Technical, Techniques, Hints, and Tips => Batteries & Chargers => Topic started by: BreezyB on April 27, 2009, 05:01:53 pm
I have a Futaba Skysport 4 TX and, up until now, I have used the charger which was supplied to charge the battery (9.6 v 700 mAh NiCd) via the inbuilt charging socket on the case. I now have a universal charger (NiCd / NiMH) which has the Delta sensing system incorporated which I would like to use instead. Can anyone help or advise with the following questions please:
(A) Will it be OK to use my new charger (MW 168VD from Components.Com) via the inbuilt socket and will the fact that the lowest output is 500mA be OK because I read recently that the charge rate should be something like 1.5mA max??.
(B) I am 99.9% certain that the middle pin of the case charging socket is + (pos), can anyone please confirm if I'm right or wrong??.
Its good to know that you Guys are out there, you have saved me from many embarrassing situations :embarrassed:
Barrie.
Cant find the website you mention or the charger, though if it is a Universal charger it should be fine. Yes Futaba is centre pin positive. I dont normally charge NiMH at more than 1C as the batteries get hot and the Tx battery will be enclosed within the radio. So for a 700mAh pack I would would want to charge at much more than 700mAh.
hi all,
Am i right in thinking the futaba tx has a diode fittted to stop the battery being analized. if so the charger wont delta peek as the the charger wont know the voltage. also i always charge mine out of the tx and alays at the 1C rate. (ie charge in approx 1 hour).
hope this helps
ro88o
Many thanks to Mankster and ro88o for your help and suggestions. It is hardly a suprise that you couldn't find the website, I got it all wrong due a "senior moment". :embarrassed: The web site actually is www.component-shop.co.uk and the charger is referred to as a 500/1000mA Smart Charger for Race Packs. For battery packs they are great but I wondered if I could use it to charge my TX but a club member has also suggested the same a ro88o that using the charging socket with other chargers may not be as simple as it seems.
My grateful thanks to you both.
Barrie.
Club member and ro88o are correct, delta-v sensing will not work through the charging jack. Easy answer is to remove the pack to charge. Not hard to do and allows a better regime that will probably keep your battery alive longer.
Many thanks for your contribution Ian, I guess that the solution is to continue using the Futaba TX Charger supplied with the set or, as you quite rightly suggest, remove and charge the battery pack independently. I will probably go with the latter.
Thanks again :-))
Barrie.
