Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: terry1956 on May 11, 2023, 07:11:12 pm
Title: How do you slow a servo down
Post by: terry1956 on May 11, 2023, 07:11:12 pm
Hi out there, I have a club 500 and the rudder action is just far to fast. I am using a cheaper flysky transmitter and I don’t think that I can adjust the servos by adjusting the transmitter. So how can I slow the rudder action down. Thanks
Title: Re: How do you slow a servo down
Post by: Andyn on May 11, 2023, 07:19:35 pm
Not sure why you’d ever wish to slow down a rudder servo. What you’re after is adding exponential, which will soften the rudder inputs around centre stick. Which tx is it?
Post by: DocMartin on May 11, 2023, 07:56:22 pm
Slow Servo
https://www.aliexpress.us/item/2255800085366134.html?gatewayAdapt=glo2usa4itemAdapt (https://www.aliexpress.us/item/2255800085366134.html?gatewayAdapt=glo2usa4itemAdapt)
Something such as this might work for you.
DM
Post by: DocMartin on May 11, 2023, 08:05:51 pm
Similar devices can be sourced locally (UK) via eBay
https://www.ebay.com/itm/352752970945 (https://www.ebay.com/itm/352752970945)
Post by: Andyn on May 11, 2023, 08:09:42 pm
It will slow a servo, but that is not going to produce a desirable effect on a model, especially something like a club 500.
For example, releasing the stick on a straight out of a corner will always cause a vast oversteer
Post by: Martin (Admin) on May 12, 2023, 03:45:05 pm
e.g. Slow down the guns training on target, on big battle wagons
