Mess Deck: General Section => Tugs and Towing => Topic started by: Captain Povey on February 22, 2009, 03:26:22 pm
Hi all, This morning was a busy day at the pool side and with some trepidation in front of the crowd I hooked up the recently completed barges to my St Canute. Here are a couple of pictures of whole thing. As the St Canute was not really built for towing the hook fitted to the boat superstructure could not be used as the superstructure is only fitted over a combing and not screwed down. So as a temporary measure I removed the rear raised deck piece and flag and screwed a cup hook into one of the boat's main structural parts. Not very pretty or accurate I know but the effect was ok and it worked - well nothing sank although in the strong cross wind steering was sometimes a bit hit and miss. At one point I got tangled up with a 'footy' but the contact was at low speed and no damage was done to either boat. We eventually disengaged at the far side of the pool having slowly made our way there under a combination of power and sail. Cheers Graham.
cup hook or tow hook it dont matter (except to the perfectionalists) , them barges look the part i like it :-)) .
daz
Nice tug. Is it the one from the Billing Boats kit? What engine do you have?
Hi and thanks for your kind words Portside ll. The barges are from Deans Marine. Yes Kno 3 it is the Billings kit with the Robbe 'power 400/35' 6v motor running off a 7.2 v rechargeable battery pack. If you want to see more detail there are more pictures on this site. Cheers Graham.
Where?
Good question, Where?. I tried typing 'St Canute' into the search window and the only thing that came up was my last post. I will have another look and get back to you. Cheers Graham.
Hello again Kno3, Ok I searched my posts and came up with 'Billings boats St Canute' try that in the search box. Cheers Graham.
Hi Kno3
Carried out search by clicking on "Home" then entering Canute in the search box, had lots of results.
Thanks for your help Richard. I will learn to use this site properly one day. Cheers Graham.
Thanks Graham, now I've found it. Nice to see al those St. Canute models. As a matter of fact my steam tug stated as a St. Canute kit too, but I changed it substantially (the only thing that's almost identical is the hull, just a bit elongated). You can see it here: http://www.modelboatmayhem.co.uk/forum/index.php?topic=11688.0
Hi Kno3, I had a look at your posts a bit earlier and thought I saw a hint of the St Canute in your boat which incidentally is a superb example of some very fine modelling. Congratulations on your fine workmanship, it is at a level that I can only aspire to. Cheers Graham.
:embarrassed:
