The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: ronkh on January 25, 2009, 05:22:50 pm
Hello all,
I have been working on this boat for the past couple of months. I was looking for plans for steam engines and on this site - attached - I downloaded the plan for a steam Pinasse as the shape of the hull really appealed to me.
www.john-tom.com
I have no idea what a Pinasse is other than it is the name for rather a lot of different boats! I have been told that the English spelling is Pinnace?
Anyway, as I could not afford a steam plant (and also that it would take too long to make one), I decided to use the hull and adapt the rest for a tug of sorts.
The first few pictures are of the bulwarks cut out using a Christmas pressie from my wife - a scroll saw.
I will give captions of to the others photos as I go along.
A couple more. On one of the photos I had to split the back of the stern/keel to fix the prop tupe in place. With a keel doubler layer on both sides, it went together extremely strongly. I hope I have used thecorrect nautical terms!
Planking going on. Did not realize how awkward some of the shapes were/are. Planking is of Balsa of which more of later.
Nice! :o :-))
Looking good. What scale should it be and what kind of superstructures did you plan?
Part of the bow got damaged after a bit of heavy handling, the front right. One of the biggest draw backs of using balsa.
And what glue are you using?
Ron,
She is looking good and should harden up a little when sealed. Are you planning on a double planking or just single?
Barry
Thanks Martin. I wonder if I can get this finished before a certain someone's Bismark!! {-) :-)) %)
kno3. Photos of part of the superstructure will be posted very soon. Hopefully within the hour.
Ron.
At the moment I am not sure whether to use resin and tissue or plank it. I have only used fibre and resin once and that was yesterday for the inside. Next time I must keep door or window open as my head was splitting after! Not nice at all. As for glue, the yellow stuff and super.
Ron.
Ron.
I may be teaching granny to suck eggs, but if you do double plank it you can use a nice soft wood like lime. Much easier second time round and gives a lovely finish.
Barry
Thinking on those lines Barry. Plenty of spare wood in shed to choose from (as most on here I think).
One of the pics showing keel doubler.
Heater looks lethal but isnt! Very cold in shed and its also not as bad as it looks. More of a bright light then heat, it gives the illusion of being warm.
At the moment, the superstructure is laid on the deck - which is not glued down - and a long way to go yet. This part of the build I will definately be planking.
The sizes (without the superstructure on) are 28" (710) length 6.75" (170) wide and 5" deep (127) without the superstructure.
I am not sure what the scale is but I did read on one of the threads on here - not sure who - and he said that if you get some model figures and it looks correct, then that is how to get a near as d##n it scale.
Barry, I have decided to plank the hull. Whether it will be in lime or whatever or a mixture of woods will wait and see.
Ron.
I tried getting different ideas for the structure with the cardboard. Thankfully, we eat a lot of cereal in our house so no shortage of boxes. :-))
The last one shows the glass fibre for strength which made smoothing down the outside of the hull so much easier.
Ron.
I was wondering how to make the funnel. Not feeling confident using glassfibre, plus I do not like the smell or the headache, I decided to fabricate one by first cutting a piece of aluminium tube in half (I think it measures just under .625"), gluing them together and filling the bottoms flat.
I then marked on to 5 scrap bits of wood the shape (rather like a figure of eight). Then I marked the outer edges of the circles to give two straight lines and cut out. Once I was happy with the shapes I then cut a notch on one side of each and stuck a length of wood on them. To get the length of ply (.750m/m) to wrap around correctly, I used another shaped piece and marking a line on one edge and centrally, I rolled it over one complete turn and marked out where the line came. Remembering to measure twice and cut once, I am happy to say that the end result came out very well.
Ron.
Hopefully will have some more done by next weekend.
Dear all,
This is where I will be needing some (or a lot) of help please. :-))
Electronics!!!! {:-{
Can I please ask for help in setting up/running an R/C boat?
My knowledge of the above is a three pin plug, lots of sparks if I get things wrong and a complete brain freeze if I am asked anything about said matter. :embarrassed:
What I have made my mind up to get is a pack from Model Flight Accessories. This comprises a Torpedo 540 motor with mount. A forward-off-reverse speed controller, fused wired harness, servo linkage, propellor (which I will replace or try to make one, I think I will need one in the region of 45m/m dia), full compression. The motor gearing is 6:1 giving 1900 RPM from 12 volts.
I would really like to get some lights on this and if not too hard, perhaps a working winch if thats possible but not important. Obviously I will need batteries and a charger but have no idea what would be best.
In short, anything that one or some of you kind people can help me with, by way of a simple wiring plan and instructions and patience, plus a not too expensive R/C controller. I have looked at ACTion website and there are wiring plans on it but I am still not too sure about some of the meanings. I not sure what an ESC is.
I would really appreciate any advice.
Many thanks in advance.
Kind regards,
Ron.
Ron,
It really isn't rocket science......or so the experts tell me. Try a pm to FLJ (Dave of ACTion). He will listen to you, fully understanding your lack of knowledge. He will supply what you need at a reasonable cost and help you through which wires to put where etc. With his help you will learn and the boat will go where you want it to. I know as he did all that for me!!
Barry
Ron,
Depending on her all up weight she might struggle a bit on 1900 rpm on that prop, but will depend on the pitch.
Give her a go but be prepared to up the prop a bit.
Hi ronkh, ESC is your speed control "electronic speed control" as for the wire's then if its your first attempts then I would err on the simple side of things and when you feel like you can add then go for it.
But most of all have fun
R,
Bit of an update on the build. Been a while but work dictates so only a couple of Saturdays free.
Not quite a tug. In fact, I'm not sure what it could be called but I am having fun making it!
Electrics are from Dave at ACTion Electronics. (What a very helpful, nice and patient man). Thanks to Barry for the pointer.
Just need to get the control box at the end of month (payday!) and I can then see if I will get the wires etc, in correctly, or if I will need an extinguisher!
I now that some things may not be to scale - as with the planks - but I think it's looking okay.
I may be wrong, but I think the scale is 1:40? How I got this scale was by measuring the door heights which are 2", and by going to George Turners web-site for figures, saw some at this scale which were just under. Not science but it does for me!
Few more. The planking's caulking was done using a felt-tip pen. I tried with card but got nowhere except frustrated and annoyed. Could'nt get it right though will have a bit of practice on some scrap for next boat. (Time allowing)!
I will be turning some port-hole windows and also stuff for the deck such as a winch or two, davits perhaps if I make a couple of small boats, anchor winch, etc.
Quite a lot more that I want to do and put on it so any ideas/suggestions would be veey welcome.
Ron.
One of the photos is a bit blurred but I think it gives an idea of the shape of the deck. This was done by leaving weights on it for a while in the hull. These were left on for the time I was at work for about two weeks total. I then planked it while it was still in the hull and this helped it to keep its curve.
I would like to add something with regards to Dave at ACTion. I told him I had no idea at all with respect to the workings. He looked at the site where I told him I got the plans for the hull, corrected me with a couple of mistakes - namely, I told him the wrong diminsions - and he sorted everything out for me. The motor - ESC - batteries - fuses - diagram, etc and where to get the controller so again, a very big thank you to Full Leather Jacket.
Dont forget that I would appreciate any ideas/thoughts on this, no matter what they are. Well, within reason!!
Ron.
With these ones I think you can see the curve I have on the deck. It shows up more with the superstructure base I think.
The control will be a four channel one instead of a two channel as I will be able to get more things in/on it.
I know that it looks a bit cartoonish but as I said earlier, I am enjoying this, its the first scratch build that I am attempting, I also wanted something a bit different from kit tugs/boats, and I love working with wood.
I am going to buy a book or two on how to wire up boats. Anyone know of any or can you recommend some?
Ron.
PS. I have decided to plank the hull and not use tissue and resin. Started planking this afternoon and in a week or two I will hopefully, be well on the way to planking it.
She is looking beautiful. Your woodwork is a credit to you...
Ron
You're more than welcome. Book? This is the one to buy:
https://shop.traplet.com/product.aspx?c=311
FLJ
Cheers Barry.
That will do for me Dave. Thanks again.
Meant to say earlier that I have yet to smooth the deck down, then its a few coats of clear varnish and a few of lacquer. Should'nt look so rough then but as I said, I still have a long way to go yet on the build.
The gap at the front is not deliberate. Its called slipping through the fingers and finding a hard floor! (After I had already damaged it).
I'll blame it on the cold weather!!
Ron.
A very nice looking boat,i like the way the bridge sits forward
Mark
Long time since last update but a couple more pics of the second planking. Bit of a mixture of woods - Mahogany, lime and other types that I had spare.
Plenty more rubbing down in between coats of clear varnish (I want about six coats I think) which will be followed by quite a few coats of lacquer.
Finally getting the electrics in and now that I have had some good advice from others on here, things are looking better in that department.
Still tons to do and many weeks/months before ready to get the bottom wet but it will happen.
Ron.
Good looking planking, Ron. Seems a pity to cover it with paint!
Had you thought about possible differential shrinkage between the different woods?
Roger in France
Hello Roger.
No, I will not be painting it but there will be plenty of clear varnish.
As for wood shrinkage, I never gave that a thought. Do you think it will/might shrink enough to spring any leaks? Surely the amount of varnish and lacquer I will be using should keep it tight but I could be wrong in my thinking.
Ron.
I am sure if you have a complete seal inside and out you should be OK. It is just that I always try to avoid using different woods if I can. However, I have very limited experience of plank on frame and so I may be raising a spectre without good cause.
Roger in France
I thought it would be a good idea to post an update on the build so far.
I think it's now starting to resemble a tug although I will admit that the hull is definitely not tug shape! That is from a plan for a Pinasse steam boat but it appealed to me.
The winch is made from some old clockwork gears, scrap copper tubing and plastic sheet and styrene. I cut some black railway pins heads off and stuck these on the bases to resemble rivets or bolts. Portholes are made from brass washers.
Ron.
The propeller base was made from scrap brass sheet as are the side-support for added strength.
I will be adding grain of wheat/rice bulbs at a later date as the cabins are not fixed down yet. I have had to place some neoprene between the motor and the base as the noise transmitted from it was one heck of a lot. Another mistake I made when I lacquered the hull was in using gloss. I thought it was matt when I "borrowed" it from work. Is there anyway I can respray the hull without the need to rub it down? I do not really want to do this as I have 5 layers of varnish below this.
Ron.
Looks very nice mate :-))
With regards to respraying,you will have to rub down very lightly,with a very fine wet and dry,to give the new varnish/laquer to adhere to
Mark
I finally made a stand for it! Bit over the top but who cares? I can honestly say that this boat/tug or whatever it is, has been the most fun I have had in yonks.
To me, this is my idea of a what an old tug looks like. I am not a sea going person and I do not recall seeing one, and if I had of done it would of been when I did not really have an interest in boats of any kind.
It is all from scratch including the winch. Everything.
I do not know if the chimney is correct, or if there is a real-life tug or boat that in anyway resembles all or part of this but again, do I care?
The biggest headache I had was concerning the rudder. On the drawing (of which I have earlier mentioned the web site where I got it from), it showed the boat as a steam powered boat having a rudder on the transom. It was not until I had got quite a way through building it, that it dawned on me that I would have problems getting the rudder to work as it shows it connected to a tiller. I didn't want a tiller and after a few experiments, came up with cutting out a square at the rear of the deck and making a hatch hiding the servo which is connected to chains. Awkward to explain how its connected but I hope the pics will show how it is.
I will be making a winch for the fore-part of the boat for which I am going to try to incorporate one for the anchors. I will try to make this a working one but if I cannot, so be it.
I have a spare channel on my transmitter and if I can't do this, then I will try something else.
With any luck, I will hopefully have some spare time in the near future to complete more of the build. As some of you will know, I work in F1 and these past few months have been extremely hectic and at times, I have only been able to snatch a couple of hours at the most on the odd weekend to do any building. Now that our milkfloats cars are winging there way over to Australia and will be away from here for the next month or so, I hope to be able to do more.
Ron.
Cheers Mark. Will give it a go soon. Still too bl''dy knackered at the moment and only feel like doing small jobs on it.
Got a little something for when you come along!! O0
Ron.
I don't normally comment on peoples builds but this one is very nice, really nice wood and bass work, does the winch work and what is the rope you have used.. :-))
Just out of interest are you still having problems getting the rudder to work i had a similar problem at one time it was because I had not placed the connections on the servo the same distance behind the centre through line as i had the rudder,you may know what I mean.
Proteus
Proteus,
Thanks very much for your comments.
The rope was from Amati.
I know exactly what you meant!! I got the servo running okay in the end as it was a case of trial and error. Mainly error but by juggling the length of the chain and different positions for the connecting holes, I finally achieved a good result.
I could of had the winch working as I had the gears but my third channel is non-reversing, and I cant quite afford a four channel yet. I did say earlier that I would try and make a working winch but obviously I wouldn't be able to use it until I get a better radio.
The wood and brass work is deliberately kept as that with no paint except for the cabin roofs and some small parts like the window frames. I wanted to do something similar to my Rainbow yacht which I have still to finish off, but on a bigger scale. Picture for show.
Ron.
Don't you just hate it when you put in the same photo twice? >>:-(
And on two different postings!
Hi ronkh,
your tug is beautiful. Great job!
Best
Wilhelm
Ron, beautiful woodwork on your tug. I hope you won't paint the hull, it's so nice to look at a well made plank-on-frame boat.
By the way, you could put some brass nails in the ends of the planks, that usually looks very nice.
Another small update of the boat.
I was going to get a soldering gun/iron to do the rails but thought I would leave it for a while until I can get some practice in.
Instead, I bought some double ball 14m/m stanchions from www.model-dockyard.com I ordered these yesterday about 10am and they arrived today 28th March along with a couple of navigation lights and a book on Model R/C control. Its going to take some reading and double-checking before I am anyway near good enough to do what I want to do.
The stanchions I am using with 1/32" brass rod.
The winches are none working as I do not have a spare channel, but I hope to be able to do so on a future build. Use as working winches that is!
I am afraid that the picture quality is like the camera, crap. A lot like my abilities when it comes to using them!
Ron.
Couple more.
Hopefully, I will get a good run on it tomorrow. I really want to finish the insides of the hull but I can't do that until the decks down and for that, I have to be sure that everything is finished inside. As this is my first scratch built effort, I am a little nervous about doing that. Still in for a penny, in for a pound.
Ron.
Uploading a few more pictures for an update. To keep cost down, almost all the extras are made from scratch.
I think the wind vane is out of scale (this could be because I don't remember seeing a tug in real life!) as could a few other things but as I said earlier, I enjoy it, its' my first scratch built and to me, it looks good.
The two square bits by the sides of the cabin are coal shoots. The anchor winch works - by hand - and the other winches would do work but turning by hand only, I didn't motorise them because of cost but also mainly as I wanted to see what I could do and how things would look before I do a bigger working tug. This will most likely be the "Archer" from a Jim Pottinger plan, and on this, all the winches etc I hope to have working.
I will let the photos show the work I have done.
Ron.
A few more.
The small boats are scratch made. Is it carvel? I cant remember. Very fiddly as they only measure 75m/m. 3 inches in length.
The bumper bit was again scratch made. I carved a piece of balsa to what I presumed to be the correct shape and then just wrapped some rope over it. Looks okay though yet my hands are now covered in superglue!
The anchor davit works. (Did I already say that? Never mind if I did!).
The anchor is also scratch made.
I have tried it in the bath and no way am I going to show a photo of that!
The bath dates from around the late seventies/early eighties or so and the colour must of been copied from someone having an accident after too many beers and some junk food. %%
I hope to be able to at least show some photos of it in the water and if I can, a video or something from my phone.
I still have a few deck bits of clutter to put on and again, I do not have a real idea of what some of them do but I am learning O0
Ron
Ron,
Just be careful when moving it about, with the rudder position it is very vulnerable.
Looks the ducks gutz mate..........
Roy
Thanks Roy.
Re. Rudder.
Believe me, I found out the ouch <:( way about the rudder >:-o
The hull was originally for a Pinacce boat and I changed it to a "tug of sorts", and it was not until I had nearly finished it that I realised that I would have problems with the rudder. The only solution that I could think of was to fit it with chains after extending it out of the back.
Seems to work okay but will have to wail until it gets it's bottom wet.
Ron.
Went down to Cripplegate Lake situated at Southwater in West Sussex (UK) today. www.horshamdistrictcountryside.org (go to Southwater Country Park)
This is the home of the www.dabblers.wikispaces.com
This was my second time down there but I forgot my camera last week!
I remembered this time, but could only take three shots as the card was full and I did not have one of my son's to tell me how to re-set it to zero!
Still, at least it proves that it floats, it does not leak, I had some very good comments from the boaters there and I had a grin like the Cheshire Cat!
For my first scratch build, I am very pleased and happy with it and I am now completely hooked on model R/C boats!
I can't see many static boats being done in the future now!! (Well, maybe just a couple).
The photos are not exactly close up but at least they show it on the water! More later and I hope that you can see them well enough.
In a couple of months, I should have a Springer ready of which more of when the time comes.
Ron.
Ron,
Some skill you have there......very nice indeed..
Barry
Looks great mate,have you named her yet :-))
Mark
Ron Congrats on a superb piece of workmanship :-)) :-)) :-)) :-)) :-)) :-))
Damien.
Thanks Barry, Mark and Damien for your comments. Makes it all worthwhile!
The name will be the Sarah E after my long suffering and very patient wife.
(http://www.postimage.org/templates/images/smiley/love/0.gif) (http://www.postimage.org/)
Thanks to Mark - Craftysod - for the hull of my next build, a Springer. This will have a separate showing on the Springer page later on.
Ron.
did you make the brass ladders and rails ron. if so how and if not where did you buy them. they look excellent. ifn fact the whole boat is a credit to you. well done :-))
Hopeitfloats,
Cheers mate.
The ladders are scratch made from scrap wood and brass rod as below.
I got the stanchions from www.cornwallmodelboats.co.uk Could this help as I believe they do an overseas post?
The brass rails were from my local model shop.
Ron.
