Technical, Techniques, Hints, and Tips => DC Motors (Brushed) and Speed Controllers => Topic started by: Martin (Admin) on September 03, 2008, 04:55:46 pm
I'm looking for a speed boat speed controller to handle a Speed 700BB on 14.4volt (possibly 16.8v), any suggestions please?
Try here...
http://www.dawnmist.demon.co.uk/rcm.htm#6
They do one which goes to 30vdc.
http://www.rcmodelworkshop.com/esc.html (http://www.rcmodelworkshop.com/esc.html)
Features:-
· 1Volt to 30Volt (20Cels) operation 35A 1000W(MK1)
· 1Volt to 48Volt (32Cels) operation 15A 700W(MK2)
· Very efficient, low loss system 0.001. (MK1)
· Easy step by step setup (visual and audible)
· Battery under - voltage protection (prevents deep discharge)
· Programmable acceleration
· Fully proportional independent speed limit (forwards and reverse)
· Smart fully automatic variable frequency (maximise motor efficiency and battery life)
· Prop RPM detection on reverse / forward changeover (protecting your motor drive system and internal components, dramatically extending their life)
· High quality silicone hook-up wire
Price:- £45.00 inc. VAT plus £2.00p/p
Someone pointed this out to me....
(http://www.ripmax.com/Product_Images/large/p/p-xtra-sesprint.jpg)
Specifications
Use: Boat
Operation: Forward/Neutral/Reverse
Break: No
On-Resistance: 0.003
Frequency: 4K
Max Peak Current: 940A
Max Continuous Current: 280A
B.E.C: No
Input Voltage: 6-16 cells
Motor Turn: 12-36
One Touch Setting: Yes
Temp Cut-off: Yes
Water Cooling System: Yes
Wire Size: 2.5mm2
Case Size: 52x35x16mm
Weight: 56g
Another one...
(http://alshobbies.com/shop/stockimage/fs-aqp280-300.jpg)
Specifications
Dimensions: 52x35x16mm
Frequency: 4Khz
Function: Fwd/Neutral/Reverse
Max Cont Current: 280amps
Max Peak Current: 940amps
Motor Turns: 12-36
Temp Cut Off: Yes
Use: Boat
Water Cooling: Yes
Weight: 56g
Hi Martin..
Don't go for the FUSION, it's an unknown quantity and leave out the Ripmax Sea Sprint as it blows on 12 cells, honest... Have at look at the Jeti 150 (up to 30 cells) thats 36v, or go for the Jeti Navy with water cooling and again up to 30 cells. The Navy's the cheaper of the two by far.
Paul R
Hi Martin,
I have a couple of seasprints, will pm you regarding my experiences :(
Don't tell me that, I've bought one now! :embarrassed:
for reference http://www.rcgroups.com/forums/showthread.php?t=698918
