The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Rob47 on April 01, 2026, 02:14:22 pm
As many know building an aircraft carrier can be dictated by available scale of aircraft. My QE has air win printed in 1/96 but as 3d printed they have solid caopies, so question any suggestions paint solid to make it look like a clear canopy?
In 1/96 scale painting them gloss black with a few pale blue squiggles can work quite well. Almost by definition the aircraft will be some distance from viewers when the ship's afloat anyway.
Kits
Yep have done that and found a coat of mask ol? helps as well. As you say hard to tell once on the water and this build though big is fun not exhibition level
Just a thought for the future.
You can 3d print clear plastic. If you printed the canopies seperately in clear, and printed the fuselage with the canopy area cut out, in a solid. Then glue together.
Hi Rob, :-))
This is my method I use, for helicopters Aluminium mixed with a bit of black, aircraft I use Aluminium mixed with white.
Easy if you?re doing the printing and what you say makes sense, but these are commercial items
Hi Rob, :-))
Dave any particular manufacturer for the aluminium paint, will give it whirl
Rob,
TAMIYA paint
A very soft pencil, e.g. 5B or 6B, can give quite a good effect, with a small amount of shine.
Rob,
TAMIYA paint
Last one Dave :o Matt, gloss or satin?
Rob,
Aluminium flat
Black gloss
White gloss
This I find gives a satan effect. If you are looking for a shinny effect I?ve use I the past on cockpit instrument panel which is a clear coating which I also use for keep clear cockpit canopy?s clear.
it Dries perfectly clear, And Gives a glass like appearance. Just have to be careful not to shake the Jar and create a bubbly froth
