Technical, Techniques, Hints, and Tips => Wood Care: => Topic started by: rich_morris on May 24, 2020, 08:05:00 pm
Title: Sanding sealer reaction with adhesive?
Post by: rich_morris on May 24, 2020, 08:05:00 pm
Hi all,
I've just helped my son paint the inside of his boat with sanding sealer, to waterproof it.
Now, we may have gone a bit heavy with the sealer, but it looks like the sealer may have affected the glue? It, looks like it's gone white in places? Maybe softened it a bit too?
The glue is deluxe materials aliphatic resin. The sanding sealer is deluxe materials sand n seal. Neither product mentions a risk to the other.
Have I done something wrong, or will it all dry out, and garden up over time? Could the joints be weakened? {:-{
Thanks for any advice...
Title: Re: Sanding sealer reaction with adhesive?
Post by: Gardener on May 24, 2020, 08:10:21 pm
Why not give deluxe a ring and ask their advice as they are both deluxe products, they should know best ...
Post by: Gardener on May 24, 2020, 08:19:44 pm
could be just over thick sanding sealer as sealer is white ...
Post by: Colin Bishop on May 24, 2020, 08:27:36 pm
The two products are waterbased and should be 100% compatible with eath other. I really wouldn't worry and I use both.
Post by: rich_morris on May 24, 2020, 09:00:52 pm
Thanks all, I'll maybe drop them a message just to check!
Looks like the joints may be during back to clear again.
I'll go lighter with the second coat!
Post by: Colin Bishop on May 24, 2020, 09:06:12 pm
That is what can happen with acrylic. If you wet it then it turrns milky until it dries out if it isn't already 100% cured. Same thing happens with acrylic varnish and paint.
Post by: rich_morris on May 25, 2020, 07:02:49 am
Hi All,
Deluxe materials got back in touch with me, they say that I do not need to worry, and that maybe the aliphatic resin hadn't dried fully.
I'm a bit surprised, as some of it had been on the boat for a couple of weeks.
The whiteness has gone overnight, but the yellowish colour is still noticeable. The painted glue still seem a bit soft. I can push my nail into it.
I'll leave it for a day or so to see if it fully re-hardens.
