Technical, Techniques, Hints, and Tips => Painting, Finishing and Care. => Topic started by: budlia on October 12, 2006, 07:37:32 pm
having carefully soldered my brass stanchions and handrails together, can anyone recommend a nice chrome effect paint (preferably aerosol) that really looks the part!
Yes i can, Alclad!!! Quite simply nothing else comes close. Not many places do it, my local model shop Hannants sell it in bottle form to be airbrushed on. The company has not long introduced a spray can version, but this is not stocked by Hannants, although i beleive a rc shop called D.M.S.Racing in Watford sell it.
The stuff in areosol form will be the best for you, should be alot tougher and more durable than airbrushing.. The way it works is that you spray grey primer first, then followed by high gloss black, and the finaly the Alclad chrome finish....haye presto, the stuff looks just like the real thing and you can even see a reflection of your face in it ;D
Hope this helps!
Voyager.
I've tried several so called "Chrome" paints and sprays and they've all been crap!
"Alclad chrome finish....hay presto, the stuff looks just like the real thing and you can even see a reflection of your face in it "
I've got to try this!!!! :o
Martin,
Just checked and the model shop in Watford does sell it, but it's not cheap at £10 a can, but it's well worth it!!!
Regards:Voyager.
We use a chrome paint from Halfords (Chrome lid on the can) to spray the reflectors in our working search lights. Much like this Alclad stuff, a few thin coats letting it dry in between, and you get an almost mirror finish.
Malc
I found out, that some of the Chrome-effect sprays come better, if they are sealed with clear varnish and some become darker. I wonder what that is as I have always used the same varnish.
Though I think you need to have a try on a sample piece first, before you spray the real item.
Jörg
Why not take them to a chrome platers and have them done in the real thing?
I don't think it would be that expensive, especially if you just want them rough chromed.
Andy
Or DIY:
http://www.speed-demon.supanet.com/eleckrom.htm (http://www.speed-demon.supanet.com/eleckrom.htm)
http://www.caswellplating.com/kits/copychrome.htm (http://www.caswellplating.com/kits/copychrome.htm)
There is another one available, maybe not in your paddock, but it is called 'chrome brite' over here, seems to work quite well, I have even used it to touch reflectors in motor cars successfully.....
Roy
Subculture
I could offer you a dissertation on vacuum metalising (plating) of plastic components, but I won't - suffice it to say that you don't want to go there. It's strictly a commercial process.
You might be lucky enough to find a metal chrome plater that will do the odd handrail for you though?
Regards, Malc
He did say he wanted to finish brass railings, so a chrome plater will be happy to oblige, and it shouldn't be that expensive either. I tend to find folk are more helpful when you explain what it's for.
Andy
A few years back one of my mates got someone in a local aircraft factory to make him a cribbage board (makes a change from lighters). Being helpful the guy asked if he wanted it chromed. My mate said yes. The board duly arrived in very shiny brass. It seems the silvery colour is actually nickel, the chrome is just a layer of metal so thin you can see through it, like a sort of varnish.
Most folks probably knew that anyway, but it came as a surprise to me, and even more so to my mate who had to explain it to the rest of the crib team...
Well that was certainly informative! i'm sure the Halfords paint would be very good, like all there paint products. but i'm going for the Alclad stuff, sounds just the ticket.I think haviing them chromed is probably a bit over the top, but thanks to you all for your excellent advice.
Best regards
Mick Lane (Budlia)
I found the can in my workshop over the weekend - the Halfords stuff is called PlastiCote - it's brilliant!
Malc
it's brilliant!
Sure hope so Malc, wouldn't be any good otherwise! ;D
