Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: barriew on May 11, 2021, 04:13:52 pm
Title: LiPo/LiFe battery for Turnigy i6 TX?
Post by: barriew on May 11, 2021, 04:13:52 pm
Has anyone converted a Turnigy/Flysky i6 Transmitter to use a Lipo or LiFe battery pack?
Anyone know if its possible?
Barrie
Title: Re: LiPo/LiFe battery for Turnigy i6 TX?
Post by: JimG on May 11, 2021, 08:43:07 pm
From the manual the transmitter voltage is 4.2 to 6V. A 1S Lipo or LiFe is too low a voltage and a 2S has too high a voltage. It could perhaps be done by using a 2S pack and a 5V BEC but would require a lot of modification to the battery box or fit an external battery box wired into the transmitter. Woukld also need an external low voltage alarm as the onboard one can't check the battery.
Jim
Post by: barriew on May 12, 2021, 06:30:02 am
Jim,
Thanks for your reply. A member of our club asked the question and I didn't think it was possible but wanted to check.
I use normal alkaline cells and have no problems, I think he is using rechargeable NiMh and claims he doesn't get a long use. Due to Covid I haven't been able to meet him to check what he is using.
Barrie
Post by: Subculture on May 12, 2021, 09:43:55 am
I expect you'd be fine with 2s LiFE- they have a lower cell voltage than lipo, at around 3.2-3.3v, giving 6.4-.6.6v respectively.
Post by: JimG on May 12, 2021, 12:48:16 pm
A fully charged LiFe cell is 3.65V giving a total of 7.3V for a 2S pack. While this will drop to a nominal 6.4V with use the initial voltage may damage the Tx which is maximum 6V.
Jim
Post by: justboatonic on May 12, 2021, 02:17:18 pm
Barrie
https://youtu.be/Ln6hztrJgnc
Post by: Subculture on May 12, 2021, 02:26:17 pm
Plenty of modellers using 2s lipo on this TX, but if you're concerned about cooking the board, then just wire in a 6v BEC to brickwall the voltage. The main thing you want to be careful of is running the battery too low and knackering the cells. Fit a lipo alarm if the TX doesn't have one.
