The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: FullLeatherJacket on April 18, 2008, 11:43:36 am
Hi Guys
One of my customers has sent me a query about fitting out this model, which he has inherited and wants to get running for his grandson. He says:
"The launch is an "Elance" Electric Launch from an old Marine Modelling free plan, & is approx 33" long x 5" beam, so it shouldn't need much power. It has a single propellor.
It had a 380 motor in it, but that looks a bit on the big side. There is also a Hunter Systems Type 9 12 volt motor with it which is physically smaller. It doesn't say what current it draws.
I seem to recall that he said the original was powered by a cassette player motor."
Does anyone have any information about this model? 33" x 5" seems a bit large for a cassette motor but too small for a 12v system. Any help would be appreciated both by Bill Isherwood and yours truly.
FLJ
Try this Dave
Motor Nominal Voltage, Voltage Range ,No-Load RPM , NO-Load Current, Current @ Max Effic. Stalled Current Max Efficiency, Case Length, Case Diam , Free Shaft Length, Shaft Diam, Weight
Speed 280 6v 4.5-6v 14,000 0.275A 1.58A 6.8A 58% 30.5mm 28.8mm 11mm 2mm 42g
Silly me I should have said Graupener 280
