
Post by: Howard on November 02, 2019, 10:41:59 pm
Hi Martin, Made mine months ago and found it a great kit for the money only hard part in getting every thing plus your fingers in side such a small hull but it can be done. mines a docking tug. Regards Howard.
Post by: Martin (Admin) on November 02, 2019, 11:40:38 pm
Do you still have your instructions Howard, the QR code link is dead?
Post by: chum444 on November 03, 2019, 01:49:35 am
Let me know if he doesn’t. I think I still have a copy. BTW, my modified Q1 was the first boat I Ever sank. Heeled WWAAYY over in a turn and down it went. I’ve since modified it but it is a fair seas hull.
Post by: tica on November 03, 2019, 07:43:05 am
@Martin you got a PM with a link RCarsten
Post by: mrzippy on November 03, 2019, 09:06:24 am
Nicely done Martin - that's Christmas sorted for me !
With nil progress whatsoever on the big 1/6 scale similar logging tug - my new workshop builds dragging on - I think I could fill the big'uns hull with water and sail this little gem up and down inside the hatch coamings !!
Hopefully see you next weekend. regards Paul
Post by: Howard on November 03, 2019, 12:15:29 pm
Hi martin, Yes I have some where will start digging, Martin I noticed in your you didn't seam to get a speed controller with yours to all reading this please make sure you get the real thing as there's a lot of chines copies' out where mine was about £40 so amazing value. Regards Howard.
Post by: barriew on November 03, 2019, 07:32:08 pm
Howard
I'm not sure its still possible to buy the original kit - only Chinese copies which don't include everything you got. I noticed that the Ebay link Martin posted says 'Print your own parts' If anyone knows how to get an original kit with all the parts I would be very interested. I have built one of the copies which came with electrics or printed parts. Barrie
Post by: tica on November 03, 2019, 08:12:25 pm
Barrier you are right I saw a posting from the original owner of the kit and he stated a price of approx. 60£ +P&P and that P&P would be high due to weight of all the parts, he also stated that some people had requested to buy the 3D printed parts and then they listed a knock off incl. the 3 D parts for a low amount on ebay / Aliexpress etc. They even use his original pictures for the adds.
I did buy one of those knock-offs on Aliexpress and got a 100% refund when I filed a complaint. That is also the reason that the QR code do not work. RCarsten
Post by: Andyn on November 03, 2019, 08:45:52 pm
What I'm most looking forward to is a thread entitled 'Martin FINISHES building a logging tug' ;)
Post by: Martin (Admin) on November 04, 2019, 08:17:25 pm
Post by: Tafelspitz on November 09, 2019, 03:27:11 pm
That's one cute little tug! :} :-))
Dom
Post by: Martin (Admin) on November 18, 2019, 09:36:32 pm
Question chaps: Is it advantageous / easier to sand the sheets to, almost final finish, while all the bits are still in sheet form?
Post by: RST on November 18, 2019, 09:48:33 pm
....yes, slap on some primer and sand it back. Makes life much easier later IMO if you have that option, even if you need to re-coat and sand back later.
Post by: RMH on November 18, 2019, 10:30:12 pm
I would of thought you'd get a better bond with just bare wood as the wood glue will soak into the grain, if you apply primer then the grain will be sealed.
Post by: Martin (Admin) on January 31, 2020, 05:56:12 am
Logging Tug - part 2
Post by: tugboattam on January 31, 2020, 11:55:25 am
I got one of these a long time ago sadly there where no plans or instructions with it so still not built, I know many of you will say it is easy to build but I'm not the greatest builder by any means, so if anyone could photo copy these I would be happy to pay postage.
Post by: Martin (Admin) on January 31, 2020, 01:00:59 pm
Ebay seller also sent a link today: http://www.mediafire.com/file/fd261dzb83rx94n/mini_tugQ1%25EF%25BC%2588old%25EF%25BC%2589.pdf/file (http://www.mediafire.com/file/fd261dzb83rx94n/mini_tugQ1%25EF%25BC%2588old%25EF%25BC%2589.pdf/file)
Post by: Martin (Admin) on February 01, 2020, 02:44:17 am
Logging Tug - part 3
Post by: Martin (Admin) on February 01, 2020, 02:49:16 am
Question: Will I get away gluing the hull plates with superglue or will I need epoxy?
Post by: Subculture on February 01, 2020, 11:11:08 am
You can tack it together with superglue, then get some brushable epoxy resin and coat the hull inside and out. The epoxy will both seal the wood, and also strengthen it enormously.
If you add a layer of 25gram glass cloth or use some old nylon tights on the outside of the hull with the epoxy, you'll have a very tough and waterproof hull.
Post by: Shipmate60 on February 01, 2020, 11:11:38 am
Martin, Superglue is water solvent so you would need to ensure that the paint coat is good. If you can get it there try the ruberised glue it is the only superglue i know of that is slightly flexable.
Post by: Martin (Admin) on February 01, 2020, 12:43:24 pm
.... never actually glass clothed any of my boats before, always counted on too many coats of paint.... and a spare 'touch-up' can!
Forgot about the tights 'hack'! :-))
Post by: Subculture on February 01, 2020, 12:50:36 pm
It's not difficult, and it improves the toughness of the boat no end. Entirely optional though.
Post by: Martin (Admin) on February 02, 2020, 08:16:31 pm
Part 5
Post by: steve mahoney on February 04, 2020, 08:11:13 pm
Such nimble fingers and so fast ;)
Post by: Martin (Admin) on February 05, 2020, 03:18:30 am
O0
Post by: Martin (Admin) on February 08, 2020, 08:00:49 pm
Part 6
Post by: Big Ada on February 09, 2020, 04:11:13 pm
C'mon Martin, are you competing with Canterbury Coxswain to see who can take the longest to build a Boat. %)
Len.
Post by: Martin (Admin) on February 09, 2020, 08:05:12 pm
Bloody cheek! {-) {-)
I have run out of decent rubber bands though ... and the postie doesn't drop the red ones anymore. {:-{
Off to Inwoods tomorrow.... 'Don't buy anything but bands!..... Don't buy anything but bands!' <*<
Post by: Martin (Admin) on February 16, 2020, 10:09:33 pm
Part 7 - i looked at it, tinkered a little bit and put it away again! :P
NB: This a 'kitchen table' build, only get a couple of hours indulgence / tolerance from Mrs Mayhem. {:-{
Post by: TheLongBuild on February 17, 2020, 10:21:47 am
So - where do I rank in the time taken ? {-) (and mines a plastic fantastic)
Well I have had the Titanic kit from around 1985-88 from the model shop inside Grosvenor precinct Chester, Bismark kit from around 1995 from the MS in Manchester and the Fleetscale Bissy from around the same period. Just about ready to start I think.. %% . Dare you to ask Martin about His Bismark !! :} :} :}
Post by: coch y bonddu on February 17, 2020, 06:29:26 pm
yes Martin you can mix them up it works for me
Post by: TheLongBuild on February 18, 2020, 10:33:20 am
Joking aside, I think the videos are pretty good, however I have fallen asleep twice because of the relaxing music {-) {-) {-)
Post by: Martin (Admin) on February 22, 2020, 10:18:02 pm
This week:
1. Ordered low viscosity epoxy didn't turn up from ebay seller..... >>:-(
2. Reinforced epoxy hull join.... with more original epoxy!
3. Reinforce hull center line with wood strips.
4. Turn to next page in instructions.
5. Remove 'Reinforce hull center line with wood strips'. {:-{
6. Put hole in hull! Repair said hole... both of them!
6. Assemble motor mount.
7. Cut myself free from motor mount.
8. Order Superglue de-bonder from Amazon.
9. Figure out running gear..... unable figure out running gear.
10. Put plasters on head wound.
11. Repair overhead video light support!
.... video tomorrow evening. :-))
Post by: coch y bonddu on February 22, 2020, 10:28:53 pm
Er how on earth plasters on Head wound...did you by any chance drop it on your head whilst glueing it together the mind boggles lol
Post by: SailorGreg on February 22, 2020, 11:08:04 pm
You have to suffer for your art - it's part of the fun. Where's the challenge in building a kit where everything went right?
ok2 {-) O0 %% %% %% .......
Post by: Martin (Admin) on February 23, 2020, 08:39:03 pm
Post by: Martin (Admin) on March 03, 2020, 10:59:13 pm
Need to glue an unknown plastic skeg to a wood hull.... any idea of glue to use?
Post by: Taranis on March 03, 2020, 11:04:44 pm
Have you got a spare piece of this plastic to test on ?
Post by: Martin (Admin) on March 03, 2020, 11:31:49 pm
Nope! >:-o
Post by: RST on March 03, 2020, 11:36:58 pm
Go straight for the stabilit express!
...In my xperience the best place for anything from "gorilla" is left on the shop shelf or disposed of at the recycling centre!!
Post by: RST on March 03, 2020, 11:49:13 pm
Is it filament printed parts in that kit. I can't quite make out from the pics? If so I find araldite / devcon epoxy, stabilit express and modelling or industrial CA stick well. The supermarket bottles of Loctite CA don't seem to hold for me. Just a suggestion for later on, I'm printing more and more things now but still mixing with usual materials.
Post by: Subculture on March 04, 2020, 06:06:16 pm
Have you bought out a glue shop, Martin. The Stabilit Express or Plastic welder will be strongest- both modified acrylic glues which will be stronger than the substrates once cured. They can pong a bit though.
Post by: Tug Fanatic on March 22, 2020, 03:58:48 pm
This is now the perfect model for my modelling year as I am told not to leave the house but I do have access to a paddling pool! O0
Post by: SteamboatPhil on March 22, 2020, 04:38:33 pm
Light bulb moment O0 I have a large paddling pool and if I am stuck in the workshop (apart from meals and to make sure steamboat apprentice is still binge watching Eastenders {-) ) a perfect time to do some testing :-)) Well at least can do the washing up then have sail when he finishes (the boat that is) {-) {-) {-) {-) {-) {-)
Post by: coch y bonddu on March 22, 2020, 10:43:40 pm
Any updates really enjoying this one
Post by: Martin (Admin) on March 22, 2020, 11:58:44 pm
Evening! I seem to have reach an impasse at the moment.... but I usually do at this stage, ie. fixing in the motor, stuffing tube & skeg... screw this up and it's a big horrible repair!
( NB: I'll probably be using good old Stabilit Express... as log as that hasn't gone hard too! .... £22 a tube now?!? ) :o :o :o :o :o
In the meantime, I've started that card TID Tug build: https://www.modelboatmayhem.co.uk/forum/index.php/topic,64562.msg685527.html#msg685527
Post by: Big Ada on March 23, 2020, 04:24:01 pm
That Hull reminds me of a Car't Dor Ice cream Tub, what does the Team think?. O0 ;D
Len.
Post by: SteamboatPhil on March 23, 2020, 05:07:02 pm
Now we no why its taking Martin so long.....so what flavour was it Martin... {-) {-) {-) {-) {-)
Post by: Martin (Admin) on March 23, 2020, 05:07:38 pm
Oh yeah! {-) {-) Might have saved myself a lot of bother!
Post by: SteamboatPhil on March 23, 2020, 05:25:17 pm
Oooo this is it< the next mayhem weekend challenge........Martins ice cream tub race.........what do we think {-) {-) {-) {-) {-) {-)
Post by: Martin (Admin) on March 23, 2020, 06:19:19 pm
That's pretty good idea! :-))
Post by: Tugtower on March 24, 2020, 10:55:13 pm
Been enjoying this build awaiting next part with eager anticipation :-))
Post by: Tug Fanatic on March 25, 2020, 10:56:12 am
A useful tip that I saw somewhere was to wrap the hull in a piece of clingfilm/ plastic bag and then you can do whatever ballasting/ layout/ flotation tests that you want to do before finishing the model. Small models have advantages!
Could you fabricate something to avoid using the plastic part? It looks like a tube so it should not be that difficult. Personally I would also be happier if I had not had to search for an adhesive that might/might not work and where I would have doubts every time I put the model in the water.
Post by: Martin (Admin) on March 25, 2020, 11:06:16 am
Thanks TF,
I'll try Stabilit first, I've not fount any solid material it doesn't adhere too as yet.... even if it doesn't bond completely, it will provide a secure enough fillet that I can then secure with superglue.
Post by: Tug Fanatic on March 25, 2020, 11:20:23 am
Don't forget that seriously abrading the plastic surface where you want the glue to stick never hurt.
Good luck.
Post by: Martin (Admin) on March 25, 2020, 11:46:55 am
... and I'm going to cover it with sanitizer hand gel! O0
Post by: Martin (Admin) on March 29, 2020, 10:49:23 am
OK, Part 9 - 'Faffing about with motor alignment'.
I usually like to do this by ear, checking for drive line loading when motor press into mount..... it doesn't go well ! I'm thinking of using a blob of epoxy and letting the motor and mount find it's own alignment..... {:-{
Post by: Tug Fanatic on March 29, 2020, 12:53:24 pm
As you are using a solid coupling have you considered a large blob of silicone sealant to mount the motor? Easy, lets the motor sit how it wants to and you can easily get the motor out if you need to.
I find it easier to ensure low friction by using a very low voltage where I find any difference in load to be much more obvious.
Post by: Tugtower on March 29, 2020, 02:08:26 pm
That shaft unit looks like a very tight fit which maybe the reason why the motor won’t lay flat ( the mount maybe off too)
Personally I would widen the shafts hole in the hull slightly (and elongate it) to allow it to be a looser fit, this will give you wiggle room to get the motor mounted better and the shaft aligned centrally to the rudder more accurately, once in place you can glue down the lot permanently with some epoxy to seal.
Just my 2 cents
Post by: Martin (Admin) on March 29, 2020, 02:48:29 pm
Yes I was thinking of the Silicon 'blob' option, but doing it with slow set epoxy.... 'cause that's what I have around at the moment! ( I have a theory that all glues, silicon etc, all stay fluid until a week before they detect you need them! )
The mount just doesn't seem to be at the right angle up/ down as appose to port / starboard.
Post by: Subculture on March 30, 2020, 12:00:06 pm
Epoxy won't work in the same way, as it lacks the softness of silicone rubber to absorb vibration.
Post by: Martin (Admin) on March 30, 2020, 01:44:35 pm
OK, so I've gone with the silicon sealant ....... only trouble is this silicon takes 24 - 72 hours to set. Should have checked that beforehand! Luckily I did remember the the silicon that smells of vinegar, instantly corrodes any metal near by and I removed the motor etc.
(https://i.ibb.co/CJXmDWY/P1280626s.jpg)
(https://i.ibb.co/MBbGt9f/P1280617s.jpg)
(https://i.ibb.co/hcMfb6F/P1280620s.jpg)
(https://i.ibb.co/zhxYb57/20200330-133104s.jpg)
Post by: Martin (Admin) on March 31, 2020, 08:53:12 pm
Today, finally gluing in the skeg!
Project Counters: Dropped stuff of the bench = 5. Total =26 Banged my head into camera & lighting gear. Today 4. Total = 17
Post by: Martin (Admin) on April 01, 2020, 06:15:15 pm
OK, all glues set.... unfortunately, something must have shifted, while clamping I guess.... {:-{
Anyway, not too bad, just a quick bit of fettling with a mini drill ( lower the arf end of the motor ) and alignment regained. :-)
Title: Re: Martin builds the Q1 Mini Logging Tug - Part 11
Post by: Martin (Admin) on April 14, 2020, 05:51:44 pm
Part 11 - Siliconingin the motor mount - Round 2!
Project Counters: Dropped stuff on the floor - Today 5. Total 26 Banged my head into camera, lighting gear - Today 4. Total 17 New bits of camera gear just for this project - This week 3. Total, a very expensive 12!
Title: Re:Q1 Mini Logging Tug - Part 12
Post by: Martin (Admin) on April 14, 2020, 06:24:09 pm
Part 12 - Lower rudder bracket / prop guard thingy!
Project Counters: Dropped stuff on the floor - Today 2. - Total 28 Personal Injury's 2 - Total 6 Banged my head into camera, lighting gear - Today 5. - Total 23 New bits of camera gear just for this project - This week 4. Total, a very expensive 16!
Post by: Tug Fanatic on April 15, 2020, 09:11:03 am
Martin
The structure of these kits seems very complicated and must make the already limited internal space even smaller. I have also asked this question in the Q3 thread to see if there is any difference
What thickness ply do they use for the Q1 kit?
Post by: Martin (Admin) on April 15, 2020, 10:09:46 am
It looks complicated but;
1. I'm ham-fisted! 2. It's self jigging, 3. Same as the Q3,ie. 3mm
Martian ok2
Post by: Tug Fanatic on April 15, 2020, 10:19:01 am
I NOW know why TugTower said; "Been working on the detachable part of the skeg for rudder access today....." {:-{ https://www.modelboatmayhem.co.uk/forum/index.php/topic,64715.msg687467.html#msg687467
Possible fixes that present themselves to be are: 1. Break it free and fit the rudder and not tell anyone, 2. Bend it a bit, fit the rudder and try and bend it back leaving the rudder pertinently in place, 3, Cut down the 'up' bit so give me more fiddle room,
I don't like option 2... i doubt i could do cleanly but I do want to paint the hull first.
I hoping you guys & girls will have other / better ideas? :embarrassed:
Post by: RST on April 16, 2020, 10:45:00 pm
Hi Martin. You won't be able to bend the brass out to fit the rudder then bend it back. You'll need to bend the metal back further than the rudder would allow so it can spring back straight.
*Probably* bending metal and straightening is actually my job.
I would break the bond, clean-up and re-fit. I had same scenario on my mini loyal build. Did it all right and committed but forgot to fettle the prop so the boss is too close to rudder leading edge. Dooh!
Post by: Tugtower on April 16, 2020, 11:34:27 pm
Hehe foresight is a gift, now you see why I opted to not buy the running gear 😉
Post by: Tugtower on April 17, 2020, 01:37:16 am
Best suggestion.... remove the guard then make a detachable one like i did from scratch...
You know it makes sense lad :}
Post by: tsenecal on April 17, 2020, 02:47:52 am
pin the rudder to the tiller post so it (the tiller post) can be separated from the rudder? pull the post, remove the rudder...
Post by: Big Ada on April 17, 2020, 04:02:51 pm
I can see Canterbury Coxswain is getting worried now. O0 PS, see post 30.
Len.
Post by: Martin (Admin) on April 21, 2020, 01:46:51 pm
Morning All ! :-)
Still working on my tug..... Yesterday, I spent 2 hours looking for the servo support bracket... only to work out that the wood pack supplied is different to the instructions. >:-o
Post by: Tug Fanatic on April 21, 2020, 10:35:23 pm
Thank you Martin.
Post by: warspite on April 22, 2020, 11:49:39 am
On the plans above, what is the item left of the description on the actual first sheet, it says Qtug V2 and then 2 cradles above it, then the item, it appears to have 4 holes, with room for a cut out to suit a servo possibly
Post by: Martin (Admin) on April 22, 2020, 12:04:00 pm
Hey Warspite! All right? :-)
Having a third look, these are the actual laser cut sheets in the box, again different from the plans and listing photos....
These are my sheets.... the bits circled "seem" to be the servo mount.... 1 mm ply, good choice! ;D
Post by: warspite on April 22, 2020, 12:23:48 pm
Reply #85 appears to be different to the sheets you show, for instance the parts circled in the last photo appear to be closer to the edge than on #85, oops - sorry cabin fever, didn't read the text properly, as you said again different from those in #85
Post by: Martin (Admin) on April 22, 2020, 12:53:57 pm
Utube update soon.... I must say, I'm really am a crap builder! {-)
Post by: Martin (Admin) on April 26, 2020, 06:47:54 pm
Part 13 - Rubber shaft and fittings
Project Counters: Dropped stuff on the floor then can't find them - This week 4. - Total 32 Personal Injury's 1 - Total 7
Post by: Martin (Admin) on May 03, 2020, 05:28:28 pm
Evening all!
Struggling a bit with the rudder linkage here....
There's not enough room to get a full +- 45o throw and I've stripped the gears of this servo already!
I'm thinking a pulley system....... or a double arm 90o bell crank.... I've seen a slot and pin mechanism somewhere, .... any other ideas?
Post by: coch y bonddu on May 03, 2020, 06:20:25 pm
Looking at the pics the only ondervation i v Can make is the following
Buy new decent micro sero Set the arm of the servo to the middle of it's arc Cut down the throw of the servo with your transmiter if you can not do this then maybee a serbo limotrr of some sort to limit it's travel poss an action servo morph....what i personaly think has happened is that it has gone hindge bound...in other words rudder can not move any further but servo can hence stripped gears....just my 2p worth
Post by: GG on May 03, 2020, 07:34:45 pm
Martin, Can you swap the servo around in its mount? Assuming you fit the servo and tiller arms square to the linking wire (which ought to be done for even rudder throw), then this would increase the angle between the linkage wire and center-line of the hull and give you more space between the tiller arm and hull.
Also, do you really need 45 degrees of rudder movement? Moving the connector one hole inwards on the servo arm looks like it would still give you enough moment. Glynn Guest
Post by: Martin (Admin) on May 03, 2020, 09:23:25 pm
"Buy new decent micro sero" - I crashed past the 'normal' ends stops via the use of a servo test - video in edit.
"do you really need 45 degrees of rudder movement?" - I think your right GG, I think Ron Dean once told me, 'that past 30o, your rudder act more as a brake than steering'.... did I remember that right?
Post by: tsenecal on May 04, 2020, 12:18:07 am
"Buy new decent micro sero" - I crashed past the 'normal' ends tops via the use of a servo test - video in edit.
i remember it as 35o but either way, it is much less than 45o
Post by: Martin (Admin) on May 04, 2020, 12:22:08 am
Post by: Martin (Admin) on May 09, 2020, 04:48:46 pm
Part 14 - Servo and mount - Round 1
Project Counters: Dropped stuff on the floor - This week 7. - Total 39 Personal Injury's 1 - Total 7 Glued myself to stuff 3 - Total 12
Post by: SailorGreg on May 10, 2020, 03:15:39 pm
Wow - that debonder is fierce stuff. I confess I did have a little chuckle when the servo started to fall apart, sorry Martin. But it was quite funny.
Greg
Post by: Tug Fanatic on May 10, 2020, 03:48:40 pm
What on earth is in that debonder? There must be a use for that beyond its intended purpose.
Did the plastic "dry" and become hard again?
Post by: Martin (Admin) on May 10, 2020, 11:06:10 pm
I kept the guts, the rest went to landfill... in the ocean?!
and this is why i hate and never use "servo testers"... the servo tester is obviously overdriving the servo... you would never get that level of throws from a transmitter, and more importantly, you would be able to adjust the endpoints with the transmitter so that the rudder never moves more than 35 degrees port or starboard, regardless of what the servo is actually capable of.
Post by: Martin (Admin) on May 25, 2020, 05:12:35 am
Q1 Mini Logging Tug build - Part 17
RUDDER SERVO and Linkage - Round 4 !
Post by: SailorGreg on May 25, 2020, 12:24:55 pm
Getting there Martin, slow but sure - but what are you doing posting at 5am? Can't you sleep?? Greg
Post by: Martin (Admin) on May 25, 2020, 01:27:18 pm
What do you mean "slow"?!?!?! >>:-(
I once did a 1,000 piece puzzle in less than a week....... on the box it said '5+ years'! {-)
Post by: Martin (Admin) on May 28, 2020, 02:03:19 pm
Do you think I'll get away with springs for Rudder Linkages?
Post by: Martin (Admin) on May 30, 2020, 07:50:33 pm
Catching up on videos - What's your choice for linkage material?
Linkage Choices
Project Counters: Dropped stuff on the floor can't find it: 6 - Total 49 Personal Injury's:: 2 - Total 13 Glued myself to stuff: 2 - Total 16 Bad Ideas: 6 - Total 300
Post by: Martin (Admin) on June 01, 2020, 05:24:37 pm
Radio Sophophobia ..... ( Turnigy TGY-16s 2.4GH computer radio )
Post by: Martin (Admin) on June 01, 2020, 07:28:27 pm
Part - 19
Assembling the other internal radio bits
Project Counters: Dropped stuff on the floor can't find it: 4 - Total 52 Personal Injury's: 0 - Total 13 Glued myself to stuff: 3 - Total 19 Bad Ideas: 1 - Total 301
Post by: Martin (Admin) on June 01, 2020, 11:29:26 pm
Project Counters: Dropped stuff on the floor can't find it: 2 - Total 54 Personal Injury's: 0 - Total 13 Glued myself to stuff: 0 - Total 19 Bad Ideas: 3 - Total 304
Post by: Martin (Admin) on June 06, 2020, 12:56:09 pm
Part 21 - Rx layout & New HobbyKing / Turnigy / FlySky i6S
Project Counters: Dropped stuff on the floor can't find it: 2 - Total 54 Personal Injury's: 0 - Total 13 Glued myself to stuff: 1 - Total 20 Bad Ideas: 1 - Total 301
Post by: Martin (Admin) on July 04, 2020, 03:08:40 pm
Still plugging away at the kit.... a few photo of upcoming videos:
(https://i.ibb.co/WtZgQq7/Q1-11.jpg)
(https://i.ibb.co/gZG6YCH/Q1-03.jpg)
(https://i.ibb.co/2gtV38r/Q1-04.jpg)
Post by: Martin (Admin) on July 04, 2020, 03:09:39 pm
Post by: Martin (Admin) on July 19, 2020, 07:38:30 pm
Right.... OK..... where was I again?!
Oh yes, radio modifications..... I ended up with this!
I decided that the TGY-i6s was too nice a radio to hack up and probably modify beyond to 'return to factory'. The new radio transplant victim is a HobbyKing 2.4Ghz Mode 2 4Ch Tx & Rx V2 - Price: £23.26 .... cheap enough to wreck and not cry about it!
Title: Re: Martin builds the Q1 Mini Logging (Dozer?) Tug
Post by: Martin (Admin) on July 19, 2020, 07:52:00 pm
Not Really! :}
It's something I used to do from years ago, open up the Rx and cover the guts with wax - the original conformal coating! ..... but all I could find in a draw was an old red tealight... with Glitter! ( remember when we were kids, Mum would ALWAYS have a box of white candle in case of a power cut. (.... 60's kid! )
Powered it all up, works like a charm! ( With hindsight, I should have tested the radio straight out of the box first... got lucky again this time! ) ;D
Post by: Martin (Admin) on July 19, 2020, 08:29:01 pm
The hull is basically finished now, last job ( yeah right! ). I'm adding the rubbing strip / fender band / strengthener ring?! It's a 1mm x 5.5mm styrene strip, superglued on, hull rubbed back to bear wood.
Post by: Martin (Admin) on July 19, 2020, 08:37:50 pm
The deck plate was basically a 98% bespoke without any trial fits! :o Just a bit of sanding an edge here and there and it was golden! Combing strips easy install. Trail fitting the mini bulwarks....
Post by: Martin (Admin) on July 19, 2020, 08:51:15 pm
Wheelhouse next, here masking off the deck opening; 1. so I don't glue wheelhouse to the deck, 2. a spacer so wheelhouse doesn't fit too tight. ( Spoiler alert: It is too tight! )
Post by: Martin (Admin) on July 19, 2020, 09:05:52 pm
I tried to be clever ( rushed it a bit ) and glued / build the wheelhouse in place over the combings, 'school leaver' mistake! It didn't fit properly at all, too short and I thought I had trashed the parts but to my surprise, the superglue snapped clean with no damage to the plastic. ... a good thing too, I got it wrong three more times! ..... very poor instructions, poor diagrams and my tools are rubbish too! %)
So as long as it takes and no matter how fiddly it is, tape the pieces together, in place before gluing. NB: Some butt joints go inside some go outside.... sigh...
The trials and tribulations of building models Martin {-)
Post by: Martin (Admin) on July 19, 2020, 09:22:00 pm
After a long and angry fight with the wheelhouse, I sort of got it all together. .... sorry no photos or video, it's hard to use a camera whilst you're raging!
Bulwalks in place too... curved bits down the front are the bulwark cappings.
Post by: Martin (Admin) on July 19, 2020, 09:54:15 pm
Next, how bad can you be at spray painting?!
( ... rhetorical question! <*< )
(https://www.modelboatmayhemimages.co.uk/images/2020/07/19/20200718_203853.jpg) (https://www.modelboatmayhemimages.co.uk/image/ZVyjG) ( Don't tell Stavros about this, I'll never hear the end of it! ) ok2
Post by: Martin (Admin) on July 22, 2020, 09:48:46 pm
Well a couple of hours of sanding, scraping and mutterings later, the effected parts are all cleaned up ... well as much as I need anyway.
I think I know what went wrong this time round, I'm using Halfords Plastic primer, it much thicker than I expected, dries slower, resprayed too quickly ....... and I think i got sweat on to some bits. {:-{
So, are isopropanol, Turps, Meths or Lighter fuel.... all OK as panel wipe on plastics?
Post by: derekwarner on August 02, 2020, 01:18:00 am
Martin....do you know the type of synthetic [plastic is a big group of many variants] parts supplied in the kit?........the first spraying attempt appears as th epaint too thick or too many coats too early :o , the last attempt suggests static electricity dust attracted to the parts {:-{ or did you use double sided tape to hold the parts?......if so a possibility is the solvent fume in the paint has reacted with the tape & released a gas particles that have attached to the parts?
Get the bamboo kitchen Chopping board.......drill 50 x 1/16" diameter holes in random positions & blow out the dust ...spray board with IPA & let dry....try supporting the items on a bent Bobby pins.........
These days, Methylated Spirit is grain based and ever after evaporation and condensation still contains a trace of synthetic oil >>:-( ...so after a gentle washing in warm soapy water [kitchen dish washing detergent], then blow dry followed by an aerosol pump spray of 99.8% IPA.......then a warm burst from the family hair dryer...the parts elevated on the pins in the boards will assist with drying.....
Finally try the spraying in the bathroom....[tiles & low dust environment].....[maybe wait until Mrs Davis is at the shops O0
Post by: Martin (Admin) on August 02, 2020, 07:14:04 am
I still keep a wicker basket on top of one of my kitchen wall cupboards. It's contents are a box of candles, 2 boxes of matches, a ciggy lighter, & a couple of those plastic glo-sticks.
Alongside the basket are 3 enamel 'Wee Willie Winkie' candlesticks, which were the only lighting upstairs at my grannies until she died in 74. Those too all have candles in them & a box of matches in the bottom.
