The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: Andy-H on January 22, 2025, 09:43:24 pm
I have a Stuart large tank, and the filler valve is leaking gas. I have a new one on order, as well as the tool, but was hoping to get a little tutorial here on how to remove it, as I don't see any instructions for that anywhere. Or maybee my google-fu is weak, either way. It appears that you have to turn it, but does it thread out, is there a trick? I assume it will make more sense when I have the replacement valve in hand, but I have a while to wait and curiosity is gettting the better of me.
They are usually the Ronson type filling valve, which is screwed into a threaded boss. The tubular tool sits over the top of the valve and two small lugs sit into the slot on either side of the spindle.
I make a tool by grinding a slot into the end of a flat bladed screwdriver.
This is what the valve and the tool look like:
https://www.ebay.co.uk/itm/174923311962?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D279311%26meid%3Db54018f74ed748df85a8fb9278f86561%26pid%3D101506%26rk%3D9%26rkt%3D10%26sd%3D263561284497%26itm%3D174923311962%26pmt%3D0%26noa%3D1%26pg%3D4481478%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecall%26brand%3DRonson&_trksid=p4481478.c101506.m1851
Thanks for that link. That's kind of what I figured it looked like, but I didn't realize the threads were so long. I have the valve in my tank turning, apparently, but perhaps I need to turn it more before the threads are dis-engaged...
So, I made a tool. Turned the valve.. and it didn't come out. Then I realized, being the mechanically oriented person that I am, that there might be an o ring or some such.. so I got a small pair of tweezers and sure enough, it pulled right out.
I think my issue is obvious... well, with my gas tank, anyway, and of course, now I have part of the valve rattling around inside my fuel tank forever.
So, there should be a picture here.. not sure why it's not appearing...
(https://photos.smugmug.com/RC-subs/i-tP3mmtq/0/MDgMFmXVLsKz6jtQ5gmpJ6cWvxDcPNcFfPB2Q2JrQ/X3/20250124_170202-X3.jpg) (https://a65l.smugmug.com/RC-subs/i-tP3mmtq/A)
(https://www.modelboatmayhem.co.uk/forum/[url=https://a65l.smugmug.com/RC-subs/i-tP3mmtq/A]https://photos.smugmug.com/RC-subs/i-tP3mmtq/0/KZfQLsXnwmrgwVJ2mLCQQkjh7SZHsfqf3nhd8CTpM/X2/20250124_170202-X2.jpg[/url])
Check if the original filling valve is just screwed in too loose before replacing. I had this on one of my gas tanks.
A tidy little package showed up today from the Royal Mail, with a new valve and a very professional looking removal/install tool. Hopefully that sorts out my issues...
