Dear Modellers
I thought that you might like an update from Farcet and to let you know what is new to the DEANS MARINE range.
The Trumpeter 1/200 scale ships are taking the model world by storm with the incredible detail on the mouldings and the brass etched parts. Large enough for radio control, but the thought of purchasing one of these expensive kits, cutting and chopping the hull around, and then trying to find the necessary working parts that would keep the scale appearance some find very risky and some insurmountable.
To this end we have added to our motorising range a complete set of parts to motorise all of the Trumpeter range of kits.
The latest release is the famous Scharnhorst 1/200 kit of this famous battle cruiser, in single screw format, twin screw format ( the most popular), or triple screw format.
For the Scharnhorst the running kit is very comprehensive and contains specially produced 2mm shafts in slimline tubes, 2 bearings, and a collets so modellers can 2rin M4 standard threaded propellers, props are cast warship high efficiency type, cast metal runners A frames for 2mm mm bearing, as a example to a twin screw set contains following:
Running Kit consists of
2 x KYTE Motors
1 x TWIN Motor Mount vacformed
2 x Capacitors
2 x Brass tube bearing tubes =22mm x 2mm
2 x 2.3mm / 2mm Nycrome EXL couplings
2 x Propshafts 150mm tube / 240mm shafts
2 x 2mm Shaft Collets
2 x Cast metal A frames
4 x 2mm Nylon thrust washers
1 x 162-11 3 blade warship prop
1 x 162-12 3 blade warship prop
2 x 2mm Rudder bearing tube 22m x 2mm
2 x Cast metal rudder rudder
1 x Nylon Tiller arm TA-5 - TA-6
2 x Nylon washers
2 X MOTOR CLAMPS A42
2 X FIXING SCREWS M14
1 x 120mm 502 piano wire Z bend 1 x 25mm Z
4 x 1” D/S MOUNTING TAPE
LASER CUT 1.5MM PLASTIC
1 X SERVO MOUNT
2 X BATTERIES BOX FRAME
2 X SHAFT SUPPORTS
2 X M/mount stiffeners
1 x rudder tube support
1 x C/d build pictures of test model
The single screw and the triple screw set contains the same parts but altered to fit the appropriate running gear assembly.
We also have in the range sets for all of the Trumpeter 1/200 scale models such as Bismark, Missouri, Hood, Nelson. etc
see our website for full details of the running gear sets.
The Bismark set on trials can be seen on You Tube DEANS MARINE - BISMARCK 1/200 SCALE MOTORISED TEST RUN 13/12/12 (https://www.youtube.com/watch?v=mBdqpMoGc2o&t=17s) (2 min 46 sec) | | Regards
Deans Marine
