Technical, Techniques, Hints, and Tips => Painting, Finishing and Care. => Topic started by: Anchorboy46 on June 15, 2009, 08:28:19 am
Do I need to paint or seal the inside of my vessel? I would think so, being that it might get wet at some time or another. Also, What do you guys recommend for above the waterline outside? I recently acquired a Caltex Lumba Lumba half finished kit and I glassed the hull, so it is okay. But the deck has been done in white sealer/primer only. What do you recommend? Anchorboy
Anchorboy
Sorry to leave your question unanswered for a while
The answer to the first bit depends on what the boat is made of and where you stand on letting wood breathe :}
For painting inside your hull - looks nice, You will be able to see and find things, It may help seal the hull. If you have lights they will appear brighter and more even.
Against - it may stop wood breathing and hasten rot - but you WOULD leave the hatch off and dry the boat out after each outing anyway :}
Don't know what people use for a boot topping - I have been known to use car trim tape sealed down with polyurethane varnish
andrew
