Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: 6705russell on February 01, 2008, 08:17:30 pm
Hi all,
I have a constant problem that is not going away?
My Thunder Tiger Neptune is suffering from some sort of electrical problem in that whilst in the water under forward motion it cuts out now and again momentarily but on dry land i have no problem, both motors are fully suppressed, i have changed the supplied speed controller to a Mtroniks Viper and i have routed the reciever aerial away from all power leads and main battery is fully charged at 12.80 volt. As anyone else had this problem with a sub? It only cuts out for a second or two and then starts up again but only when surface and submerged running
Many thanks
Russ
Have you done a range test/check?
When i started to have problems down the lake i pulled the sub out and stood it on dry land and walked 20 odd metres away and it did not cut out?
Could you have a broken wire (inside the insulation) that makes and breaks when the boat is in motion?
They are a b****r to find (speaking from experience with an old car)
Just a thought
Cheers and good luck
Doug
Hi, iv read else where that other people have had this trouble as well so your not alone ;)
all the best
