Mess Deck: General Section => Chit-Chat => Topic started by: Bryan Young on September 29, 2008, 07:33:29 pm
Not often I ask for help....but this time I need some guidance. My printer (Canon i950) started playing up so I un-installed and re-installed only for the "legend" to pop up and tell me that no printer driver is installed. Tried "Driver Detective" but not willing to pay for something that should already be there (tightwad). Any ideas please as I really get stuck without the printer. Ta. BY.
Bryan
Have you tried re-booting since the install? Just a thought.
Doug
some times I found that with printers I had to install via the disk then connect the printer and then search for the drivers via disk dont ask why but I just found that on some printers this is how it was.
that was with millenium though
R,
You may have already done this Bryan, but go on to the Canon website, download and install the latest driver and then reboot.
Bryan,
Uninstall the drivers, remove the printer connection in device manager,
then reboot and the computer will ask for the driver disk and install for you.........
Roy
Bryan
Doug
Is re-booting the same as switching off and then on again? Shows my level of ignorance!
Yes turn off then on before you do uninstall printer in control panel but leave connected start comp then comp fins printer and asks for disc [basically]
Bryan,
Roy
Thank you Roy. Now all I have to do is to work out how to do it! This little saga is beginning to have a comic side to it...the blind leading the blind and the one-eyed man is king and all that. But I shall now try your suggestions....I may be some time......
Maybe that's the idea Bryan. {-)
Seriously though, Roy is right. If you are not sure how to do it then try Googling "Uninstall printer Driver" and you will get a selection of step by step instructions. By reading several of these it should be possible to puzzle out what you need to do on your machine. If when switching on,the PC detects that a printer is installed but has no driver, it should do most if not all the work for you.
But it may take some time.... ;)
press "start" on the bottom left of your computer a window opens
goto>"control panel" click on that
then> look for and click on "add/remove" programmes
then> look for the programme you want to remove then click on that programme's "remove" button
then> close the window ..(.red X in top right corner)
goto> start ( on the botton left of your screen) click on that and a window opens
look for the prompt that says "turn off computer" click on that
another window opens click on the "restart" button... this will turn off the computer and turn in on again (rebooting it)
check when computer is fully "booted up" that the programme has been removed.
with the printer turned on (I think)( to let the computer know that it is there )
install your printer software as prompt by the installation programme on your disc / or the wizard if you prefer and then reboot your computer as before. the drivers for your printer should be part of the package unless you need to update, then its off the the printer makers site.
check that your disc is clean no dust or light smears
I forgot to turn my printer on and it took an hour to realise it l.o.l. {-)
Martin
I think hes still smashing keyboard in frustration
so was i now i have to press harder to get caps now.
martin
Martin, I think you just gave the instructions for removing a program, not a device driver.....
Now he'll commit hara kiri :(
Surely the driver(s) are part of the software package.
Me thinks and it might be best to just remove the printer's installation programme and start again. basic package boot up, then any updates boot up again
martin
They are on the disc but if hes got newer software for operating system might not recognize drivers
whadda i know just build the darn things LOL
Nice little double edged sword there Colin!
start
control panel
open printers
file
server properties
click drivers tab
in the ..install printers drivers list click the driver to be removed
click remove
yes to confirm
Don't know if this is right . I just to prefer to clear the decks and start again
martin
Knew you'd appreciate it Bryan!
Martin
Going through the latest postings re. technical writing (of instructions for building a model etc.) I could suggest that you can apply for the job. Lucid and simple. Well written and many thanks. BY.
Hi M8s
Too many hours putting data into the Sinclair Spectrum 48k T[17] many years ago, has left me brain dead. :D
Martin
Shhh Colin - you've just given away how we do anything in the (paying) IT-fixin' world.
If I stumble across something wildly unusual at work, job one is "give me five minutes" and Google for any solutions available online. 99% of the time someone else has had the same problem and posted it.
NEVER pay for IT support! :D
Andy, IT Support
Hi m8s
Don't need Goooogle all the info is either in the computer or @ Microsoft.com
Its helped me a lot over the years. Also I did one of those City n Guilds courses on stripping down these machines and rebuilding them from scratch then put the software into them . After working on typewriters for years then the Word Processor (Huh) mes had enough of machines. Mind you its a lot better and cleaner than being an Agricultural Engineer.
I need a replacement for Microsoft Office 2000 professional disc 2. As my disc is cracked any ideas anybody.
martin
The big problem with looking at microsoft's site is that while the information is probably there, it is invariably couched in terms that are totally incomprehensible. I often wind up looking at
www.theeldergeek.com
where the answers turn up in English. Often. Quite often, anyway.
The biggest problem is usually wording the question "correctly" so that the answer coming back has some relevance to the question I thought I was asking.
Hi m8s
Know what you mean about Microsoft, I get to where I am looking for eventually.
I've just have a little history with computers and the machines before them and its helps. Gone are the days of the manuals.
I'll have a look at that site so far looks o.k.
Wording questions, I Goooogle but trying to cross reference like... Swains + St rood or Tescos + Gillingham the + seams to be important
Martin
Just a small addition.
If the printer is attached via USB.
Disconnect USB cable first. Then un-install. Then re-install. Only then re-connect the USB cable.
Steve
Good point Steve
Martin
Got my printer back "on-line" now...but I think the driver is a "generic" one. But it also turned out that the driver was not the only thing at fault.
1. The yellow ink had started to congeal and was clogging the nozzles. Apparently this is a common problem with yellow. Don't ask me why!
2. Even after "fixing" the problem the results on glossy paper that I bought from Aldi (thinking it was a "good buy") were still rubbish. When I swapped to one of my more expensive papers the results were dramatically better.
Thanks for all your help. BY.
I've been tempted to use cheap clone ink cartridges in the past but they always seem to give problems. I now just find the best price on original manufacturer ones. Yiou can get good bargains if you look around.
As far as photo paper is concerned, most of the big names are OK, again look for bargains. However, if you want real longevity so that your great gradchildren can see your precious pics it's still best to match the original manufacturer ink and paper as they are designed to work together.
It seems to be a bit unfortunate that modern printers have their inkwells "chipped". So the cost of a machine (printer) is really cheap..but if you do a lot of printing then the cost of the ink goes through the roof. This, in the long term, will be a negative investment by the printer manufacturers. This whole thing is supposed to be an affordable way of letting Joe Public do his "thing". Apart from the complexity and so on of developing your own slides and prints when we used to use the chemical bath way, digital photography opened up a new world to millions of people. Now they are cashing in....and it is becoming unaffordable to the many who embraced it. Geese and Golden Eggs come to mind. Ink is reasonably cheap. Cartridges must cost peanuts. Why kill off a good thing for short term gains? Not a rant. Just disappointed. BY.
If you have a lot of photos to print then it's much cheaper to take a CD with the files to Jessops or one of the other high street firms and have them do the printing. I only use my photo printer for special large size prints that I want to frame myself. Personal printers are simply uneconomic for lots of prints.
colin
I've always had excellent results with my 95p clone ink cartridges, it helps if you never switch the machine off.
Bryan, have you experimented with different paper settings? This can make a huge difference
I was on another thread about ink and photo printer and had my eyes opened to the expense they can cost in running them. For instance that some of these modern day photo printer use 7 different colours and when one is empty,you have to buy a new cartridges. I started to learn as much as I could about my Epson 3200 printer/scanner/photocopier. After a while I got accustomed to printing photos. My ink lasts for a long time now and I have more say in picking the size of picture to be printed. (As it says read the instructions). I don't buy Epson's cartridges but buy from Play.com or 356.com the latter had a pack of colour cartridges at a reasonable price with delivery next day.
I have Paint Shop Pro and I never had any luck with it. While the instructions seem understandable, when it comes to resizing and cropping everthing goes wrong. It is probably me but then the other week my daughter said that she didn't realise that it was so hard to use and shouldn't have got it for me. I use the Canon software (my camera) or the Wizard with reasonable success and the quality is very good.
I print at least a pic a week to keep the nozzle/jets clean and would get more economy if I used Grayscale when printing documents.
Sorry for highjacking the thread
Martin
The printer manufacturers are not in it to sell printers. Their main function is to sell ink.
I have avoided Epson due to their policy of chipping cartridges and sueing anybody who dares to muscle in on them. I used to have a Cannon, but it didn't take it long to decide that its waste ink pad was full, which could only be remedied by a service which would cost more than the replacement printer. Both makes seemed to insist on regular, persistent and expensive head cleaning.
My Lexmarks were OK but expensive to run, and a comment from a cartridge salesman (we dont list remanufactured colour cartridges for Lexmark because of the complaints) eventually put me off them.
My current HPs are hopefully going to carry on being boring as they just sit there and work.
A word of what might have been wisdom that I was told was that buying a high capacity cartridge is only economical if high use is anticipated, otherwise the ink in the nozzles dries and might fail to clear on the start-up.
Since I changed suppliers I have not had trouble with print quality and there seems to be more ink in the cartridges, or maybe I've acquired the knack of printing pictures.
I'll need get down to the shops with a disc and try that method. It is passport size photo that has been the one I can't print out. Doesn't seen to be list in any of the software I have. :(
Very happy with my Epson but I don't think I would have bought one when they were just printers.
Martin
Serif Photoplus 6 (a free download) will let you specify the size of a photo in inches/centimetres for printing. I use it all the time for resizing photos for the club website. It does what it says on the tin or somesuch O0
http://www.freeserifsoftware.com/software/PhotoPlus/default.asp
HTH
Doug
If SWTSMBO is into making greeting cards for all and sundry, the cartridges cost a small fortune. Just got an external system for our Epson, much cheaper.
You can fix this yourself, the routine is here http://www.neilslade.com/Papers/inkjetstuff11.html (http://www.neilslade.com/Papers/inkjetstuff11.html) and here http://www.fixyourownprinter.com/forums/inkjet/15284 (http://www.fixyourownprinter.com/forums/inkjet/15284)
I have used this workaround without a problem. Cleaning and drying the pad on the bottom of the printer is the biggest pain in the ****
While we are talking on the printer side of this thread I have given up on printers, Oh I still have my Epsom colour and a Hp desk jet
and I have a fax copier printer by cannon.
I found that my daughter was printing more than me and only when I was at work it cost me a fortune in ink but not now {-)
mono chrome settings locked in the fax and the others are shut off :D
I have used this company for ink for my printers for some time, good products, fast delivery and excellent prices, worth a look.
ink-1.co.uk/shop/
Steve
aka HLR
Thanks but that was several years ago. Canon lost a customer by a process of commercial stupidity, forgetting that there were other players out there. The various printers that have been used since have all given good service and acceptable results for the jobs I needed doing. When something terminal fell off, I joined the throwaway society and got a fresh one.
Just have put new cartridges in the old Epson 3200
I think you'll agree the quality is reasonable. l.o.l.
Martin
Very nice...
But copying banknotes is illegal.
Malc
LOOK very closely at the pictures. !!! {-)
Looks like a £10 note to me? (and making any facsimile of a banknote is illegal)
you can have this one for a fiver l.o.l.
I've just wrecked my screen cutting one out.... :(
:o :D ::) there has to be something wrong with this scan of a Tenner or the Fiver even - I mean it comes from a Scotman's pocket and I am surprised its even seen daylight... probably the last time it saw daylight was the day it was printed ..... and even then it's a bit IFFY to me.....ever known a Scotsman to let you know he has some money.......wonder there isnt a scan of his hand along with it....KEEPing a hold of the note. Aye nowt like a grip of a Scotsman on a Ten poond note ya nar..... {-) {-) {-)
aye
john e
bluebird
THE STRONGEST GRIP IN THE WORD
Just for you John anytime oll mate
Start a new thread. Called.. Name that Tartan
Och martin Ah dae hink we ur gonnae hae tae tak' ye tae th' doctors - thes is twice runnin' ye hae removed bunsens frae th' depths ay yer wee sprran an' thes is a bad sign fur a scotsman
why aye man
oh it takes a worried man, to sing a worried song
oh it takes a worried man to look at that tenner so long :-X
I might as well hold on to it the banks certainly can't
I have got cracking results with Aldi paper, The printer has to be set to the right type of paper, mines an Epson and I use the "quality glossy film" setting.
I set mine to photo paper and the print settings to Best Photo, thery're very good pics.
I also do a sample with plain papaer to make sure the nozzles are clear :-)), before I start doing best quality pics.
Using Fugi paper it gives good glossy pics but I have to manualy adjust the pic size to 108mm x 150mm (6x4) it doesn't seem to like the 6 x 4 imperial setting.
