Model Boat Mayhem - Forum
Dry Dock / Shipyard: Builds & Questions => Working vessels R&D: => Topic started by: Mark47 on February 20, 2009, 11:17:12 PM
I want to build a kit next (don't mind if there is some construction involved). All I want is something stable, good looking and can handle rough water.
But I want input on the next two links
US coast guard, on it need's paint, battery and remote.
www.pegasusmodels.co.uk/detail.asp?main=Boats&sub1=Boat+Kits&ID=990744
Or this? Paint, all electrics.
http://www.modelslipway.com/ The Trent boat.
All your info needed!
Hi Mark ,The Trent is a nice build . I enjoyed it and there is a good bit of construction if that is what your looking for . But not so sure you will want to put it into rough water
after you put a lot of hard work into it ! Good luck with whatever you pick . :-))
Hi John,
Are you saying it's brittle?
Hi John,
I've ordered a Trent as there was not much feed back.
No not saying it's brittle at all . It has a good strong hull and the wheelhouse if built correctly is strong too . What i mean is that once you put many hours work into completing this model you won't feel like risking it in rough water . Leave that sort of thing to the full scale Trent thats what they are built for . Enjoy your built
regards John
regards John
Oh? OK. I've never built a kit before. It's always been hull & plans so not really sure what to expect. I am thinking of changing to brass stantions, just for the strength.
Ah, you've never met me {-) {-) {-). When I've built lifeboats, this is exactly what I use them for. Rough water. :-))
Ah. I just stick to the full size ones for rough water . I see what you are thinking of with the brass stantions and here comes the but ! But on the Trent kit i think the weak point would be where the kick boards that the stantions fasten to meet the deck . it will all come clear when you get the kit . All said i enjoyed building it . Have a slipway Maggie M on the go at the moment
. Its a nice kit too .
regards john
regards john
I thought that myself. Thinking of using some spare brass sheeting I have for the kick boards. ;)
You will have a good base to work from but as you know when you beef one part up it has a knock on effect with other parts . Sounds like a nice project keep us up to date
with how your doing . I'M not up to speed with the photo thing yet . I'll have to change that . I have enjoyed this forum since i have joined some really good tips and everyone wants to help .
