Technical, Techniques, Hints, and Tips => Glue etc. => Topic started by: Blaven03 on August 13, 2020, 09:58:48 pm
Hello,
Hope every1 well in current climate?
Has any1 got any suggesting for a good adhesive to bond materials to vac formed hulls (Parat Hull).
Any help appreciated.
Stabilit Express
Agree with Martin. It is what Graupner advised for building all their moulded kits and works very well. It is a bit pricey though and comes as 2 parts which have to be mixed into a paste before use. While not as convenient as some it does work. I have also been introduced to a superglue recently ( hate the stuff normally as I am the only thing most of them seem to stick to anything) which seems to work very well on plastics. It is Screwfix's " No Nonsense" . I have been trying it on 3D printed plastic parts which can be very tricky to fix and it works well , particularly on the ABS filament bits.
Whatever you decide to use - be sure to roughen the surfaces to be glued, this gives the glue a surface to grab on.
I got to ask what are the materials (not sure what is used for Parat)? ABS or PS to the same material then solvent such as MEK / Limonene / Dichloromethane as sold in the Tamiya / EMA etc. bottles, rather than any plastic "cement" from Humbrol or Revell etc. or other "adhesive", is a complete no-brainer. For plastic to something else, or to fill gaps then you have to use some form of bonding / cement. I like the aforementioned Stabilit Express also (often called Stability Express now). I've not had cause to use the "no more nails" / "stixall" / "sticks like s***t" stuff yet, particularly as it's sold in such big tubes compared to what I need but not to say it's no good for some folk in other applications. As other said though, whatever you use: always rough up surfaces as far as possible and de-grease for best results.
This stuff? - https://www.screwfix.com/p/no-nonsense-solvented-grab-adhesive-350ml/7454d
(https://media.screwfix.com/is/image//ae235?src=ae235/7454D_P&$prodImageMedium$)
No, this
https://www.screwfix.com/p/no-nonsense-superglue-50g/79181 (https://www.screwfix.com/p/no-nonsense-superglue-50g/79181)
Good Morning,
Thanks very much for input.
The hull of Parat is fairly thin and flimsy. The plan is to mount another base at the bottom internally (probably a hard nylon plastic) to make a rigid base to fit Units and skeg to. Just wasn’t sure best adhesive.
Regards DJ
Buy a tube of Everbuild Stixall or Evostick sticks like sh--t .Both of these wiil do the job
