The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: das boot on January 24, 2009, 08:50:59 pm
Can you buy replacement motor cowlings for these 'riggers, does anyone know? I'd like to fit a new one(sorry, Euan...)but can't seem to locate one on the 'net anywhere...any ideas chaps?
Ta
Vac form your own :-))
you could always make one from aluminimum, make a wood form and a sheet of aluminimum (tin can) ,soap and a blow torch .
Made one for a engine cowel for a bi plane i crashed .
daz
The problem is solved gentlemen, many thanks for your advice. I've made a new cowling up, when it's completed and sanded down I'll post a pic up of my handiwork.
Rich,
REMEMBER THIS IS A SPEED MACHINE NOT A SUB?,make sure whatever you make is totally waterproof as the hatch forms a watertight seal.The rigger was a scatch build by a chap in Devon so no commercial hatch available.The hatch on it is designed to make just enough space for the motor and battery connectors.
cheers Euan.
I'm onto it Euan...I've just swapped the cowl that was on the hatch with something longer, a bit deeper and a touch higher. Purely cosmetic...I'll still be using the existing hatch cover, just the 'bump' has changed.
I'm treating it as a submarine, mate...not a sniff of water will be permitted to enter the boat under any circumstances.
Cheers,
Rich,
I responded to your pm but i keep getting messages from Martin the mod that it has been sent to the wrong person.The esc has a built in bec circuit so all you have to do is connect up yur 12cell pack.
cheers Euan.
Excellent Euan, many thanks for that...one less thing to worry about, that's what I like! With a bit of luck and a following wind, we shall on the water by next weekend...
Thanks again for all the help and advice..
