Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: Neil on August 14, 2024, 02:39:47 pm
hi all,
whilst having a clearout I found two transmitters that if remember were given to me some time agoone is an old classic Digifleet [presume 40mhz] 4 CHANNEL [I think] transmitter.
no idea what it is worth, but if someone makes a decent donation to Cancer Research I will post it to mainland UK covering cost of postage 2nd class.
The second tx is a 27mhz 2 chanel Hitec with tx crystal............same goes, a donation to Cancer Research and ill pay postage.
Thank you all.
if admin feel this should be in for sale, please adjust accordingly. thanks.
Hello Neil the Fleet one is 40 Mhtz FM and the top switch on the left (aerial edge) looks like it has a throttle / mixer built into the Rx.Nice I have one so will pass this by.
Roy
cheers for the info Roy.....any info helps if someone wants it. :-))
You'll find Fleet and Futaba crystals are the same so you can use or test it with Futaba and Corona gear.
A six channel Fleet transmitter would be great for a sub user on its own if they own a synthesised ( no Rx crystal needed as it binds to 40 Mhz Tx)
This is just for info to boost sale value. I've enough 40 MHz gear.
thanks for thje info.....have 5 sets of 40 meg myself but as this is pretty vintage and you have witnessed my total lack of ability to sort out modern stuff on the other thread, just thought that a donation to cancer research someone might want it to fiddle with.....i'll give ity a week or so n if not put it on ebay with all proceeds to them. least i can do for the way their research saved me last year.
The Fleet systems are great and I use mine regularly. One thing you should take care about is the Derek Olley the designer and owner of Fleet adopted a different order of wiring for servos and so for the receivers. The order of the wiring for Fleet servos / rx's is red - black - yellow (or signal).
The accepted and usual order is black - red - signal. If you inadvertantly connect a 'standard' servo it instantly kills the rx. I know to my cost!
The transmitter works as normal with standard 40Mhtz FM receivers. Which is what I do.
You will need to consult the manual to set up the transmitter for different models if that is a requirement, but it is quite easy.
Roy
The NiCd battery cells will need cycled a couple of times which needs a mention in an Ebay sale.
I've repaired & customised dozens of RC sets, including Fleet, and can tell you and the prospective Tx buyer that the rugged case might superficially resemble a 60s and 70s era Futaba M Series Tx, with its discrete component encoder, but this one has modern electronic circuitry.
They are easily serviced and expanded to seven channels by an electronics hobbyist with all the required knowhow reachable via Google and Modelboatmayhem forum.
