Technical, Techniques, Hints, and Tips => Microprocessor control => Topic started by: Dainesh on August 09, 2021, 10:01:07 am
Title: pic ESC for servo motors
Post by: Dainesh on August 09, 2021, 10:01:07 am
Hi Gewts,
I'm in a smaller project.
I have a 1/350 Trumpeter Viribus Unitis, and I was searching for small motors for it, until I saw the motors in the 9g micro servos.
I thought that I can use two servo motors to drive the two shafts from four.
I put the motors in with the controlling circuit and it was OK.
Now I would like to cotrol the both servo motors from the same signal, plus mix the left/right signal in it.
Title: Re: pic ESC for servo motors
Post by: Dainesh on August 09, 2021, 10:06:33 am
Here is the photo  ok2
Post by: xanthar on January 12, 2023, 09:20:35 pm
I'm curious how this worked out?
I'm guessing that these are continuous rotation servos?
Do they rotate fast enough to drive a small prop well ?
Post by: roycv on January 13, 2023, 04:09:52 am
Hi when using standard servos as drive units it is usual to disconect the motor from the gearbox and drive a prop direct.  You are on new ground with this size servo.
Interested to know the outcome.
Roy
