Technical, Techniques, Hints, and Tips => GRP & Epoxy => Topic started by: Trucker on February 13, 2023, 06:00:57 pm
Title: moulding catylist v laminating catylist
Post by: Trucker on February 13, 2023, 06:00:57 pm
Hi Guys
Im having a bit of a moulding interest for a part i want, but, it seems the catylist for my rubber mould has gone walk a bouts, but i do have some laminating catylist so wondering will it work to make my rubber mould ?????
Trucker
Title: Re: moulding catylist v laminating catylist
Post by: nemesis on February 14, 2023, 04:26:36 pm
NO, two different beasts.nemesis
Post by: Trucker on February 14, 2023, 04:55:15 pm
That put that one to bed nice and quick,
many thanks, again
Trucker
Post by: Trucker on February 22, 2023, 05:51:53 pm
Hi, All
Another question regarding my molding of a few scale lights, all the molding stuff has arrived but i now have a bad vibe regarding my little masters ive made up, i made them from plasticine,im a little concerned the rubber molding will attack the plasticene. if this is a non starter whats the recommended stuff to use, the size of each one is 12mm long 7mm wide and 10mm thick...
Trucker
Post by: nemesis on February 23, 2023, 12:00:02 pm
Hi Trucker, silicone cures without heat, I have never used plasticene for a master, basically you cannot get the sharp detail I require. For nav lights I get a length of perspex from the plastics firm that I use, to the diameter I require and turn them off in the lathe. failing that I used a silicone mould and clear casting resin. Make far more that you require because when you go back to use it again it will have gone off. It is a shame that you have to buy the minimum quantity and even that is too much for the task in hand. nemesis
Post by: Trucker on February 23, 2023, 07:23:06 pm
Thank you for your wise wisdom nemesis. im glad i just didnt plough into this, it probably all would have gone to land fill, my project for the molding is a hand full of small lights around the bridge to illuminate the deck work area, plan is to embed a LED into the clear resin and have these working.
Trucker
